Sign in to follow this
content creator
Write NCI Data To Operations Comment Section
Hi here is my latest project scanning the nci file and operation/tool then writing some information to the comment section.
Here we are renaming the operation posting the nci data reading it  then deleting the file and restoring the operations name.
Optional error report at the end
#include "StdAfx.h"
// <copyright file="AiOperationCommentInfo.cpp">
// Copyright (c) 2020 Peter Evans, Inc. All rights reserved.
// </copyright>
// <summary>Write information from the operation to the comments section</summary>
////start of StringManipulation header/////
namespace StringManipulation
	System::Int32^ stringtoint(System::String ^ numberStr);
	System::Double^ stringtodouble(System::String ^ numberStr);
	System::String ^ ConvertStringArrayToStringJoin(array<System::String^>^ array);
	System::String ^ GetAfter(System::String ^ strSource, System::String ^ toBeSearched);
	System::String ^ GetBefore(System::String ^ strSource, System::String ^ toBeSearched);
	System::String ^ GetStringAfter(long count, System::String ^ input, System::String ^ text);
////end of StringManipulation header/////
////start of FileManagerUtilities header/////
namespace FileManagerUtilities
	public ref struct TargetFile
		System::String ^ pathtofile;
		System::String ^ filename;
		System::Int32 ^ index;
	public ref class FileInformation
	public:
		FileInformation();
		~FileInformation();
		//System::String^ GetCurrentFileName();
		array<System::String^>^ GetAllLinesFromFileToArray(System::String^ filepath);
		array<System::String^>^ SplitLineWhiteSpace(System::String ^ line);
		array<System::String^>^ FilePathList(System::String ^ filepathtodirectory, System::String ^ fileextention);
		array<TargetFile^>^ GetTargetFileArray(array<System::String^>^ StringArray);
	private:
////end of FileManagerUtilities header/////
////start of StringManipulation funtions/////
System::Int32^ StringManipulation::stringtoint(System::String ^ numberStr)
	auto number = gcnew System::Int32;
	bool isParsable = System::Int32::TryParse(numberStr, *number);
	return isParsable ? number : nullptr;
System::Double^ StringManipulation::stringtodouble(System::String ^ numberStr)
	auto number = gcnew System::Double;// ^ number;// = gcnew double;
	bool isParsable = System::Double::TryParse(numberStr, *number);
System::String^ StringManipulation::ConvertStringArrayToStringJoin(array<System::String^>^ array)
	// Use string Join to concatenate the string elements.
	auto result = System::String::Join(".", array);
	return result;
System::String^ GetBetween(System::String^ strSource, System::String^ strStart, System::String^ strEnd)
	if (strSource != nullptr && strStart != nullptr && strEnd != nullptr)
		int Start, End;
		if (strSource->Contains(strStart) && strSource->Contains(strEnd))
			Start = strSource->IndexOf(strStart, 0) + strStart->Length;
			End = strSource->IndexOf(strEnd, Start);
			return strSource->Substring(Start, End - Start);
	return nullptr;
//in string 1 > initial string to be searched
//in string 2 > the value to search for
//returns new string found after first instance of initial string
System::String^  StringManipulation::GetAfter(System::String^  strSource, System::String^  toBeSearched)
	int ix = strSource->IndexOf(toBeSearched, System::StringComparison::InvariantCultureIgnoreCase);
	if (ix != -1)
		System::String^ code = strSource->Substring(ix + toBeSearched->Length);
		return code;
	return nullptr;
System::String^  StringManipulation::GetBefore(System::String^  strSource, System::String^  toBeSearched)
	if (ix != -1)
		System::String^ code = strSource->Substring(0, ix);
		return code;
	return nullptr;
System::String ^ StringManipulation::GetStringAfter(long count, System::String ^ input, System::String ^ text)
	System::String ^ code = GetAfter(text, input);
	if (code != nullptr)
		count = count + 1;
		code = code->Trim();
		code = code->IndexOf(" ") > -1
			? code->Substring(0, code->IndexOf(" "))
			: code;
		return code;
	return nullptr;
////end of StringManipulation functions/////
////start of WinformsUI header/////
//////////the funtions headers used in our user interface
//gets a listview from the supplied windows form control
//in : int x, int y, System::Windows::Forms::Control ^ control
//returns : System::Windows::Forms::ListView^
System::Windows::Forms::ListView^ GetListViewFromPoint(int x, int y, System::Windows::Forms::Control ^ control);
//gets a textbox from the supplied windows form control
//System::Windows::Forms::Control ^ control in : int x int y
//returns : System::Windows::Forms::Control ^
System::Windows::Forms::Control ^ GetTextboxControlFromPoint(System::Windows::Forms::Control ^ control, int x, int y);
void SetMinMaxValueToList(System::Collections::Generic::List<double> ^ zdepthvaluelist, double &MinZValue, double &MaxZValue);
array<array<System::String^>^>^ GetArrayofArrayOfLinesFromFile(System::Windows::Forms::ListView::ListViewItemCollection ^ itemlist, System::String ^ pathtofiles, System::String ^ extention);
//The signature of Button click event handler is listed in the following code snippet.
