csharp and python-scripts-for-mastercam
McCSharp.dll Add-In -> A c# scripting extension for Mastercam. Merge the contents of the McCSharp folder with your Mastercam folder to install.
McCSharp.zip
There was a missing file in the first .zip file.
McCSharp.zip
//C# script example
//OpenMastercamPartFolder.cs
//reference nethook_3
#r"C:/Program Files/Mcam2020/chooks/NETHook3_0.dll"
//get the current filename
var ret = System.IO.Directory.GetParent(Mastercam.IO.FileManager.CurrentFileName);
//write the current file name to mastercams event logger
Mastercam.IO.EventManager.LogEvent(Mastercam.IO.Types.MessageSeverityType.InformationalMessage,"",Mastercam.IO.FileManager.CurrentFileName);
//open the folder containing the current mastercam file in windows explorer
System.Diagnostics.Process.Start(ret.FullName);
//C# script example
//VerifyOperationsByToolNumber.cs
//get a list of the nethook supported lists in mastercam
var List = Mastercam.Support.SearchManager.GetOperations();
//loop through the list of operations
foreach(var operation in List)
//if the operation type is not nesting
if (operation.Type.ToString() != "Nesting")
         //get the operations toolnumber
         var tlnum = operation.OperationTool.Number;
         //write the tool number to mastercams event logger
         Mastercam.IO.EventManager.LogEvent(Mastercam.IO.Types.MessageSeverityType.InformationalMessage,""," ToolNumber : " + tlnum.ToString());
         if(tlnum > 0 )
         if(tlnum < 100)
         //if the operations tool number is less than 100 set it unselected
         operation.SetSelectedState(false);
         if(tlnum > 100)
         if(tlnum < 200)
         //if the operations tool number is less than 200 and greater than 100 set it selected
         operation.SetSelectedState(true);
         if(tlnum < 300)
         if(tlnum > 200)
         //if the operations tool number is less than 300 and greater than 200 set it selected
//verify the selected operations
Mastercam.Support.ExternalAppsManager.RunFTCommand("OMverifySelectedOperations");
Added some example scripts of calling functions from mastercams list of ft functions, New skinny user interface can be used as a sidebar to call functions while you program.
McCSharp.zip
Please note you will have to manually set the path in your script file to the nethook3_0.dll file for your version of mastercam
It probably needs to be recompiled..
Let me check for those files
CsScriptmenu.dll.zip
I compiled this aginst 2022 beta pb2, it should run on every Mastercam that has Nethook3_0.dll
