Dynamic Mill won't generate toolpaths for SOME letters
Hi all,
I'm using the Dynamic Mill operation to cut letters into the surface of a piece of acrylic. Some of the letters are not having toolpaths generated. I've attempted to re-chain those letters, tried putting them into a separate operation, but nothing seems to work. It's not always the same letter either. For example, I need to cut the word "electronics", but only one of the "c"s doesn't generate. In another instance I need to cut the letters "ETG" and the "G" won't generate.
Unfortunately, the file is too large for me to upload here (even as a ZIP folder, jeez), so I'll gladly email it to you if you contact me at [email protected]. Any help would be greatly appreciated. Thanks.
I'm so dumb, I realized I don't need to upload the file. I can just upload it to Google Drive and share the link. https://drive.google.com/file/d/1MDPpLLsjuJRh1h3vRi5LlR03L3S65VDY/view?usp=sharing
As a warning, the file is oddly large and may cause MasterCAM to act sluggish. I didn't create the file, so I don't know why it's like that. I'm just in charge of CAM'ing it.
Also, here's a screen shot of the ETG where the G won't generate.
In the parameters page there is a minimum maximum radius setting you would need to adjust.
It looks like this geometry was created from a solid model.  If you could gain access to that model, you could just select the floor surfaces for the machining regions and be done.
On 3/17/2020 at 7:47 PM, Val J said:
you could create splines on the curved areas, it will take some time but give much better results
If you can't get the solid model, then creating splines is a good option.  Set the Cplane to 2d.
