Sign in to follow this
byte
Vbscript : Adding arcs instead of points to drilling operation
Hi, I was wondering if their is a way to add arcs instead of points to a drill op via vbscript. Here is my code for drilling :
Function DrillAllAddToOperation(LevelToDrill,PathToOpLibrary,OpNameAsString,OpCommentAsString,OverRideSettings,currentview)
Call FreeChains
Call UnselectAll
Call RepaintScreen(True)
Call SetCPlaneNumber(currentview)
Call SetTPlaneNumber(currentview)
Call ZeroPts
Dim SearchArcs
SearchArcs = StartDBSearch(mc_alive, mc_arctype)
If SearchArcs Then
Do
If Not LevelToDrill <> GetEntityLevel Then
Dim Arc
Set Arc = New McAr
If GetArcData(GetEntityEptr, Arc) = True Then
Call AddDrillPoint (Arc.X, Arc.Y, -1)
End If
End if
Loop While NextDBSearch
End If
If MakeOperationFromName(PathToOpLibrary,OpNameAsString,OpCommentAsString, OverRideSettings) <> mcOPERATION_INVALID Then
Else
End If
Call SetCPlaneNumber(mcVIEW_TOP)
Call SetTPlaneNumber(mcVIEW_TOP)
Call ZeroPts
End Function
Thank youu!
ps. I know this language is out of date but IT is having trouble download visual studio onto my machine with windows 10
It is certainly out of date and essentially deprecated at this point but you might be able to use AddArcPoint()
If you open or create a VBScript in Mastercam Code Editor you will get intellisense to help find functionality.
Mick,
thank you.
 If I may ask another question, would it be possible to disable duplicate tool checking during makeoperationfromfilename ?
33 minutes ago, Mick George said:
That would be a question for roger, i would ping him via [email protected]
Thank you Mick.
17 minutes ago, Roger Martin from CNC Software said:
Peter,
See :
NET-Hook API Reference Guide
https://nethookdocs.mastercam.com
Search for: OperationsManager.ImportOperation
Note the ImportOptions that are passed to the ImportOperation method.
Thank you for the reply Roger,
I am looking to add an arc to an already existing drilling or circle milling/helixbore operation
Search for: "DrillPoint"
See: DrillPoint Constructor (ArcGeometry)
In a "Point-Based" type operation in the NET-Hook API...
The toolpath geometry assigned to it are "DrillPoint" objects.
The operation has the "DrillPoints" member data that contains these points.
-Pseudo code-
// MyArc - is an existing ArcGeometry object.
// MyDrillOp - is a "Point-Based" type operation.
var drillPt = new DrillPoint(MyArc);
MyDrillOp.DrillPoints.Add(drillPt);
MyDrillOp.Commit();
MyDrillOp.Regenerate();
Thank you very much.
-Pseudo code-
MyDrillOp.Commit();
It works perfectly, thanks again.
In my user profile these functions work well, however on 2 other users there is some undefined behavior where toolpaths are being sometimes mangled, I will probably switch to using only pocket and contour toolpaths to deal with the former helix bore, circle mill toolpaths, the drilling doesn't seem to cause a problem, but I will most likely return to the c++ point based system for drilling.
