Access to solid edge data
hello,
I have one question i dont have found any answer in the online documentation.
Is it possible with NetHook to have, without create any additionnal  geometry, the canonic datas of a solid edge?
- The type (Arc, Line, Nurbs…)
- And the data (Arc center, radius, plane or line ends) ?
In Mastercam, that's possible for exemple with analyze function, but is it possible to do the same in a Net Hook program and access to all of these data?
SolidEdge.JPG.fd1a4efecf02d87147daa5443e723070.JPGimage.png.1e34b8e6e3e2f1bd19dbb8fecc431974.png
Thanks in advance!
1 hour ago, LMVUICHARD said:
Thank you very much for your quick answer, despite its content... decidedly, i'm a little bit unlucky with Net-Hook projects!
Have a nice day!
There is the ability to have the edge curves come into Mastercam if that option is turned on when the file is imported. If they are turned on and you have them does that help with what your trying to accomplish?
Yes, i know this option, but it create ALL edges in the model, for only few needed...
Cleaning and sorting after is not shorter compared to create some.
Create some edges it's not really a big deal, but it's make the application less "Fully native solid integrated"...
Many users, coming from CAD solid world, don't understand it be needed to create wireframe geometry before all...
But thank you for your proposal!!
With the chook sdk you could set up a function like this to create solid edges at the desired depth
int CrtEdgCrvsTrgt(int num, MC_BYTE color, double LwrScnLmt, double UprScnLmt, long level)
	bool CreateEdges = true;
	SetMainLevel(level);
	bool succf = false; long num_curve_create = 0; SldTagArray sldFaces;
	PSBodyAskFaces(num, sldFaces); long fccnt = PSBodyAskFaces(num);
	for (long i = 0; i < fccnt; i++) {
		bool isfce1 = ps_is_face(sldFaces[i]); if (isfce1) {
			bool creasrf = false;
			DB_LIST_ENT_PTR ** eptrs; SldTagArray sldEdges; SldTagArray sldEdges2;
			int vertex0{}, vertex1{}; long num2 = PSFaceAskEdges(sldFaces[i], sldEdges); for (long i2 =
				0; i2 < num2; i2++) {
				bool isedg1 = ps_is_edge(sldEdges[i2]); if (isedg1) {
					long num2 = ps_get_edge_vertices(sldEdges[i2], &vertex0, &vertex1);
					bool isv1 = ps_is_vertex(vertex0); bool isv2 = ps_is_vertex(vertex1);
					if (isv1 && isv2) {
						p_3d p3d1{}; bool scf1 = ps_get_vertex_point(vertex0, p3d1);
						p_3d p3d2{}; bool scf2 = ps_get_vertex_point(vertex1, p3d2);
						p_3d pt1; view_to_view(p3d1, 1, 1, pt1);
						p_3d pt2; view_to_view(p3d2, 1, 1, pt2);
						if (scf1 == true && scf2 == true && pt1[2] < UprScnLmt && pt2[2] < UprScnLmt &&
							pt1[2] > LwrScnLmt && pt2[2] > LwrScnLmt) {
							creasrf = true;
						else { creasrf = false; break; }
			if (creasrf == true) {
				SldSetFaceColor(sldFaces[i], color); if (CreateEdges) {
					long num3 = PSFaceAskEdges(sldFaces[i], sldEdges2);
					for (long i3 = 0; i3 < num3; i3++) {
						bool isedg2 =
							ps_is_edge(sldEdges2[i3]); if (isedg2) {
							num_curve_create =
								ps_tag_to_mc_ents(sldEdges2[i3], 0);
				if (num_curve_create != 0 && num_curve_create > 0) { succf = true; }
				return succf ? num_curve_create : 0;
				creasrf = false; //out of range
Also : see my post about creating c++/cli nethook entries to take advantage of chook functions while maintaing access to your .net code
Big thank you for your contribution Peter!
For the moment, i'm just in exploration of the NetHook capabilities.
But what you write, and other tips you've posted gave me want to explore in addition on sdk and Chook...
I'm more used to Vb (Sorry…). But i hope i can understood quickly the C (++ and #) basics keys... at least i can try!
Now the problem for me is to find enough time to read, write and test between possibilities...
Thanks to you!
  • 4 years later...
					if (isv1 && isv2) {
							creasrf = true;
						bool isedg2 =
							num_curve_create =
Hi,
I am trying to export a solid entity (mc_solid_ent). For my purpose I need to iterate in depth over all its Parasolid objects – body, faces, edges, and vertices.
ps_tag_to_mc_ents function works, but it actually explodes the object and creates multiple new objects. I don't want to modify the original project.
Is there a way to iterate over all Parasolid objects in depth without using this function?
If there is no such way, what is the best approach to delete all newly generated objects? - I don't like this as a solution - redundant, requires extra memory, time consuming, etc., but if there is no other option...
I commonly use the undo functions when working with ps_tag_to_mc_ents. Similar to your situation, I'll need characteristics from a solid entity and this is the only way I know how to get what I need and not create a mess.
UndoTransStart();
ps_tag_to_mc_ents();
//any code executed here will be undone when next line is executed
UndoTransTerminate();
