Grimes
Mazak operators and post
Havent posted in a while, but have been lurking. anyways, our company was bought by a new person ( boss retired ) and our main mazak programmer moved mostly into the office. so about 6 mazak mills may open up for someone to step in. im trying to be the one to step in. i set up a part about 2 years ago on the one machine. im going to modify my fanuc post to suit this new control. the different codes and such shouldnt be too hard, but these machines use fpr vs. ipm. that is what i am trying to ask is how to change my post to fpr.
did a bit of searching but really couldnt understand much about using G95. any help would be greatly appreciated. these controls are totally different lol.
Feed comes out of the 'feed' variable.
All you really need to do in the Post is redefine how 'feed' is setup.
I would add a global formula to the start of your post:
feed = fr_pos$ / ss$
That should honestly set you up for most milling, so long as your Machines really are always set to 'FPR' mode.
If your Operation was programmed at 30 IPM, and your RPM was 5,500, your "F" value would be: F.0045
You will need to find the "Format Assignment" for the 'feed' variable, and modify it for additional "Decimal places" on the output.
Try adding this to your Format Statement section:
fs 44  0.5
Then, modify the 'feed' variable Format Assignment from this:
fmt  "F" 15 feed        #Feedrate
To this:
fmt  "F" 44 feed        #Feedrate
If you need to change the 'F' character to 'E', do this:
fmt  "E" 44 feed        #Feedrate
gonna try this tonight. youd think mastercam would just have a switch in the control definition for which feed you wanted ipm or fpr. thanks as always colin. will test it out.
what does this mean?
tap_feedtype       : 1     #0 = Units Per Minute (G94)
                           #1 = Units Per Revolution (G95)
how do you change that in the parameters for tapping?
was just reading that in the post
If it's in the general output settings I reckon you would set it to 1 to output feed per rev. The tap cycle reads that if I recall
looked for that couldnt find it.
heres where im at:  ( using the first three thin.gs you said not changing the f to an e )
just drew a simple box using a 1/2" endmill, and tapped one point.
posted two, one of which i know that there is an error.
21 Jan 2020 08:18:53 PM - Report created.
21 Jan 2020 08:18:53 PM - Initialize posting log file
21 Jan 2020 08:18:53 PM - Using MP run version 20.00 and post components version 20.00
21 Jan 2020 08:18:53 PM - Initiate opening the post processor file(s).
21 Jan 2020 08:18:53 PM - C:\Users\Public\Documents\shared Mcam2018\mill\Posts\MAZAK WITH STAGE TOOLING.PST
21 Jan 2020 08:18:53 PM - The post processor file has been successfully opened.
21 Jan 2020 08:18:53 PM - Initialization of pre-defined post variables, strings, postblocks was successful.
21 Jan 2020 08:18:53 PM - Search for defined post variables, strings, postblocks was successful.
21 Jan 2020 08:18:53 PM - PST LINE (231) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (234) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (239) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (240) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (242) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (243) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (244) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (245) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (246) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (247) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (248) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (249) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (250) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (258) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (259) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (260) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (261) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (262) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (263) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (264) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (267) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (268) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (269) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (270) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (271) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (276) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (280) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (281) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (282) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (290) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (291) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (292) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (294) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (295) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (296) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (297) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (298) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (299) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (300) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (301) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (302) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (303) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (304) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (305) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (306) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (307) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (310) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (311) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (315) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (316) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (317) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (318) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (319) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (322) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (330) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (331) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (332) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (333) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (335) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (337) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (338) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (339) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (340) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (341) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (342) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (343) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (344) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (345) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (346) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (349) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (350) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (351) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (352) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (355) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (357) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (358) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (359) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (362) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (363) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (365) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (366) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (367) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (368) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (369) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (371) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (372) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (375) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (376) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (377) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (378) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (379) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (380) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (381) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (382) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (383) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (386) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (387) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (388) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (389) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (390) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (391) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (392) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (393) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (395) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (396) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (397) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (400) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (403) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (404) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (405) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (406) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (407) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (408) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (409) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (410) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (413) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (414) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (415) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (416) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (417) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (418) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (419) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (420) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (431) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (432) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (433) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (434) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (435) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (444) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (445) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (446) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (447) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (448) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (449) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (450) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (453) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (454) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (455) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (456) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (459) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (460) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (461) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (462) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (465) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (466) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (467) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (468) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (469) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (470) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (471) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (472) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (473) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (474) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (482) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (483) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (484) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (485) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (486) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (487) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (496) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (497) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (498) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (499) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (500) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (501) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (506) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (507) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (508) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (509) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (514) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (515) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (516) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (521) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (522) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (523) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (528) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (529) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (530) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (531) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (536) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (537) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (538) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (539) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (540) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (541) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (542) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (543) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (544) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (545) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (546) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (547) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (548) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (549) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (550) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (551) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (552) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (557) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (558) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (559) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (565) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (566) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (567) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (568) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (574) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (576) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (577) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (582) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (583) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (584) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (585) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (593) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (594) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (595) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (596) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (597) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (605) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (606) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (607) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (608) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (609) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (610) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (611) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (612) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (613) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (614) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (615) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (616) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (617) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (618) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (619) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (620) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (621) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (622) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (623) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (624) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (625) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (630) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (634) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (635) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (636) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (672) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (673) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (674) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (675) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (676) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (677) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (678) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (679) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (680) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (681) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (682) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (683) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (684) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (685) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (690) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (691) - The formula is attempting to divide by zero, , Calculation returned zero
21 Jan 2020 08:18:53 PM - PST LINE (692) - The formula is attempti
blah, blah, blah.
