Welcome to eMastercam.com
Creating a ball gage tangent to a solid
  • Please log in to reply
12 replies to this topic
#1
So not a Guru
So not a Guru
    Advanced Member
  • Members
  • PipPipPip
  • 486 posts
Is this possible in MC?
We get a lot of fairly close tolerance countersink callouts & what we usually do is put a M00 that tells the operator to put a positive height offset for the tool in, before running the c'sink. Then after it's ran, they check it by measuring with a ball gage & adjust the offset accordingly.
I always have to draft the geometry of the c'sink & ball dia to determine what the measurement should be.
I was just wondering if there was a more faster way to do this.
#2
jlw™
jlw™
    Advanced Member
  • Members
  • PipPipPip
  • 1,784 posts
absolutely
  • So not a Guru likes this
#3
So not a Guru
So not a Guru
    Advanced Member
  • Members
  • PipPipPip
  • 486 posts
absolutely
Is it a secret that I need my Cracker Jacks decoder ring for? :secret:
#4
jeff
jeff
    Advanced Member
  • Members
  • PipPipPip
  • 7,278 posts
Silly, it's the Little Orphan Annie secret decoder ring!
Be sure to drink your Ovaltine!
#5
JoshC
JoshC
    Member
  • Members
  • PipPip
  • 255 posts
I would go about it like this: https://www.dropbox....ntBall.mp4?dl=0, I don't know if its the fastest way but that is how I would handle this task.
#6
jlw™
jlw™
    Advanced Member
  • Members
  • PipPipPip
  • 1,784 posts
I didn't look at JoshC's file but I do it with geo and use sizes of readily available ball gages.  I send out a print with what ball gage to use and what it should read on depth mics.  Can you share a file, I'll show you how I do it.
#7
SlaveCam
SlaveCam
    Member
  • Members
  • PipPip
  • 276 posts
I'd do a spreadsheet document for calculating the values. It's basic 2D math. Put in the gage ball diameter, countersink tip angle and either the start or end diameter of the cone and the spreadsheet will give you the needed Z value.
#8
jayzy
jayzy
    Newbie
  • Members
  • Pip
  • 2 posts
You should look at JoshC's file, cause that how I do it too.
#9
So not a Guru
So not a Guru
    Advanced Member
  • Members
  • PipPipPip
  • 486 posts
Thanks guys! I was camping so I didn't get this till this morning. Josh, that is exactly what I was looking for.
  • JoshC likes this
#10
BrianP.
BrianP.
    Advanced Member
  • Members
  • PipPipPip
  • 338 posts
I have used these gauges with good results.
  • htm01 and Charlie Pierson like this
#11
Charlie Pierson
Charlie Pierson
    Advanced Member
  • Members
  • PipPipPip
  • 784 posts
That gage works well, IMHO
#12
So not a Guru
So not a Guru
    Advanced Member
  • Members
  • PipPipPip
  • 486 posts
Yes, we have them, but not for all diameters & all angles. Also, there are many applications where these gauges are interfered with but other areas of a part.
#13
5th Axis Consulting Group
    Manufacturing Specialist
  • Members
  • PipPipPip
  • 14,676 posts
I do it like Josh, expect I use the primitives to make the Solid Sphere so I can do solid layout to make a print to send to the floor for checking them.