//click event to write the quantity of parts to be nested to the user interface data label
//in : System::Object ^ sender, System::EventArgs ^ e
void GetMinMaxValueToList(System::String ^ negativezval, System::Collections::Generic::List<double> ^ zdepthvaluelist, System::String ^ positivezval);
//creates a listview on the supplied windows form
//in : int Left  int Top int Width int Height System::Windows::Forms::Form ^ Form int mainlistitem
System::Windows::Forms::ListView ^ CreateListViewOnWinform(int Left, int Top, int Width, int Height, System::Windows::Forms::Form ^ Form, int mainlistitem);
//creates a textbos on the supplied windows form
System::Windows::Forms::TextBox ^ CreateTextboxOnWinform(int Left4, int Top4, int Width4, int Height4, System::Windows::Forms::Form ^ Form);
//creates a button on the supplied windows form
//in : int Left, int Top, int Width, int Height,
//in : System::String ^ buttonname, System::String ^ buttonname2, System::Windows::Forms::Form ^ Form,
//in : void(*funtioninput)(System::Object ^ sender, System::EventArgs ^ e)
System::Windows::Forms::Button ^ CreateButtonOnForm(int buttonleft, int buttontop, int buttonwidth, int buttonheight, System::String ^ buttonname, System::String ^ buttonname2, System::Windows::Forms::Form ^ Form, void(*funtioninput)(System::Object ^ sender, System::EventArgs ^ e));
//creates a label on the supplied windows form
System::Windows::Forms::Label ^ CreateLabelOnForm(int labelleft, int labeltop, int labelwidth, int labelheight, System::String ^ labelmessage, System::Windows::Forms::Form ^ Form);
//////////end of funtions region
////end of WinformsUI header/////
////start of WinformsUI functions/////
void WriteLinesToTextFileDeleteIfExisting(array<System::String^>^ StringArray, System::String^ Path)
	//if (System::IO::File::Exists(Path))
	//	System::IO::File::Delete(Path);
	System::IO::StreamWriter ^ sw = gcnew System::IO::StreamWriter(Path);
	sw->WriteLine("Nc File Report");
	for (auto i = 0; i < StringArray->Length; i++)
		sw->WriteLine(StringArray[i]);
	sw->Close();
//////////the funtions used in our user interface
public ref struct NcDataReaderParams
	System::String ^ NcFilenamePrefix;
	System::String ^ StockThicknessPrefix;
	System::String ^ DateAndTimePrefix;
	System::String ^ PathToNcFileFolder;
	System::String ^ PathToOutputFolder;
NcDataReaderParams ^ GetNcDataReaderParams(System::String ^ pathtofiles, System::String ^ filename, System::String ^ extention)
	auto params = gcnew NcDataReaderParams;
	if (System::IO::Directory::Exists(pathtofiles))
		auto parameterlist = gcnew System::Collections::Generic::List<System::String ^>;
		FileManagerUtilities::FileInformation fileinformation;
		auto listoffiles = fileinformation.FilePathList(pathtofiles, extention);
		for (auto i = 0; i < listoffiles->Length; i++)
			if (System::IO::Path::GetFileName(listoffiles[i]) == filename) {
				auto lines = System::IO::File::ReadAllLines(listoffiles[i]);
				for (auto j = 0; j < lines->Length; j++)
					parameterlist->Add(lines[j]);
				auto parameterarray = parameterlist->ToArray();
				if (parameterarray->Length == 5)
					for (auto j = 0; j < parameterarray->Length; j++)
						switch (j)
						case 0:
							params->NcFilenamePrefix = parameterarray[j];
						case 1:
							params->StockThicknessPrefix = parameterarray[j];
						case 2:
							params->DateAndTimePrefix = parameterarray[j];
						case 3:
							params->PathToNcFileFolder = parameterarray[j];
						case 4:
							params->PathToOutputFolder = parameterarray[j];
	return params;
System::Windows::Forms::TextBox ^ CreateTextboxOnWinform(int Left, int Top, int Width, int Height, System::Windows::Forms::Form ^ Form)
	System::Windows::Forms::TextBox ^ txtbox = gcnew System::Windows::Forms::TextBox;
	txtbox->Left = Left;
	txtbox->Top = Top;
	txtbox->Width = Width;
	txtbox->Height = Height;
	txtbox->Text = "";
	txtbox->BackColor = System::Drawing::Color::Black;
	txtbox->ForeColor = System::Drawing::Color::White;