then the post:
( P# , REV )
O0000
( COMPANY )
( TEMP1 )
( JAN. / 21 / 2020 )
( X ZERO )
( Y ZERO )
( Z ZERO )
( PART USING )
( STOP ON  SIDE )
( PROGRAM WRITTEN BY DERYCK )
( PART RAN ON FADAL )
/ G91 G28 Z0.
/ G28 X0. Y0.
/ G92 X10. Y10. Z10.
N1 ( 1/2" CAR E/MILL ,.5 DIA )
G91 G28 Z0.
T1
M6
T2
G0 G40 G90 X-3.0345 Y2.1113 S2069 M3
G43 H1 Z1. M8
Z.1
G1 Z-.5 F.00483
Y1.8613
X-2.7845
X2.7845
G2 X3.0345 Y1.6113 I0. J-.25
G1 Y-1.6113
G2 X2.7845 Y-1.8613 I-.25 J0.
G1 X-2.7845
G2 X-3.0345 Y-1.6113 I0. J.25
G1 Y1.6113
Y1.8613
X-3.2845
G0 Z1.
M9
G91 G28 Z0. M5
M1
N2 ( 1/2"-13 HSS SPP C/TAP ,.5 DIA )
G91 G28 Z0.
T2
M6
T1
G0 G40 G90 X-2.7845 Y1.6113 S100 M3
G43 H2 Z1.
M29
G84 Z-.5 R.1 F7.6923
G80
G91 G28 Z0. M5
G91 G28 Y0.
the endmill feedrate looks good, but the tap is still in ipm.
should say, using 2018, with a modified default mill post.
fs 44  0.5
To this:
If he doesn't have 44 defined in his post then he should define that corect?
That is the control for rigid tap feed as pitch yes/no.
Go and look at the post lines that are showing an error. You will need to get those cleaned up to really know what's going on.
The 'feed' variable is used elsewhere in the Post, so using a Global Variable (formula), like I showed, really won't work in this case.
You would have to modify 'pfcalc' or wherever the Feed variable is set.
(Don't use the Global Variable Formula that I initially showed...)
ptap$            #Canned Tap Cycle
      pdrlcommonb
      result = newfs(17, feed)        # this reformat statement could be messing it up
      if met_tool$,
        if toolismetric, pitch = n_tap_thds$
        else, pitch = (1/n_tap_thds$) * 25.4
      else,
        if toolismetric, pitch = n_tap_thds$ * (1/25.4)
        else, pitch = 1/n_tap_thds$
      pitch = pitch * speed           # this section is def forcing ipm, comment this line out
      pbld, n$, sg94, e$              # since you don't use G94/95, comment this line out
      pcan1, pbld, n$, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout,
        prdrlout, *pitch, !feed, strcantext, e$
      pcom_movea
If your ptap$ section looks like this, try making the commented modifications and run it again. I'm guessing all the post warnings you got were from the global calculation running with a null spindle speed. The !feed can probably go tho.
i gotta get this working, today had a bigger program, just a pain to have to change all the feedrates all the time.
Quote
Quote
      pdrlcommonb
      if met_tool$,
      else,
      pcom_movea
That logic isn't the best (I'm aware it came from a generic); In Mastercam 2019 and beyond toolismetric will never be true.  Beside that, using the tap_pitch$ variable will half the amount of code in that postblock.
OP, have you contacted your reseller?  If you need this in a hurry I think that would be your best bet.
23 hours ago, Grimes said:
( COMPANY )
( TEMP1 )
( X ZERO )
( Y ZERO )
( Z ZERO )
( PART USING )
( STOP ON  SIDE )
/ G91 G28 Z0.
/ G28 X0. Y0.
G91 G28 Z0.
T1
M6
T2
G43 H1 Z1. M8
Z.1
G1 Z-.5 F.00483
Y1.8613
X-2.7845
X2.7845
G1 Y-1.6113
G1 X-2.7845
G1 Y1.6113
Y1.8613
X-3.2845
G0 Z1.
M9
G91 G28 Z0. M5
M1
G91 G28 Z0.
T2
M6
T1
G43 H2 Z1.
