Sign in to follow this
byte
C++/Cli NEThook Entry Point
Here is the code I am using now to create c++/cli NEThooks that can access both c++ and c# functions compiled into 1 DLL for visual studios :
using Mastercam::App::NetHook3App;
public ref class MyConcreteClass : public NetHook3App
public : virtual Mastercam::App::Types::MCamReturn Run(int param) override {
//your code here//
	System::Windows::Forms::MessageBox::Show("msg");
		return Mastercam::App::Types::MCamReturn::NoErrors;
To do this :
-> download the c++/cli add on for visual studios 2017 community
->create a new clr empty project in visual studios
-> link in the NEThook3_0.dll file from your mastercam
->add the above code to a new file called main.cpp
->add a .resx file and add in your tool tip information
->create an ft. file with the tooltip and resource information
->compile the project and place the resulting .dll file and .ft file in the chooks folder
-> add a tooltip to your context menu then run the nethook you will see a winforms messagebox dispay : "msg"
-> from there you could add in the desired c++ sdk libraries and nethook3_0 funtions that you want to use.
Thank you for taking the time to read.
some mixed code
	ChainManager::ChainTolerance = 0.015;
		LevelsManager::SetMainLevel(50000);
		const auto chains = Mastercam::Database::ChainManager::ChainAll(true, false, nullptr, Mastercam::Database::Types::ChainDirectionType::Clockwise, 50);
		ChainManager::SortChains(chains, ChainManager::SortType::Area, ChainManager::SortOrder::Descending);
		const auto offsetChaini = chains[0]->OffsetChain2D(Mastercam::Database::Types::OffsetSideType::Left, 0.0, Mastercam::Database::Types::OffsetRollCornerType::None, 0.0, false, 0.01, true);
		const auto chngeometry = ChainManager::GetGeometryInChain(chains[0]);
		for (long i = 0; i < chngeometry->Length; i++)
			chngeometry[i]->Delete();
void SplineFromChainsOnLevel(const int &level4)
	    //chain the geometry on a specified level : returns a chain array
		const auto chains4 = ChainManager::ChainAll(true, false, nullptr, Mastercam::Database::Types::ChainDirectionType::Clockwise, level4);
        //check that we have something////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
		if (chains4 != nullptr && chains4->Length != 0)
			//convert the current geometry in chain array to parametric spline : delete the original geometry
			GeometryCreationManager::CreateParametricSplineFromChain(chains4[0], 0.015, Mastercam::GeometryUtility::Types::OriginalCurvesDisposition::Delete, 500);
void GetOuterChainFromLevel(int level)
	const auto chains = Mastercam::Database::ChainManager::ChainAll(true, false, nullptr, Mastercam::Database::Types::ChainDirectionType::Clockwise, level);
	if (chains != nullptr && chains->Length != 0)
		//sort chains by area in descending order : largest to smallest area
		//use the offset function to separate the largest area chain from the group: the new geometry will be created on the current active level
		//get the geometry from chain index zero
		//loop through each element in the geometry array derived from the chain
			//delete the orginal geometry
Another Sample for contourOp with c++/cli
int makecsopfromchains(int level, double clearancePlane, double feedPlane, double topOfStock, double depth, int viewId,