	return txtbox;
	System::Windows::Forms::Button ^ button = gcnew System::Windows::Forms::Button;
	button->Left = buttonleft;
	button->Top = buttontop;
	button->Width = buttonwidth;
	button->Height = buttonheight;
	button->Name = buttonname;
	button->Text = buttonname2;
	button->BackColor = System::Drawing::Color::Black;
	button->ForeColor = System::Drawing::Color::White;
	//button->FlatStyle = System::Windows::Forms::FlatStyle::Flat;
	//add event handler to the button //function below
	button->Click += gcnew System::EventHandler(funtioninput);
	return button;
	System::Windows::Forms::Label ^ label = gcnew System::Windows::Forms::Label;
	label->Left = labelleft;
	label->Top = labeltop;
	label->Width = labelwidth;
	label->Height = labelheight;
	label->Text = labelmessage;
	label->BackColor = System::Drawing::Color::Black;
	label->ForeColor = System::Drawing::Color::White;
	//label->FlatStyle = System::Windows::Forms::FlatStyle::Flat;
	return label;
	System::Windows::Forms::ListView ^ ListView1 = gcnew System::Windows::Forms::ListView;
	ListView1->Left = Left;
	ListView1->Top = Top;
	ListView1->Width = Width;
	ListView1->Height = Height;
	ListView1->BackColor = System::Drawing::Color::Black;
	ListView1->ForeColor = System::Drawing::Color::White;
	auto header = gcnew System::Windows::Forms::ColumnHeader();
	header->Text = "                            ";
	header->Name = "col1";
	header->Width = Width;
	ListView1->Columns->Add(header);
	ListView1->Scrollable = true;
	ListView1->View = System::Windows::Forms::View::Details;
	//ShowScrollBar(static_cast<HWND>(ListView1->Handle.ToPointer()), (int)SB_VERT, true)
	//Form->Controls->Add(ListView1);
	return ListView1;
	auto zdepthvaluearray = zdepthvaluelist->ToArray();
	if (zdepthvaluearray->Length > 0)
		MinZValue = zdepthvaluearray[0];
		MaxZValue = zdepthvaluearray[0];
	for (auto m = 0; m < zdepthvaluearray->Length; m++)
		if (zdepthvaluearray[m] <= MinZValue)
			MinZValue = zdepthvaluearray[m];
		if (zdepthvaluearray[m] >= MaxZValue)
			MaxZValue = zdepthvaluearray[m];
	auto listofarraysoflinesfromfile = gcnew System::Collections::Generic::List<array<System::String^>^>;
	//loop through the current listview located at the specified coordinates
	for (auto i = 0; i < itemlist->Count; i++)
		//check the items select bit if it is selected -> continue
		if (itemlist[i]->Selected == true)
				for (auto j = 0; j < listoffiles->Length; j++)
					if (System::IO::File::Exists(listoffiles[j]))
						if (System::IO::Path::GetFileName(listoffiles[j]) == itemlist[i]->Text)
							auto lines = fileinformation.GetAllLinesFromFileToArray(listoffiles[j]);
							listofarraysoflinesfromfile->Add(lines);
	return listofarraysoflinesfromfile->ToArray();
	if (negativezval != nullptr)
		auto curzval = StringManipulation::stringtodouble(negativezval);
		if (curzval != nullptr)
			zdepthvaluelist->Add(-*curzval);
	else
		if (positivezval != nullptr)
			auto curzval = StringManipulation::stringtodouble(positivezval);
				zdepthvaluelist->Add(*curzval);
	System::Drawing::Point listviewpoint;
	//define x position
	listviewpoint.X = x;
	//define y position
	listviewpoint.Y = y;
	//get the parent System::Windows::Forms::Form
	auto listviewformcontrol = control->GetChildAtPoint(listviewpoint);
	//typecast the System::Windows::Forms::Control as a textbox so we can access it
	return dynamic_cast<System::Windows::Forms::ListView^>(listviewformcontrol);
	System::Drawing::Point textpoint;
	//define x position
	textpoint.X = x;
	//define y position
	textpoint.Y = y;
	return control->GetChildAtPoint(textpoint);
////end of WinformsUI functions/////
////start of FileManagerUtilities function definitions/////
FileManagerUtilities::FileInformation::FileInformation()
FileManagerUtilities::FileInformation::~FileInformation()
array<System::String^>^ FileManagerUtilities::FileInformation::GetAllLinesFromFileToArray(System::String ^ filepath)
	return System::IO::File::Exists(filepath) ?
