Sign in to follow this
Temores2790
Comments not posting
I need help with my post because is no posting the comments in tools or in the manual entry it doesn't output the comments or the codes and I have already the option to get the comments
tool_info    : 3    #Output tooltable information?
                     #0 = Off - Do not output any tool comments or tooltable
                     #1 = Tool comments only
                     #2 = Tooltable in header - no tool comments at T/C
                     #3 = Tooltable in header - with tool comments at T/C
pstrtool        #Comment for tool
      if strtool$ <> sblank,
        strtool$ = ucase(strtool$)
        *strtool$
  pcomment$       #Comment from manual entry (must call pcomment2)
      pcomment2 #Required if doing boolean 'if' logic testing!
pcomment2       #Output Comment from manual entry
      scomm$ = ucase (scomm$)
      if gcode$ = 1005, sopen_prn, scomm$, sclose_prn, e$  #Manual entry - as comment
      if gcode$ = 1006, scomm$, e$                         #Manual entry - as code
      if gcode$ = 1007, sopen_prn, scomm$, sclose_prn      #Manual entry - as comment with move NO e$
      if gcode$ = 1026, scomm$                             #Manual entry - as code with move NO e$
      if gcode$ = 1008, sopen_prn, scomm$, sclose_prn, e$  #Operation comment
      if gcode$ = 1051, sopen_prn, scomm$, sclose_prn, e$  #Machine name
      if gcode$ = 1052, sopen_prn, scomm$, sclose_prn, e$  #Group comment
      if gcode$ = 1053, sopen_prn, scomm$, sclose_prn, e$  #Group name
      if gcode$ = 1054, sopen_prn, scomm$, sclose_prn, e$  #File Descriptor
1) What is the base post?
2 Has it been previously edited?
This should normally work out of the box. Did you edit the comment section when doing the header?
Is your ptoolcomment section missing? The pstrtool function just makes the comment uppercase.
ptoolcomment    #Comment for tool
      tnote = t$, toffnote = tloffno$, tlngnote = tlngno$
      if tool_info = 1 | tool_info = 3,
        pstrtool #Convert strtool$ to uppercase if string is not empty
        scomm_fx_arg = strtool$ + sdelimiter + drs_str(2, tnote) + sdelimiter +
          drs_str(2, toffnote) + sdelimiter + drs_str(2, tlngnote) + sdelimiter + drs_str(2, tldia$)
        pcomment_out #Check comment length and output to NC file
thanks!! that was the problem!!! I fixed
