Welcome to eMastercam.com
2018 Public Beta open now
  • Please log in to reply
49 replies to this topic
#21
Sticky
Sticky
    Advanced Member
  • Members
  • PipPipPip
  • 875 posts
That looks nice, I think of a few nice uses for the new features.
  • RandyPhori likes this
#22
civicegg
civicegg
    Advanced Member
  • Members
  • PipPipPip
  • 384 posts
Bet you never used access keys.
Only for a few toggles
Do you mean the spring pass would continue after the first contour was complete without the tool disengaging from the path and then use the leadout when the spring pass is complete? That would be sweet.
You can do that in older versions of mcam, but requires a separate finishing toolpath. Either by using "enter onfirst depth cut only" or by "double" chaning the geometry.
#23
Sticky
Sticky
    Advanced Member
  • Members
  • PipPipPip
  • 875 posts
I'll keep that in mind, thanks for the tip.
#24
Master Mason
Master Mason
    Newbie
  • Members
  • Pip
  • 12 posts
I get this when I try to run MCam 2018. I did try to reinstall, but same problem.
#25
lowcountrycamo
lowcountrycamo
    Member
  • Members
  • PipPip
  • 31 posts
I use spring passes on anything +- .002.  I also make spring passes the same way and also dislike leadin and out there.  How to double the chain length.
#26
5th Axis Consulting Group
    Manufacturing Specialist
  • Members
  • PipPipPip
  • 14,676 posts
When you use the chain method don't use chain as your methods, but use partial. Then keep picking your chain like normal, but when you get to the start point you go around again. You can do it a couple different ways, but I find this the easiest way to teach people to do it.
  • Mick, jeff and lowcountrycamo like this
#27
Mick
Mick
    Poison Ivy
  • Members
  • PipPipPip
  • 2,292 posts
Ron, that is exactly what I have done. Especially with engraving, to avoid excessive hop ups. Using a high federate, I sometimes re-trace the contour(s). Way quicker that way :)
#28
civicegg
civicegg
    Advanced Member
  • Members
  • PipPipPip
  • 384 posts
By using the enter on first depth cut only, it allows you to add or subtract spring passes on the fly, simply by adding finish passes with a zero step over.
#29
BrianP.
BrianP.
    Advanced Member
  • Members
  • PipPipPip
  • 338 posts
I haven't downloaded 2018 so I can't see what you are seeing, but what does this feature do that you couldn't do with multi passes in the regular contour toolpath? I set finish number to 2 and leave the spacing set to 0 to do spring passes now, and it works fine. If the feature is critical I often have to create a separate tool path anyways as I probe in between the two to set the wear comp.
In your example if your rough pass was set to .100 then your finish pass is taking .100. I have had instances where the rough tool pass creates chatter and if you have your finish set to 0 it will not remove the chatter. You can now leave .005 for your finish pass then spring pass it with out creating another op.
#30
FROZEN
FROZEN
    Member
  • Members
  • PipPip
  • 246 posts
Yes. Just like in pocketing finish pass. You can now select a button for a spring pass. I have just always called it a free pass.
Spring pass, free pass and Ghost pass. I have heard a lot of different terms. In other words another finish pass to reduce tool pressure.
#31
Hcarte
Hcarte
    Newbie
  • Members
  • Pip
  • 7 posts
No when. You cannot knock the knees out of anything and expect it to stand. The legacy toolpaths are still good toolpaths and still do better in a lot of situations. Surface Rough Pocket well that is a different conversation since I have not used in years. That use to be my go to toolpath. I will still use surface finishing contour when I want to mimic the HST toolpaths for semi finishing bottom to top. Flowline and Parallel along with Scallop. We need the holder and holder avoidance added to the legacy toolpaths along with the newer interface.
Ron,
I work for a company that makes exhaust systems for Polaris.  We build all of our own Stamp tooling. We mainly use high feed tools to rough our punches and dies. Surface rough pocket is our go to toolpath. The die that I am working on today I roughed it with surface rough pocket the part took 18 minutes. I did the same part with optirough and the part took 24 minutes same tool same step over same step down.  We have been trying to use the new toolpaths but cant seem to make them run as fast as the legacy toolpaths. I would like to hear your thoughts on bigger parts that are 4.00 to 6.00 inches deep.
Howard
#32
JParis
JParis
    Merchant of Death
  • Moderators
  • 26,231 posts
Ron,
Howard
There's your issue right there....
Your step downs should most likely be 100 to 200% of dia and depending on material, assuming something like 4140, 7-10 stepover with a chip thinning calculation applied to push your feedrates..
With more info on material and tools used a closer starting situation could be offered
#33
Hcarte
Hcarte
    Newbie
  • Members
  • Pip
  • 7 posts
We are using Sandvik 210 high feed cutters. The die is 4.00 deep the material is A2.
#34
MIL-TFP-41
MIL-TFP-41
    Advanced Member
  • Members
  • PipPipPip
  • 1,245 posts
Ron,
Howard
For high feed tools try using Area Rough. it is more for shallow depths of cuts. Optirough is more for large depths of cuts, then stepping up (Tho it can be made to work like Area Rough.)
  • Mick and Rstewart like this
#35
Mick from CNC Software Inc.
    Advanced Member
  • CNC Software
  • PipPipPip
  • 1,025 posts
You will need to post this on the official beta forums.
Edited by Mick from CNC Software Inc., 16 February 2017 - 05:39 PM.
#36
  • Members
  • PipPipPip
  • 14,676 posts
Ron,
Howard
Howard, I answered you other topic and have to agree what I have been seeing has been my results, but on that part I can't say what you are currently doing is a bad way to go about it. A see a strong case of that toolpath being updated to the new interface with your sample file.
I stand corrected and I thank you for sharing the file I really appreciate seeing how someone else goes about their work. :unworthy: :unworthy: :unworthy:
  • newbeeee, CADCAM3D5AXIS and FPSteve like this
#37
civicegg
civicegg
    Advanced Member
  • Members
  • PipPipPip
  • 384 posts
4-6 inches deep, you are entering plunging territory.
#38
jlw™
jlw™
    Advanced Member
  • Members
  • PipPipPip
  • 1,784 posts
LOL that's what I just said in the other post.
#39
civicegg
civicegg
    Advanced Member
  • Members
  • PipPipPip
  • 384 posts
Yea I just read your post, son of a betch. It was the next topic I looked at....
#40
jeff
jeff
    Advanced Member
  • Members
  • PipPipPip
  • 7,278 posts
Ya know, I've been using Mastercam since V8 and it never once occurred to me to do this!  Seems like it would be quicker than what I normally do and that is to extend the end of the contour in the Lead in/out settings so my tool runs off the part on my finish pass and don't end up with that dreaded vertical blend line.
:wallbash:
  • BrianP. likes this