		System::IO::File::ReadAllLines(filepath) :
		nullptr;
array<System::String^>^ FileManagerUtilities::FileInformation::SplitLineWhiteSpace(System::String ^ line)
	return line != nullptr ? line->Split(nullptr) : nullptr;
array<System::String^>^ FileManagerUtilities::FileInformation::FilePathList(System::String ^ filepathtodirectory, System::String ^ fileextention)
	auto count = 0;
	auto filelist = gcnew System::Collections::Generic::List <System::String^>(0);
	auto files = System::IO::Directory::GetFiles(filepathtodirectory, fileextention);
	for (auto i = 0; i < files->Length; i++)
		auto fileinfo = gcnew System::IO::FileInfo(files[i]);
		if (fileinfo != nullptr &&
			files[i] != nullptr &&
			files[i] != System::String::Empty)
			filelist->Add(files[i]);
			count++;
	return count > 0 ? filelist->ToArray() : nullptr;
array<FileManagerUtilities::TargetFile^>^ FileManagerUtilities::FileInformation::GetTargetFileArray(array<System::String^>^ StringArray)
	auto targetfilelist = gcnew System::Collections::Generic::List<TargetFile ^>(0);
	auto count = 0;
		auto targetfile = gcnew TargetFile();
		targetfile->filename =
			System::IO::Path::GetFileName(StringArray[i]);
		targetfile->pathtofile = StringArray[i];
		targetfile->index = count;
		targetfilelist->Add(targetfile);
		count++;
	return count > 0 ? targetfilelist->ToArray() : nullptr;
namespace AiTools
	//get a list of all the operations in the database
	std::vector<operation *> GetListOfOperations()
		//vector to hold operations
		std::vector<operation *> ops;
		//check if we have something
		if (!TpMainOpMgr.GetMainOpList().IsEmpty())
			//loop through the list of operation
			for (auto index = 0; index < TpMainOpMgr.GetMainOpList().GetSize(); ++index)
				//get the current operation
				auto op = TpMainOpMgr.GetMainOpList()[index];
				//check if the pointer is valid
				if (op != nullptr)
					//add the operation
					ops.push_back(op);
		return ops;
	//get a list of tool assemblies from the database
	std::vector<Cnc::Tool::TlAssemblyCPtr> GetListOfTools()
		//vector to hold assemblies
		std::vector<Cnc::Tool::TlAssemblyCPtr> toolassemblies;
		if (!Cnc::Tool::GetToolSystem()->GetAssemblies().empty())
			//loop through the list of assemblies
			for (auto index = 0; index < Cnc::Tool::GetToolSystem()->GetAssemblies().size(); ++index)
				auto tool = Cnc::Tool::GetToolSystem()->GetAssemblies()[index];
				if (tool != nullptr)
					//add the current assembbly
					toolassemblies.push_back(tool);
		return toolassemblies;
	void PostOperationNci(const operation *op)
		nci_bin n;
		long long fpos = 0;
		bool succf = false;
		//post 1 operationss NCI data
		nci_manager(op->op_idn, NCIMGR_POST_ONE, &n, &fpos, &succf);
	System::String^ GetPathToNciFolder()
		//get the path to the nci data output folder
	return System::IO::Path::Combine(Mastercam::IO::SettingsManager::SharedDirectory, "Mill\\NCI\\");
#include "atlstr.h"
	public ref class Functions
	    public : void AiOperationCommentInfo()
			//create a list strings to output to our report
			auto listviewlist = gcnew System::Collections::Generic::List<System::String^>;
			//get the list of operations
			auto ops = GetListOfOperations();
			//get the list of tool assemblies
			auto toolassemblies = GetListOfTools();
			if (!ops.empty() && !toolassemblies.empty())
				//loop through the list of operations
				for (const auto op : ops)
					//loop through the list of tool assemblies
					for (const auto tool : toolassemblies)
						//find the tool that matches the operation
						if (tool->GetSlot() == op->tl.slot)
							//store the name of the operation
							CString ncioriginalname = op->cmn.nci_name;
							//create a new variable to hold the temporary operation nci name
							CString nci_name;
							//store the operation index in the variable
							nci_name.Format(_T("%sOperation %d.nci"), NCIPrefixStr(), op->op_idn);
#if C_H_VERSION >= 2100 // Mastercam 2019 or later
