Welcome to eMastercam.com
DRILLING ALUMINIUM
  • Please log in to reply
9 replies to this topic
#1
master80
master80
    Member
  • Members
  • PipPip
  • 179 posts
Hello gentlemen,
What is the best for drilling aluminium 2011 ,hole dia .111  4.5  inch deep.  (  40* D)
Gun drill not working ,after 4 psc  drill gone ::((
My max rpm is 3000
thanks for any help
#2
JParis
JParis
    Merchant of Death
  • Moderators
  • 26,231 posts
What are your speeds & feeds on that gundrill?
That's likely your best option so dialing it in properly is important
What's your gundrilling rpocess?
Are you creating a c'bore for the drill to enter the hole spinning backwards and then turning it on and applying thru tool coolant?
Drill masters suggests for their tools that size
10k RPM and 1.75 IPM
If you only have 3k, you're looking at a feed .525IPM
#3
master80
master80
    Member
  • Members
  • PipPip
  • 179 posts
3000 RPM   AND F9.
thanks for repy
#4
master80
master80
    Member
  • Members
  • PipPip
  • 179 posts
O054(***ALUMINIUM AIR HOLE ***)
(***X0Y0 CENTER OF PART ***)
T6M6(**SPOT DRILL**)
G0G90G54X0Y0B0.
M56
T36
S1500M3
G54W-2.
G43H6Z2.
M8
G98G81Z-.06R.1F10.
G0G80Z2.M9
M5
M1
T35M6(**PILOT DRILL***)
G0G90G54X0Y0B0.
M56
T36
S2000M3
G54W-2.
G43H35Z2.
M8
G98G81Z-.75R.1F6.
G0G80Z2.M9
M5
M1
T36M6(**GUN DRILL***)
G0G90G54X0Y0B0.
M56
T6
S20M3
G54W-2.
G43H6Z2.
G1Z0F50.
Z-.6F4.
M10
S3000M3
G1Z-4.5F9.
S20M3
G1Z2.M11F30.
M5
G91G28Z0W0
G28Y0
#5
master80
master80
    Member
  • Members
  • PipPip
  • 179 posts
ok,then I now what I  did wrong
#6
master80
master80
    Member
  • Members
  • PipPip
  • 179 posts
JParis
what about  high speed steel drill???this is what have in now???
#7
JParis
JParis
    Merchant of Death
  • Moderators
  • 26,231 posts
JParis
That's certainly not a gundrill as previously stated
#8
#Rekd™
#Rekd™
    Advanced Member
  • Customers
  • PipPipPip
  • 3,539 posts
Make sure you have a loc-line coolant hose pointing directly at the drill.
#9
dstryr
dstryr
    Member
  • Members
  • PipPip
  • 123 posts
40xd in that size drill with 3000 rpm?
I run a production part with 1000 psi
Guhring Gundrill .058 2.250 deep no peck
Works great and I've gotten 1000 holes out of the same drill so far in 6061
#10
5th Axis Consulting Group
    Manufacturing Specialist
  • Members
  • PipPipPip
  • 14,676 posts
PCT makes some pretty good drills up to 50D you might be surprised of their offering. Ghrung is a very solid choice, but I have had good luck with PCT.