Mastercam::Operations::Types::ContourSubtypeType cntrtpe, Mastercam::Database::Types::CutterCompDir cuttercompdir,
Mastercam::Database::Types::ChainDirectionType chndir,int FeedRate,int spindlespeed,bool tabon)//, EndMillFlatTool ^ tool)
	const auto chains = Mastercam::Database::ChainManager::ChainAll(true, false, nullptr, chndir, level);
	operation op = {};
		auto views = Mastercam::Support::SearchManager::GetViews();
		Mastercam::IO::ViewManager::GraphicsView = views[viewId];
		Mastercam::IO::ViewManager::CPlane = views[viewId];
		Mastercam::IO::ViewManager::TPlane = views[viewId];
		auto cntrop = gcnew Mastercam::Operations::ContourOperation;
		cntrop->CutterComp.Direction = cuttercompdir;
		cntrop->CutterComp.RollCorners = Mastercam::Database::Types::CutterCompRoll::CutterCompRollAll;
		cntrop->Linking->Depth = depth;
		cntrop->Linking->ClearanceOn = true;
		cntrop->Linking->Clearance = clearancePlane;
		cntrop->Linking->Retract = clearancePlane;
		cntrop->Linking->RetractOn = true;
		cntrop->Linking->TopStock = topOfStock;
		cntrop->MiscValues->UseValuesFromPost = true;
		cntrop->CutParams.LeaveStock.OnFloors = 0.0;
		cntrop->CutParams.LeaveStock.OnWalls = 0.0;
		cntrop->CutParams.InfiniteLookAhead = true;
		cntrop->MultiPass.Enabled = false;
		if (tabon)
			cntrop->Tabs.Enabled = true;
			cntrop->Tabs.NumberOfTabs = 4;
			cntrop->Tabs.EntryExitMode = Mastercam::Operations::Types::TabEntryExitType::Vertical;
			cntrop->Tabs.TabThickness = 0.04;
			cntrop->Tabs.TabWidth = 0.1;
		cntrop->ForceToolChangeOn = false;
		cntrop->BreakThrough.Enabled = false;
		cntrop->ArcFilter.Enabled = false;
		cntrop->RotaryAxis.Enabled = false;
		cntrop->CutParams.ContourSubtype = cntrtpe;
		cntrop->CutParams.InternalCornerRoundingRadius = .001;
		cntrop->Entry.ArcRadius = .025;
		cntrop->Entry.ArcSweep = 90.0;
		cntrop->Entry.HelixHeight = 0.0;
		cntrop->Entry.Enabled = true;
		cntrop->SpindleSpeed = spindlespeed;
		cntrop->FeedRate = FeedRate;
		cntrop->NCIName = "Contour #1";
		cntrop->Name = "Contour operation created via API";
		op.op_idn = cntrop->GetOperationID();
		cntrop->SetChainArray(chains);
		if (!cntrop->Commit())
			return 0;
	return 1;
some new functions
int makehlxbreopfromgeo( double clearancePlane, double feedPlane, double topOfStock, double depth, int viewId,  int FeedRate, int spindlespeed, int slot)
	operation op = {};
	System::Collections::Generic::List<Mastercam::Curves::ArcGeometry ^> ^arcs;
	auto cntrop = gcnew Mastercam::Operations::HelixBoreOperation;
	auto arcType = Mastercam::Curves::ArcGeometry::typeid;
	auto ptcount = 0;
	auto selectedEnts = Mastercam::Support::SearchManager::GetSelectedGeometry();
	// Iterate through each wireframe entity
	//System::Windows::Forms::MessageBox::Show(selectedEnts->Length.ToString());
	for (auto i = 0; i < selectedEnts->Length; i++)
		auto gt = selectedEnts[i]->GetType();
		//System::Windows::Forms::MessageBox::Show("gt=> " + gt->ToString());
        if (gt == arcType)
			auto drillPt = gcnew Mastercam::Database::DrillPoint(dynamic_cast<Mastercam::Curves::ArcGeometry ^> (selectedEnts[i]));
			cntrop->DrillPoints->Add(drillPt);
			ptcount++;
		cntrop->AssignMillToolBySlot(slot);
		//linking params
		cntrop->Linking->FeedPlane = feedPlane;
		cntrop->PlungeRate = 75.0;
		cntrop->RetractRate = 500.0;