							//assign the new name to the operation
							_tcscpy(op->cmn.nci_name, nci_name);
#else
							sprintf(op->cmn.nci_name, _T(nci_name));
#endif
							DB_LIST_ENT_PTR ptr = nullptr; bool bsuccf;
							//rewite the operation
							operation_manager(op, OPMGR_REWRITE, &ptr, &bsuccf);
							nci_bin n;
							long long fpos = 0;
							bool succf = false;
							//post the operation
							//get the current nci filename//no need to convert from CString we know the opid
							System::String^ filename = "Operation " + op->op_idn.ToString() + ".nci";
							//get the path to mastercams NCI output directory
							auto path = System::IO::Path::Combine(System::IO::Path::Combine(Mastercam::IO::SettingsManager::UserDirectory, "Mill//NCI//"));
							//check if the path exists
							if (System::IO::Directory::Exists(path))
								//Get the list of NCI files in the output folder
								auto filearray = fileinformation.FilePathList(path, "*.nci*");
								//loop through the list of NCI files in the output folder
								for (auto i = 0; i < filearray->Length; i++)
									if (System::IO::File::Exists(filearray[i]))
										auto checkzdepthmode = false;
										if (System::IO::Path::GetFileName(filearray[i]) == filename)
											//create a new list to hold z values
											auto  zdepthvaluelist = gcnew System::Collections::Generic::List<System::Double>;
											//get an array of lines from the NCI file
											auto lines = fileinformation.GetAllLinesFromFileToArray(filearray[i]);
											//loop through the lines
												//get an array of substrings from each line
												auto substrings = fileinformation.SplitLineWhiteSpace(lines[j]);
												//copy some information from the nci file
												for (auto k = 0; k < substrings->Length; k++)
													if (substrings->Length == 1)
														System::Int32^ number1002 = 1002;
														auto number = StringManipulation::stringtoint(substrings[k]);
														if (number != nullptr)
															if (*number != 0 && *number != 1 && *number != 2 && *number != 3 && *number != 80 && *number != 81 && *number != 82 && *number != 83)
																if (*number == *number1002)
																	checkzdepthmode = true;
																else
													if (substrings->Length == 18 && checkzdepthmode == true)
														if (k == 12)
															auto zval = StringManipulation::stringtodouble(substrings[k]);
															zdepthvaluelist->Add(*zval);
													if (substrings->Length == 10 && checkzdepthmode == true)
														if (k == 6)
													if (substrings->Length == 6 && checkzdepthmode == true)
															if (k == 3)
													if (op->opcode == TP_DRILL)
														if (substrings->Length == 20 && checkzdepthmode == true)
															if (k == 3)
											auto maxzval = 0.0;
											auto minzval = 0.0;
											//find the min max z value
											SetMinMaxValueToList(zdepthvaluelist, minzval, maxzval);
											CString OperationInfo;
										    //copy some other information
											OperationInfo.Format(_T("ZMin :Z%lf ZMax :Z%lf TlLength :%lf Tldia :%lf Tlnum :%d RPM :%d Feed :%lf"), minzval,maxzval, tool->GetStickout(), op->tl.dia,op->tl.tlno, op->tl.rpm, op->tl.feed);
											//write the information to the operation comment
											_tcscpy(op->comment, OperationInfo);
											//restore the original filename
											_tcscpy(op->cmn.nci_name, ncioriginalname);
#else
											sprintf(op->comment, OperationInfo);
											sprintf(op->cmn.nci_name, ncioriginalname);
#endif
											//rewrite the operation
											//optional create a list of errors and send them to a report
											auto minzstrval = StringManipulation::GetAfter(minzval.ToString(),"-");
											if (minzstrval != nullptr)
												auto minzdblval = StringManipulation::stringtodouble(minzstrval);
												if (minzdblval != nullptr)
													if (tool->GetStickout() <= *minzdblval + .05)
