Sign in to follow this
medaq
post adding B rotation in sub
Trying to use a post that was rock solid for outputting sub routines for an older machine. And now it is adding a B0. to any sub that is in a rotation other than 0. So the subs at 0 are not getting this, but say B90. is putting a B0. at the begining.  I did the post debug and took a screen shot of the affected area. It is showing in the 'pcout' I highlighted the line in the picture. Not sure what to modify to remove the wrong B axis rotation.
T5 M06 ( 1/8 FLAT ENDMILL)
(MAX - Z.6)
(MIN - Z.28)
G00 G17 G90 G55 X.1874 Y-1.0766 S10000 M03
B90.
G49
G94
G05.1 Q1
G43 H5 Z.6 M08
M98 P4001
G90 X.1874 Y-3.8416
M98 P4001
G90 X.1874 Y-6.6066
M98 P4001
G90 X.1874 Y-9.3716
M98 P4001
G05.1 Q0
M05
G91 G28 Z0. M09
G28 X0. Y0.
G28 B0.
G00G90G49G80G40
G90
/3 M0
O4001
G91
Z-.1508 B0.
In the subprogram block is it forcing output?
I honestly dont know, and can not figure out which call is calling the actual b rotation. Here is all the out and sub section.
pfxout          #Force X axis output
      if absinc$ = zero, *xabs, !xinc
      else, *xinc, !xabs
pxout           #X output
      if absinc$ = zero, xabs, !xinc
      else, xinc, !xabs
pfyout          #Force Y axis output
      if absinc$ = zero, *yabs, !yinc
      else, *yinc, !yabs
pyout           #Y output
      if absinc$ = zero, yabs, !yinc
      else, yinc, !yabs
pfzout          #Force Z axis output
      if absinc$ = zero, *zabs, !zinc
      else, *zinc, !zabs
pzout           #Z output
      if absinc$ = zero, zabs, !zinc
      else, zinc, !zabs
pfcout          #Force C axis output
      if index = zero & rot_on_x,
        if use_rotmcode & (fmtrnd(cabs) <> fmtrnd(prv_cabs) | sof), *sindx_mc
        if absinc$ = zero, *cabs, !cinc, !cout_i
        else, *cout_i, !cinc, !cabs
pcout           #C axis output
        if use_rotmcode & fmtrnd(cabs) <> fmtrnd(prv_cabs), *sindx_mc
        if absinc$ = zero, cabs, !cinc, !cout_i
        else, cout_i, !cinc, !cabs
psub_call_m$     #Call to main level, single tool
      psub_call_trans
psub_call_mm$    #Call to main level, multiple tools
      psub_call_trans
psub_call_trans #Translate level calls from toolchange, user
      if wcstype <= one, result = mprint(shomeserror)
      sav_absinc = absinc$
      #pindex                    #Removed this as rotary should already be in position.  This gives redundant WCS output. WBT
      #Mirror or Rotate Coord's
      if sub_trnstyp$ = zero | (sub_trnstyp$ = one & mr_rt_actv),
        #The original pattern is not mirrored or rotated
        if sub_sec_no$,
          absinc$ = zero
          if sub_trnstyp$, psub_rotate
          else, psub_mirror
        mr_rt_actv = three
      else, #Translate
        if sub_mny_t$,
          if wcstype > one, absinc$ = zero
          if lock_codes = one & not(index) & rot_on_x, pbld, n$, *sunlock, sunlockcomm, e$
          pbld, n$, *sgcode, *sgabsinc, [if not(index), pwcs], pfxout, pfyout, pfzout,
            pfcout , e$# jim added * to pfcout
          if lock_codes = one & not(index) & rot_on_x & cuttype = 0, pbld, n$, *slock, slockcomm, e$
          pe_inc_calc
          ps_inc_calc
      absinc$ = sav_absinc
      result = nwadrs(strp, main_prg_no$)
      main_prg_no$ = main_prg_no$ + sav_progno #Add sub number offset
      if sav_progno = main_prg_no$, result = mprint(sprgnerror)
      pbld, n$, "M98", *main_prg_no$, e$
      prv_feed = c9k #Force feed in sub
psub_mirror     #Mirror start code, user
      #Mirror Y axis
      if sub_trnmthd$, pbld, n$, *sgabsinc, strns_mir_on, *sub_trnsx$, e$
      #Mirror X axis
      else, pbld, n$, *sgabsinc, strns_mir_on, *sub_trnsy$, e$
psub_rotate     #Rotate start code, user
      pbld, n$, *sgcode, *sgabsinc, strns_rot_on, *sub_trnsx$, *sub_trnsy$,
        [absinc$ = one], *sgabsinc, *rt_cinc, e$
psub_st_m$       #Header in main level
      result = nwadrs(stro, main_prg_no$)
      *e$
      *main_prg_no$, e$
      spaces$ = 0
      if scomm_sav <> snull, scomm_str, *scomm_sav, scomm_end, e$
      spaces$ = sav_spc
      #G51/G68 requires absolute position on first move
      if mr_rt_actv & absinc$ = one,
        absinc$ = zero
        prv_absinc$ = m_one
        prv_xabs = m_one
        prv_yabs = m_one
      else, pbld, n$, sgabsinc, e$
psub_end_m$      #End in main level
      n$, "M99", e$
      prv_absinc$ =   -1
      #Reset update variables for subs at main level
      #Mirror or Rotate cancel, output is forced
      if (sub_trnstyp$ = zero & esub_sec_no$ > zero)
        | (sub_trnstyp$ = one & esub_sec_no$ = esub_totl_no$-one
        & sub_trnmthd$ = two),
        subout$ = zero
        no_nc_out$ = m_one
        #Mirror cancel
        if sub_trnstyp$ = zero,
          absinc$ = zero
          pbld, n$, *sgabsinc, strns_mir_off, *sub_trnsx$, *sub_trnsy$, e$
        else, #Rotate cancel
          pbld, n$, strns_rot_off, e$
        no_nc_out$ = zero
      end_sub_mny = sub_mny_t$
Look in your tool change blocks...
make sure the pindex and pcout or pfcout are called before
c_msng$
That position output without digging deeper looks to be coming from plinout, which you should only be in after the c_msng$ being invoked
Can I ask a dumb question? Are you sure your planes are defined correctly for the source operations? Have you posted the operation without subs and all the rotations are correct?
c_msng$
Not sure this helps in diagnosing this?
plinout         #Output to NC of linear movement - feed
      pcan1, pbld, n$, sgfeed, sgplane, `sgcode, sgabsinc, pccdia,
        pxout, pyout, pzout, pcout, `feed, strcantext, scoolant, e$
They are defined correctly, and am modifying an old program that used to post fine. When taking off the subroutine check in transform and just post it long code, it posts fine.
(MAX - Z.6)
(MIN - Z.28)
B90.
G49
G94
G05.1 Q1
G43 H5 Z.6 M08
Z.4492
G01 Z.4442 F50.
(MAX - Z.6)
(MIN - Z.28)
B90.
G49
G94
G05.1 Q1
G43 H5 Z.6 M08
Z.4492
G01 Z.4442 F50.
Sorry can't offer anything more you're getting deep into post issues and afraid you may have to get the professionals involved.