		//lead in
		//entry params
		//end lead in
		//set feedrate
		cntrop->NCIName = "Helix #1";
		cntrop->Name = "Helix Bore operation created via API";
		cntrop->Commit();
		cntrop->Regenerate();
		DB_LIST_ENT_PTR ptr{};
		bool succf{};
		operation_manager(&op, OPMGR_GET, &ptr, &succf);
		op.cmn.stk_remain = 0.0;
		op.dcuts.stock_t_l = 0.0;
		op.u.helix_bore.finish_feedrate_pct = 100.0;
		op.u.helix_bore.entry_exit_sweep = TWO_PI / 4;
		op.u.helix_bore.finish_on = false;
		op.u.helix_bore.rough_pitch = .05;
		op.u.helix_bore.start_at_center = true;
		op.u.helix_bore.n_rough_passes = 1;
		op.u.helix_bore.perp_entry = true;
		op.u.helix_bore.overlap = 50.0;
		op.u.helix_bore.entry_exit_sweep = 45.0;
		op.u.helix_bore.start_angle = 90.0;
		op.u.helix_bore.calcDepthFromStock = false;
		operation_manager(&op, OPMGR_REWRITE, &ptr, &succf);
		operation_manager(&op, OPMGR_NCI_REGEN, &ptr, &succf);
	return 1;
int makedrillopfromgeo(double clearancePlane, double feedPlane, double topOfStock, double depth, int viewId, int FeedRate, int spindlespeed, int slot)
	operation op = {};
	auto cntrop = gcnew Mastercam::Operations::DrillOperation;
	auto ptcount = 0;
		if (gt == arcType)
			ptcount++;
	//linking params
	//lead in
	//entry params
	//end lead in
	//set feedrate
	cntrop->NCIName = "Drill #1";
	cntrop->Name = "Drilling operation created via API";
	cntrop->Commit();
	bool succf{};
	op.u.prm_drl.brk_thru = 0.0;
	op.u.prm_drl.calcDepthFromStock = false;
	op.u.prm_drl.cycle = 1;
	op.u.prm_drl.drill_tip = false;
	op.u.prm_drl.dwell = 0.0;
	op.u.prm_drl.peck1 = 0.55;
	op.u.prm_drl.peck2 = 0.05;
	op.u.prm_drl.peck_clr = 0.5;
	op.u.prm_drl.start_hole = false;
	op.u.prm_drl.sub_pgm = false;
	op.u.prm_drl.do_custom = false;
	op.u.prm_drl.TipControl = 0;
	return 1;
int makecrcmillopfromgeo(double clearancePlane, double feedPlane, double topOfStock, double depth, int viewId, int FeedRate, int spindlespeed, int slot,double num_fcuts, double size_fcuts,double stk_tl_onwall)
	operation op = {};
	auto cntrop = gcnew Mastercam::Operations::CircleMillOperation;
	auto ptcount = 0;
		if (gt == arcType)
			ptcount++;
	//linking params
	//lead in
	//entry params
	//end lead in
	//set feedrate
	cntrop->NCIName = "Circle milling #1";
	cntrop->Name = "Circle Milling operation created via API";
	cntrop->Commit();
	bool succf{};
	op.cmn.stk_remain = stk_tl_onwall;
	op.dcuts.fin_n = num_fcuts;
	op.dcuts.fin_amt = size_fcuts;
	op.dcuts.on = true;
	op.dcuts.sub_pgm = false;
	op.dcuts.bottom_up = false;
	op.dcuts.by_depth = false;
	op.dcuts.rgh_n = 1;
	op.dcuts.rgh_amt = 1000.0;
	op.dcuts.island_depths = false;
	op.u.circmill.calcDepthFromStock = false;
	op.u.circmill.cmn.brkthru_on = false;
	op.u.circmill.cmp_to_tip = false;
	op.u.circmill.entry_exit_sweep = 90.0;
	op.u.circmill.entry_fr_override_on = false;
	op.u.circmill.exit_fr_override_on = false;
	op.u.circmill.finish_all = false;
	op.u.circmill.fin_fr_override_on = false;
	op.u.circmill.helix_on = false;
	op.u.circmill.fin_ss_override_on = false;
	op.u.circmill.hs_entry_on = false;
	op.u.circmill.mp_fin_on = false;
	op.u.circmill.mp_rgh_on = false;
	op.u.circmill.perp_entry = false;
	op.u.circmill.start_at_center = true;
	op.u.circmill.overlap = 0.0;
	op.u.circmill.rough_on = false;
	op.u.circmill.taper = false;
	return 1;