														listviewlist->Add("Error operation -> " + op->op_idn + " -> tool stickout is too short by ->" + (*minzdblval + .05 - tool->GetStickout()).ToString() + " -> please extend your tool stickout." + "   Max Depth = -" + minzdblval->ToString() + "   Min Depth = " + maxzval.ToString() + "   Tool Stickout = " + tool->GetStickout().ToString());
														op->db.select_flag = TRUE;
													else
														op->db.select_flag = FALSE;
													if (tool->GetStickout() > *minzdblval + .5)
														listviewlist->Add("Error operation -> " + op->op_idn + " -> tool stickout is too long by ->" + (tool->GetStickout() - (*minzdblval + .5)).ToString() + " -> please shorten your tool stickout." + "   Max Depth = -" + minzdblval->ToString() +"   Min Depth = " + maxzval.ToString() + "   Tool Stickout = " + tool->GetStickout().ToString());
													else
									System::IO::File::Delete(filearray[i]);
			auto array = listviewlist->ToArray();
			if (array->Length > 0)
				System::Windows::Forms::Form ^ Form = gcnew System::Windows::Forms::Form;
				Form->BackColor = System::Drawing::Color::DarkGray;
				Form->Width = 1000;
				Form->Height = 650;
				Form->AutoScroll = true;
				Form->HorizontalScroll->Maximum = 0;
				Form->VerticalScroll->Visible = true;
				Form->VerticalScroll->Enabled = true;
				Form->HorizontalScroll->Enabled = false;
				Form->HorizontalScroll->Visible = false;
				System::Windows::Forms::Application::EnableVisualStyles();
				//add the list view to the windows form
				int Left = 10; int Top = 75; int Width = 1000; int Height = Form->Height - 150;
				//add a listview control to the windows form
				auto listview = CreateListViewOnWinform(Left, Top, Width, Height, Form, 1);
				Form->Controls->Add(listview);
				for (auto i = 0; i < array->Length; i++)
					auto listViewItem1 = gcnew System::Windows::Forms::ListViewItem(array[i]);
					//add the listview items to the listview
					listview->Items->Add(listViewItem1);
				Form->Show();
	public ref class AiOperationCommentInfoNethook : public Mastercam::App::NetHook3App
	public: Mastercam::App::Types::MCamReturn AiOperationCommentInfo(int param)
		AiTools::Functions functions;
		functions.AiOperationCommentInfo();
		return Mastercam::App::Types::MCamReturn::NoErrors;
https://github.com/PeterRussellEvans/WriteOperationDataToCommentSection
This seems like a lot of code to accomplish this.  Writing the text NCI to disk then scanning it seems rather inefficient, especially on larger NCI files.
I think you could achieve the same result doing something like this...
extern "C" __declspec(dllexport) int eMCExample452020Entry (int param)
	// Must call this prior to accessing any Resources in the C-Hook DLL !
	ChangeResCl res (GetChookResourceHandle ());
	CInterrogateMastercamFile fileInterrogator;
	fileInterrogator.Load();
	auto operationIDs = fileInterrogator.GetOpIDsInOpMgrOrder();
	if (operationIDs != nullptr)
		p_3d min;
		p_3d max;
		Cnc::Tool::TlAssemblyCPtr toolAssembly;
		std::wstring newComment = L"";
		DB_LIST_ENT_PTR outPointer = nullptr;
		bool result;
		for (auto opID : *operationIDs)
			auto operation = TpMainOpMgr.GetMainOpList().OpByID(opID);
			fileInterrogator.LoadForSingleOperation(operation->op_idn, true);
			fileInterrogator.CalcBnciExtents(false, false, true, true);
			min = fileInterrogator.GetBnciLowerLeft();
			max = fileInterrogator.GetBnciUpperRight();
			newComment = L"Z Min: " + std::to_wstring(min[2]) + L"\r\n";
			newComment += L"Z Max: " + std::to_wstring(max[2]) + L"\r\n";
			Cnc::Tool::GetToolSystem()->Find(operation->tl.slot, toolAssembly);
			if (toolAssembly != nullptr)
				newComment += L"Tool Projection: " + std::to_wstring(toolAssembly->GetToolProjection()) + L"\r\n";
			_tcscpy_s(operation->comment, newComment.c_str());
			operation_manager(operation, OPMGR_REWRITE, &outPointer, &result);
	return MC_NOERROR | MC_UNLOADAPP;
I know you might feel like this...
