Sign in to follow this
byte
How to ublank entities in a Chook ?
Good day,
I am blanking the entities in my mcx files with this function
int doentblnk(long selectionMask = ALL_ENTITIES_MASK, int level = 0, MC_BYTE color = 0)
	long count = 0; bool succf, suc = false; ent entity; DB_LIST_ENT_PTR foundPtr; DB_LIST_ENT_PTR eptr = db_start;
	do
		get_raw_ent(false, &eptr, &foundPtr, &entity, 0, ALL_ENTITIES_MASK, &succf);
		if (succf)
			if (entity.id != selectionMask)
				suc = true;
				sel_bit_turn_on(&entity, BLANK_BIT);
				write_ent_sel(&entity, entity.eptr);
	} while (succf);
	return suc ? 1 : 0;
However, when I try to reverse the process by setting BLANK_BIT off it does not work.
Not sure what you mean about "does not work".
This worked for me (tested in 2018 and 2020) ->
extern "C" __declspec (dllexport) int m_main (int not_used)
	// Must call this prior to accessing any Resources in the C-Hook DLL !
	ChangeResCl res (GetChookResourceHandle ());
	ent entity;
	if (AskForGeometry (_T ("Select an Arc..."), A_ID, entity))
		sel_bit_turn_on (&entity, BLANK_BIT);
		write_ent_sel (&entity, entity.eptr);
		AfxMessageBox (_T ("Entity was Blanked"));
		sel_bit_turn_off (&entity, BLANK_BIT);
		AfxMessageBox (_T ("Entity was UnBlanked"));
	return MC_NOERROR | MC_UNLOADAPP;
	ent entity;
Hi Roger,
some of the entities are not returning from their blanked state even manually after processing, but they are registered in the level manager.
I used this function
int doentunblnk(long selectionMask = ALL_ENTITIES_MASK, int level = 0, MC_BYTE color = 0)
	std::vector<ent> ents; std::vector<ent> ents2;
	do
		if (succf)
				sel_bit_turn_off(&entity, BLANK_BIT);
	} while (succf);
	return suc ? 1 : 0;
The now un-blanked entities are not appearing visually on-screen?
ref: interfaces\GUI\CGui_ch.h
// Try this first after the un-blanking.
repaint_graphics ();
// This 'repaint_graphics' does do it for you, replace it with this ->
rebuild_graphics();  //  Only use if really needed, as this can take time.
} while (succf);
if (suc) //  Was anything changed?
return suc ? 1 : 0;
} while (succf);
return suc ? 1 : 0;
Thanks Roger, that fixed the problem, although jeeez I don't think I can afford the performance loss on that one.
I used both, there is however a lot going on in between, could the call set_clr_sel_bits() be interfering, I also did not call freechains while doing chain_intersect..
My problem is the management of existing geometry, in my project I host a collection of c++/cli nethook entry points each designed to :
->get a solid if there is 1 solid in the file
->blank the existing non solid entities ,lines,arcs, notes,splines etc.
->create geometry on the min/max z extends of the part using the psbodyaskfaces and psbodyaskedges on a unique level for each top and bottom group
->creates a silhouette boundary using mastercams silhouette boundary function onto a unique level
->separating the outer "external" profile of the silhouette boundary ,top geometry and bottom geometry levels using nethook chainmanger and sort chains by area functions
->separating the "full" 360 degree arcs onto a unique level for top and bottom
->comparing the xy CenterPoint and diameter values to find the "through" holes then storing them on a unique level
->converting all non full circle wireframe geometry to splines via nethooks createparametricsplinefromchains to avoid parts of the chain being dropped by nesting undetected
->using c++ chains_intersect and comparing the spline length on the remaining "internal" top and "internal" bottom group against the remaining silhouette boundary "internal" group and deleting the "through" pockets
->repeating the above process to filter out the full circles entities from the silhouette boundary "internal" group
-> assign specific toolpaths to each group of geometry on each level : top plane pockets, bottom plane pockets, top blind holes, bottom blind holes,bottom through holes,and the outer profile final contour
In order to avoid inadvertently chaining existing geometry on the target levels I blank them with the first function, however it would be nice to return any notes or geometry for the
user, although this is not critical since we will be nesting after some parts may contain engineering notes pertaining to customer requirments for a specific part.
We make private jet interiors so there are a lot of "special cases" that need documentation and because of the fast pace production line style of programming notes in mastercam save a lot of time and ensure important information for the programmer is delivered.
Quote
Depends if you're messing with the BLANK_BIT when using this.
So you are "blanking" the items you don't want included in the chain(s) and then chaining all on that level?
Quote
Is that the only way you have to separate the items to be chained?
Can you separate the desired items - by type, by color, or...
Edited by Roger Martin from CNC Software
It is only clearing SELECT_BIT
Yes.
Same problem since I am concerned with what would happen were the chook would to be ran twice.
I have an Idea but I do not know how, could I recolor all the existing entities in the database then use color schemes to define which geometry to chain? I am chaining with the .net api chainmanager. (my efforts to do chaining in c++ have not been very successful)
Can you email me a sample part file? SDK [at] mastercam [dot] com
 Just a sample of the geometry you're dealing with and let me know which items should be chained and which should be ignored.
Since you doing C++/CLI you have all of the tools available to you.
I sent you an email Roger.
OK...
 You're trying to chain what, on which level, while having the chaining ignore what type(s) of geometry?
You're said you're doing this by blanking the unwanted entities, which while this will work...
You don't like the need to have to call rebuild_graphics after. Fair enough, as that can take some time to complete.
There may be other ways to segregate the wanted from the unwanted geometry when chaining.
If I have details, I may be able to offset suggestions,
CHAIN Level : 10000000  + Level 500000000 as top pocket operation
CHAIN Level : 5000000  + Level 500000000 as bottom pocket operation
CHAIN Level : 50 as bottom pocket operation
CHAIN Level : 100 as top pocket operation
CHAIN Level : 5000 as contour osciliation bottom plane
CHAIN Level : 5000 as 2d contour bottom plane
CHAIN Level : 50000000 as contour osciliation top plane
CHAIN Level : 50000000 as 2d contour top plane
Our programmers are currently using an older chook I wrote to program full  360 degree arcs so I will deal with those at a later date.
We are currently using the new chooks also as of yesterday, It is working well, the issue is really just the blank entities requiring refresh.