M29
G80
G91 G28 Z0. M5
G91 G28 Y0.
whats going on now, think i corrupted something, there are those three block delete lines before the first tool and my home position isnt getting posted wtf? tried with all my posts same thing.
ya ive been messing around with this for a while, trying to contact the companys reseller might be my best bet, im just not exactly a big wheel in the company. but maybe talk to my supervisor tomorrow.
so if my company bought the licenses, is it free to ask for a custom post or does it cost the company money. if it comes with the license might be a better sell for me.
I pulled the section from the 2018 fanuc generic, do the newer ones no longer force IPM tap output?
And usually, you have to pay for the post. But, you can still sell it pretty easily on the time saving of not having to edit posted code anymore.
the company has to pay for it, damn i doubt they would do it, they should give you one custom post with each license at least.
you should put it in the budget when you buy the machine,
the cost of a post is nothing in the long run,
log how much time you waste editing programs and multiply that by your shop rate and see how fast it pays for itself
I feel your pain I really do. I got started with Mastercam in the V9 days. I went and worked in a shop that had V7 and then I got them to upgrade to V9.They had bought a 3rd Party Post from the the Machine Tool builder they bought the machine from. The Machine Builder had their own MP.DLL and everything. Problem was the post was terrible and support was weeks for a 2 minute issue. I called our dealer and he said that CNC Software just released the Generic 5 Axis Post and I was more than welcome to play with it. The dealer even got me the 5 Axis Power Point. Within about 2 weeks I had a majority of what I wanted and needed done for that machine. I was cutting some molds that ran for 170 hours with no hand edits or Verification Software on a 5 Axis Router that had a 4' x 8' table. I normally ran 30-50 hour programs cutting different molds in 3+2 and full 5 axis back then again with no Verification and no Moduleworks 5 Axis toolpaths. The company had spent good money on a post and paid good money for maintenance on that post, but at the time that company NOT the Mastercam Dealer or CNC Software were involved was not meeting our needs and work had to be done. I since then will tinker with posts to things that are format or little things, but leave the more integrated or complicated things to the professionals that do this for a living.
There are a lot of different posts on the tech exchange and other things if you stuck and must do what your company is not willing to do. I wrote complete probing logic for machines and custom drill cycles and many other things over the years. I might could sit down and from scratch in 10-12 months figure out how to write a MP post, but since no one is going to pay me for it I will not. I trust the companies doing it and will work with them to help all parties involved. Keep asking question keep putting your best foot forward showing people on the forum you're giving it your all and people will help you figure out what you need, but thinking someone is going to give you the keys to the castle without some work on your side isn't how it works around here.
oh, dont think im giving up on this. this could work for all the mazaks in the plant. i could probably find a way to squeeze it into the post. just thought it would be easier, like you find the feed variable, and a a line like feed = feed / speed. but not as easy as i had hoped.  ive actually got my post for the mazak finished, didnt take much just the feed thing is killing me.
thats cool youve been working on 5 axis machines that long, thats my goal. to find a shop that has one or some. as of right now ive never even seen one in real life just on youtube.
I would strongly recommend looking at MPmaster to build your post from. That has a lot of the .set stuff built into along with other things that the Generic Mastercam posts lack IMHO. There is supposed to be a new generation of Mastercam stuff coming, but so far it is limited to one Router post.
Can you upload the post?  I'm not an expert but I think I can point you in the right direction.
ya getting late tonight but tomorrow will figure out how to upload it, just dont laugh, at it because it works, but i am completetly self taught with it.
Here is how I solved it for our HCN4000.
define your own variable and format it:  -->  fmt  "F" 13 thdlead
Create a routine to convert ipm to ipr:
p_whichfeed    # ipm to ipr for tap cycle
               if drillcyc$ = 3,
                thdlead = 1 / n_tap_thds$
                thdlead
                else,
                *fr$
find where the F7.6923  is being output from , (perhaps ptap$ ?)
if so,
Substitute 'p_whichfeed' for '*pitch' in ptap$
      pdrlcommonb
       pitch = 1 / n_tap_thds$    #added 7/2/07  ADDED Peck Tapping option -09/05/2018, jmp
          result = newfs(17, feed)  # Set for tapping Feedrate format
      pcan1, pbld, n$, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout, [if peck1$ > 0, *peck1$],
        prdrlout, *pitch, !feed, strcantext, e$  # changed  from *feed  to *pitch, !feed  7/2/07
      pcom_movea
How I handle our Mazak's, all 41 of them
gotta be for every feedrate though, do your mazaks run a G1 in ipm? i think all of ours run fpr on all feed rates. so if i use like 50 ipm on the plunge, then a 10 ipm feed thats a lot of changes and a pita, i use find and replace in ncplot. but still a bit more work. if it cant be done it cant be done, havent been on that machine i a week so it hasnt been a problem. thanks all as always.