...but don't; developing in a vacuum is hard.
  • Haha 1
That is why I share what I do, so others won't have to search the galaxy for answers.
1 hour ago, Zaffin_D said:
extern "C" __declspec(dllexport) int eMCExample452020Entry (int param) { // Must call this prior to accessing any Resources in the C-Hook DLL ! ChangeResCl res (GetChookResourceHandle ()); CInterrogateMastercamFile fileInterrogator; fileInterrogator.Load(); auto operationIDs = fileInterrogator.GetOpIDsInOpMgrOrder(); if (operationIDs != nullptr) { p_3d min; p_3d max; Cnc::Tool::TlAssemblyCPtr toolAssembly; std::wstring newComment = L""; DB_LIST_ENT_PTR outPointer = nullptr; bool result; for (auto opID : *operationIDs) { auto operation = TpMainOpMgr.GetMainOpList().OpByID(opID); fileInterrogator.LoadForSingleOperation(operation->op_idn, true); fileInterrogator.CalcBnciExtents(false, false, true, true); min = fileInterrogator.GetBnciLowerLeft(); max = fileInterrogator.GetBnciUpperRight(); newComment = L"Z Min: " + std::to_wstring(min[2]) + L"\r\n"; newComment += L"Z Max: " + std::to_wstring(max[2]) + L"\r\n"; Cnc::Tool::GetToolSystem()->Find(operation->tl.slot, toolAssembly); if (toolAssembly != nullptr) { newComment += L"Tool Projection: " + std::to_wstring(toolAssembly->GetToolProjection()) + L"\r\n"; } _tcscpy_s(operation->comment, newComment.c_str()); operation_manager(operation, OPMGR_REWRITE, &outPointer, &result); } } return MC_NOERROR | MC_UNLOADAPP; }
This is also a good solution, thanks Zaffin.
+1000
:thumbsup:
I sometimes struggle to understand your code, but I appreciate that you're willing to share what you're working on!
When I used your method on operations on the bottom plane the value gets inverted
For example Method 1 outputs ZMin -.500 ZMax-.035
Method 2 outputs ZMin .035 ZMax .500
is there a reliable way to use your method for bottom operations?
#include "stdafx.h"
using Mastercam::App::NetHook3App;
#ifdef UNICODE
#define std_tostring std::to_wstring
#define std_string std::wstring
#else
#define std_tostring std::to_string
#define std_string std::string
#endif //UNICODE
// </copyright>
	public:
		FileInformation();
		~FileInformation();
	private:
	return result;
		int Start, End;
	return nullptr;
	if (ix != -1)
		return code;
	return nullptr;
	if (ix != -1)
		return code;
	return nullptr;
		count = count + 1;
			: code;
		return code;
	return nullptr;
	sw->Close();
						switch (j)
						case 0:
						case 1:
						case 2:
						case 3:
						case 4:
	return params;
	txtbox->Top = Top;
	txtbox->Text = "";
	return txtbox;
	return button;
	return label;
	header->Text = "                            ";
	return ListView1;
	else
	//define x position
	//define y position
	//define x position
	textpoint.X = x;
	//define y position
	textpoint.Y = y;
		nullptr;
	auto count = 0;
			count++;
	auto count = 0;
		count++;
namespace AiTools
				if (op != nullptr)
					//add the operation
					ops.push_back(op);
		return ops;
		nci_bin n;
		long long fpos = 0;
		bool succf = false;
#include "atlstr.h"
	public: void AiOperationCommentInfo()
						CString nci_name;
						_tcscpy_s(op->cmn.nci_name, nci_name);
#else
						sprintf_s(op->cmn.nci_name, _T(nci_name));
#endif
						nci_bin n;
						long long fpos = 0;
						bool succf = false;
															else
													if (k == 12)
													if (k == 6)
													if (k == 3)
														if (k == 3)
										auto maxzval = 0.0;
										auto minzval = 0.0;
