Sign in to follow this
Leon82
Is it possible to change the letter for position in a certain drill cycle?
In a certain probe (drill) cycle I need I & J output for x and y position, respectively.
Currently I use misc drill parameters.
I and j are the x y points for a z measurement.
The problem is if you want to chain a large amount of points you have to edit those two parameters for each point.whereas if I can get it to just output the point position it with I and j it would save a lot of time.
I played around quick and it gave me a duplicate format statement error.
Typically I create a global alias for the variable and format it, but you can also use the new address function nwadrs( ); just remember to set the format back after output.
Can you tie a condition to mi$, mr$, canned text, a drill parameter or custom drill parameters?
Edit: Nevermind, I missed that or already doing that. Try adding a condition that will reinitialize it until your done with the probing.  I'm done for the weekend and I don't have my post at home.
Try searching here for pmachine and you will see a different example but it will show the process.
I can use the p common drill b post block to set it .
there's actually an example in there I can follow so maybe I'll try that when I get some time.
You can use the 'nwadrs' function to assign a different 'prefix' character to any variable output.
     result = nwadrs(xabs, "I")
     result = nwadrs(yabs, "J")
But you have to remember to set them back to the original prefix, after you have finished the output. (I would do this in 'pcanceldc$' Post Block.)
Awesome thank you!
It worked, but I had to put it like this to prevent it from yelling at me when I posted it
result = nwadrs( "I", xabs)
Yes, getting the parameter order correct helps. I was going from memory...
  • Haha 1
