Contour type (chamfer)
Hello everyone,
   I'm trying to make the post shows me a message that if I'm using CONTOUR TYPE as CHAMFER and not using a chamfer tool.  I tried and the message was not pop up right.  Below these dotted lines are my defined and images, thank you for your responds
Image link
https://goo.gl/photos/Svu1US3ppZcLA3pk6
sContourType: yes$ # Chamfer feature
Under....
ptlchg_errorpop #Pop-up common toolchange errors    if tool_typ$ = 12 & (sContourType <> 1) , [if mprint(sChamferWrongContourType, 1) = 1, exitpost$] # Signal to using right tool but not chamfer toolpathUnder....pparameter$ # Run parameter table
if prmcode$ = 12014, sContourType = rpar(sparameter$, 4)
Under...
#region sChamferWrongContourTypesChamferWrongContourType = "CUT# "+sToolPathNumber+" You DID NOT choose CHAMFER feature as chamfering feature"                           +no2asc(13)+"TOOL#"+no2str(t$)                           +" ("+no2str(tldia$)+", "+s20001+")"                           +no2asc(13)                           +no2asc(13)+"Step 1: Click on PARAMETERS"                           +no2asc(13)+"Step 2: Click on CUT PARAMETERS"                           +no2asc(13)+"             look for CONTOUR TYPE(on the top right hand side)"                           +no2asc(13)+"Step 3: Click on 2D CHAMFER feature"                           +no2asc(13)+"Step 3: Click on GREEN check mark"                           +no2asc(13)                           +no2asc(13)                           +no2asc(13)+"Feed Rate: "+no2str(feed)+ " ***** #Teeth x Chip Load x RPM"                           +no2asc(13)+"Plunge Rate: "+no2str(plunge)                           +no2asc(13)+"RPM: "+no2str(speed)+" ***** (SFM x 3.82) / Tool Dia"                           +no2asc(13)+"SFM: "+no2str(sfm)+" ***** .26 x RPM x Tool Dia"                           +no2asc(13)+"ChipLoad: "+no2str(fpt)+" ***** Feed Rate (RPM x Flutes)"                           +no2asc(13)                           +no2asc(13)                           +no2asc(13)+"THIS IS SERIOUS STUFF, IT MUST BE FIXED ASAP!!!"                           +no2asc(13)                           +no2asc(13)+"Click OK to go back to MASTERCAM to fix this issue NOW!!!"#endregion
#region sWrongToolChamferWrongContourType sWrongToolChamferWrongContourType = "CUT# "+sToolPathNumber+" You chose WRONG TOOOL for chamfering feature" +no2asc(13)+"TOOL#"                                    +no2str(t$) +" ("+no2str(tldia$)+", "+s20001+")"        +no2asc(13) +no2asc(13)+"Your LINKING PARAMETER for Z Depth is: "+no2str(operation_depth)                                     +no2asc(13) +no2asc(13)+"Step 1: Click on PARAMETERS" +no2asc(13)+"Step 2: Click on TOOL"                                     +no2asc(13)+" choose any CHAMFER tool" +no2asc(13)+"Step 3: Click on GREEN check mark"                                     +no2asc(13) +no2asc(13)+"Feed Rate: "+no2str(feed)+ " ***** #Teeth x Chip Load x RPM"                                     +no2asc(13)+"Plunge Rate: "+no2str(plunge)                                     +no2asc(13)+"RPM: "+no2str(speed)+" ***** (SFM x 3.82) / Tool Dia"                                     +no2asc(13)+"SFM: "                                    +no2str(sfm)+" ***** .26 x RPM x Tool Dia" +no2asc(13)+"ChipLoad: "                                    +no2str(fpt)+" ***** Feed Rate (RPM x Flutes)"                                     +no2asc(13)                                     +no2asc(13)                                     +no2asc(13)+"THIS IS SERIOUS STUFF, IT MUST BE FIXED ASAP!!!"                                     +no2asc(13)                                     +no2asc(13)+"Click OK to go back to MASTERCAM to fix this issue NOW!!!" #endregion Under....ptlchg_errorpop #Pop-up common toolchange errors
