How to find type of curve geometry in c++/cli
I'm having trouble figuring out how to look for different types in curve geometry array in c++/cli .net type :
 auto slctedents = Mastercam::Support::SearchManager::GetSelectedGeometry();
		if (slctedents->Length > 0)
			// Iterate through each wireframe entity
			for (auto i = 0; i < slctedents->Length;i++)
				if (slctedents[i]->GetType() == Mastercam::Curves::ArcGeometry::typeid)
					auto arc = gcnew  Mastercam::Curves::ArcGeometry;
This is not correct obviously, I'm a bit stuck.
Try this.
/// <summary> Get the selected wireframe geometry by type. </summary>
/// <param name="points"> [out] The points. </param>
/// <param name="lines">  [out] The lines. </param>
/// <param name="arcs">   [out] The arcs. </param>
void SelectedWireframeGeometryByType (
	System::Collections::Generic::List<Mastercam::BasicGeometry::PointGeometry ^> ^points,
	System::Collections::Generic::List<Mastercam::Curves::LineGeometry ^> ^lines,
	System::Collections::Generic::List<Mastercam::Curves::ArcGeometry ^> ^arcs)
	auto pointType = Mastercam::BasicGeometry::PointGeometry::typeid;
	auto lineType = Mastercam::Curves::LineGeometry::typeid;
	auto arcType = Mastercam::Curves::ArcGeometry::typeid;
	auto selectedEnts = Mastercam::Support::SearchManager::GetSelectedGeometry ();
	for (auto i = 0; i < selectedEnts->Length; i++)
		auto gt = selectedEnts[i]->GetType ();
		if (gt == pointType)
			// dynamic_cast here is like the "as" keyword in C#
			points->Add (dynamic_cast<Mastercam::BasicGeometry::PointGeometry ^> (selectedEnts[i]));
		else if (gt == lineType)
			lines->Add (dynamic_cast<Mastercam::Curves::LineGeometry ^> (selectedEnts[i]));
		else if (gt == arcType)
			arcs->Add (dynamic_cast<Mastercam::Curves::ArcGeometry ^> (selectedEnts[i]));
void TestGetByType ()
	auto points = gcnew System::Collections::Generic::List<Mastercam::BasicGeometry::PointGeometry ^> ();
	auto lines = gcnew System::Collections::Generic::List<Mastercam::Curves::LineGeometry ^> ();
	auto arcs = gcnew System::Collections::Generic::List<Mastercam::Curves::ArcGeometry ^> ();
	SelectedWireframeGeometryByType (points, lines, arcs);
	auto msg = System::String::Format ("{0} - Points\n{1} - Lines\n{2} - Arcs", points->Count, lines->Count, arcs->Count);
	System::Diagnostics::Debug::WriteLine (msg);
	// Using the 'native' MessageBox here just so that we don't need to reference System::WindowsForms.
	MessageBox (nullptr, CString (msg), _T ("Wireframe Geometry"), MB_ICONINFORMATION);
Edited by Roger Martin from CNC Software
Hi Roger,
The example compiles, however, It gives me a warning "no instance of constructor "System::Collections::Generic::List<T>::List[with T=Mastercam::Curves::ArcGeometry ^] matches the argument list, and it returned zero on all the results even with selected geometry, however it gives a bad error if I select solids or non wireframes so..I think its doing something.
Pete,
I have no idea what you have going on here. The constructor error make no sense.
To be sure that the code in the previous post was not mangled, I copied that code directly from that post to a C++/CLI project (that references the NETHook API).
And... It builds, runs and produces the expected result. Tested in Mastercam 2018 and 2020.
Expanding it out to include processing of Surfaces/Solids may be a bit more involved.
To see exactly what the "type" you're dealing with, add some diagnotics.
auto gt = selectedEnts->GetType ();
System::Diagnostics::Debug::WriteLine ("gt=> " + gt->ToString ());
if (gt == pointType) {...}
