Welcome to eMastercam.com
Help with figuring angle, radius????
  • Please log in to reply
4 replies to this topic
#1
Roger
Roger
    Member
  • Members
  • PipPip
  • 244 posts
I've sectioned off a piece of a part from a customer.  Can someone have a look at it, and tell me if the area in red is an angle surface, or a radius surface.  I think it's angled, and I got 14.9214 degrees.  I've attached a Solidworks 2013 file, and a Parasolid file.Attached File  TEST.SLDPRT   288KB   18 downloadsAttached File  TEST.SLDPRT   288KB   8 downloads
#2
So not a Guru
So not a Guru
    Advanced Member
  • Members
  • PipPipPip
  • 493 posts
I can't open solidworks files, but in MC X9 you can do: Analyze/Test Surfaces and Solids/Draft angle. This will check your entire model, but you can use: Analyze/Dynamic to find the radius or angle of any surface or solid
#3
jlw™
jlw™
    Advanced Member
  • Members
  • PipPipPip
  • 1,797 posts
analyze dynamic and click a face/surface.  It it has any radius at all dynamic analyze will return a diameter value.  quick and easy.
#4
Jay Kramer @ Precision Programming
    Advanced Member
  • Moderators
  • 4,473 posts
If you are wondering if the faces are concave or Convex no. do they have a radii to them yes. they are a angled face.
#5
Roger
Roger
    Member
  • Members
  • PipPip
  • 244 posts
That was exactly what I was asking!  Thank you all for your responses!  I learned a new analyze function that I had previously not used.  I was 99.9% sure that it was an angled surface from using Solidworks evaluate features like, (curvature, zebra strips, deviation analysis, etc.), But I wanted a second opinion.   :gathering: !!!
