edit mastercam post to move a gcode line when post out
Hello,
I edit the post for lathe threading, but when I post out, the threading line is on the top. I can't find the way to move it below the M8 line. see sample below
 THREAD 1 L0.0500 H0.0310 S0.0040 0.0010 0.0020 #3 C0.0500 Z0.0000 -0.4800 D0.0940 0.0940 30
RAPID ABS X5.0000 Z5.0000
 TLCHG I20 T20 20
SETRPM S0200
RAPID ABS X0.3500 Z1.0152
AUXFUN M8
AUXFUN M5
AUXFUN M9
AUXFUN M0
Please help me. thank you
2 hours ago, Taolaoday said:
Hello,
 TLCHG I20 T20 20
SETRPM S0200
AUXFUN M8
AUXFUN M5
AUXFUN M9
AUXFUN M0
Have you contacted your Reseller for help?
  • 3 weeks later...
On 3/27/2020 at 4:50 PM, Taolaoday said:
Hi Colin,
I appreciate you get back to me. please see an attached mcam file and an update post and help me out.
Thank you
Cuong
MPLEZPTH.PST
sample file for EZ Path lathe.emcam
What school do you attend? Share something with us to help us feel comfortable your not using a pirated seat of software and we will be glad to assist.
I worked for MIT, screen shot of license attached but let me know if you need more proof of the license I am more than happy to provide it. Thank you very much for your help
No need to edit the post. Just add a point toolpath before the Threading operation as a ref check and the toolpath will output correctly.
 EZPATH|SX 0000 MODE|INCH MON APR 20 09:15:00 1920
RAPID ABS X-0.3936 Z0.0000
 TLCHG I20 T20 20
SETRPM S2000
RAPID ABS X-0.0079 Z0.0000
AUXFUN M8
RAPID ABS X-8.0000 Z8.0000
 TLCHG I20 T20 20
SETRPM S0400
RAPID ABS X-0.2900 Z0.2095
AUXFUN M8
 THREAD 1 L0.0500 H0.0300 S0.0100 0.0010 0.0020 #3 C0.0500 Z0.0000 -0.4000 D0.0950 0.0950
 TLCHG I20 T20 20
SETRPM S0260
RAPID ABS X-0.5400 Z-0.4534
AUXFUN M8
 THREAD 1 L0.0769 H0.0560 S0.0100 0.0010 0.0020 #3 C0.0500 Z-0.5000 -0.9000 D0.1940 0.1940
AUXFUN M5
AUXFUN M9
AUXFUN M0
So, you "worked for" MIT (past tense?), and you are currently using a VPN Tunnel to access their NetHasp?
This seems a little fishy. If you were working for MIT, I know for a fact that the Educational Division of CNC Software would be willing to help edit your Post, so that the school's machine would be running with Mastercam.
It seems in your case, that you are using the MIT license, while trying to setup and program a machine that is not a school resource. I'm not trying to accuse you here, I'm just pointing out some red flags that I see.
If that isn't correct - if the machine you are programming for is actually an asset of MIT and you are doing work for the school programs - then I would be happy to assist with your Post issues. However, if you are using the school's educational resources to support a separate commercial endeavor, then you would need to purchase an industrial license of the Mastercam software, and would need to get Post Processor Support from your industrial Mastercam Reseller.
If you are indeed legitimately working on school projects, then I would suggest contacting: [email protected] and explaining your situation. They would absolutely be able to assist an legitimate request for help from a school. But the burden would be on you to prove that you are working on educational, not commercial, projects.
 TLCHG I20 T20 20
SETRPM S2000
AUXFUN M8
 TLCHG I20 T20 20
SETRPM S0400
AUXFUN M8
 TLCHG I20 T20 20
SETRPM S0260
AUXFUN M8
AUXFUN M5
AUXFUN M9
AUXFUN M0
Thank you very much . have a good day .
I expect if there was an issue here the moderators would have flagged it right away, since he provided an mcx file.
Correction: I am working for MIT.
If I am no longer work at MIT, I can not log in to MIT's VPN to access Mastercam license. .
Thank you for your suggestion and Have a good day!
Still doesn't answer the question of is what he is working on actually supporting MIT (given MITs direct access to masteram corporate) or a supplemental income stream for himself, which question seems to have been evaded.
 Hello 5th Axis CGI,
thank you very much for your help. but instead of add another toolpath before a threading toolpath, open threading tothpath parameters, check the box "ref point" and gcode post out correctly too. without your help, I never though of this option. I greatly appreciate your help.
1 hour ago, Taolaoday said:
 Hello 5th Axis CGI,
Yes better way to handle it.
