Sign in to follow this
navsENG
Arc Filter on helical entry
One thing I dont like about these "newer" toolpaths, is that on a helical entry I always get point to point code..
Even if I go into the filter tolerance, bump it up to a few thou (for roughing) , and enable the line/arc filter settings. This will greatly simplify the code, but it never seems to fix the ramp in. That can add a lot to the size of the code / toolpath..
Am I missing something?
Bottom right corner of the Filter page?
The 3D arc on switch ?
I think this is the switch you are looking for
One thing to keep in mind.. you cannot get 3D arc entry output on the newer 5 axis hole toolpaths.
They do not output the necessary NCI code
This switch should work for most other toolpaths
Wow, I feel stupid right now...
Thanks gcode, that helps me also..
You also need to make sure you have helix support turned on in your Control Definition
  • Thanks 2
I can't remember which, but there is another toolpath that, for some reason wont output entry helixes, only point to point, even with the arc entry turned on.
All planes supported needs to be actvie in that picture. The output above should only support X-Y and not X-Y-Z thus nulling out Helix entry arc output.
This should work fine in a standard 3X milling operation. the circular motion is in the XY plane.. the helix motion is along the Z axis
I think for me this has been the issue, in the control definition...
Thanks !