										OperationInfo.Format(_T("ZMin :Z%lf ZMax :Z%lf TlLength :%lf Tldia :%lf Tlnum :%d RPM :%d Feed :%lf"), minzval, maxzval, tool->GetStickout(), op->tl.dia, op->tl.tlno, op->tl.rpm, op->tl.feed);
										_tcscpy_s(op->comment, OperationInfo);
										_tcscpy_s(op->cmn.nci_name, ncioriginalname);
#else
										sprintf_s(op->comment, OperationInfo);
										sprintf_s(op->cmn.nci_name, ncioriginalname);
#endif
										auto minzstrval = StringManipulation::GetAfter(minzval.ToString(), "-");
												else
													listviewlist->Add("Error operation -> " + op->op_idn + " -> tool stickout is too long by ->" + (tool->GetStickout() - (*minzdblval + .5)).ToString() + " -> please shorten your tool stickout." + "   Max Depth = -" + minzdblval->ToString() + "   Min Depth = " + maxzval.ToString() + "   Tool Stickout = " + tool->GetStickout().ToString());
												else
			Form->Width = 1000;
			Form->Height = 650;
			//Form->Show();
public ref class MyEntryPoint : public NetHook3App
public: virtual Mastercam::App::Types::MCamReturn Run(int param) override {
	//start program//
	Method2();
	//end program//
		void Method1()
				p_3d min;
				p_3d max;
				std_string newComment = _T("");
				bool result;
					newComment = _T("Z Min: ") + std_tostring(min[2]) + _T("\r\n");
					newComment += _T("Z Max: ") + std_tostring(max[2]) + _T("\r\n");
						newComment += _T("Tool Projection: ") + std_tostring(toolAssembly->GetToolProjection()) + _T("\r\n");
#else
					sprintf_s(operation->comment, newComment.c_str());
#endif
		void Method2()
Hmm that is odd.  Rather than rely on the GetBnciLowerLeft()/GetBnciUpperRight() function, try reading the BNCI as shown below.  You'll want to cover more NCI lines (NCI_ARC_CW, NCI_5AX_LINEAR, NCI_ARC_CCW, etc.),  but it should get you started.
			double minZ = 99999.999;
			double maxZ = -99999.999;
			CBnciReadWrite bnciReader;
			bnciReader.ReadSection(currentOperation->op_idn, false);
			auto binaryNCILines = bnciReader.GetData();
			for (auto nciLine : binaryNCILines)
				switch (nciLine->gcode)
				case NCI_RAPID:
					if (minZ > nciLine->u.m0.ep1[Z])
						minZ = nciLine->u.m0.ep1[Z];
					if (maxZ < nciLine->u.m0.ep1[Z])
						maxZ = nciLine->u.m0.ep1[Z];
					break;
				case NCI_LINEAR:
					if (minZ > nciLine->u.m1.ep1[Z])
						minZ = nciLine->u.m1.ep1[Z];
					if (maxZ < nciLine->u.m1.ep1[Z])
						maxZ = nciLine->u.m1.ep1[Z];
					break;
				default:
					break;
				case NCI_RAPID:
					break;
				case NCI_LINEAR:
					break;
				default:
					break;
Okay, I see, that is very helpful, I will post what I come up with here when it is done. Hopefully something shorter than my first iteration..
Thanks Zaffin.
@Zaffin_D
I used colored points to display the results in a fun way..
I had to add some extra numbers to capture the first drill position and retract point, here is the code GitHub or source :
void StorePoint( p_3d &pt, short view, MC_BYTE color,int levelnumber)
	ent point;
	point.id = P_ID;
	if (view != 1)
		p_3d NewPointInOperationView;
		view_to_view(pt, 1, view, NewPointInOperationView);
		point.u.pt = NewPointInOperationView;
	else
		point.u.pt = pt;
	bool succf;
	store_ent(&point, &ptr, 0, color, levelnumber, main_attrib, &succf);
#pragma region Exported Entry Points (Optional)
/// <summary> This is an optional additional exported entry point function. </summary>
/// <remarks> It is usually used via a "FUNCTION CPP" command in a Function Table (FT) file.
/// <param name="param"> An optional value passed in using a PARAM value in the "FUNCTION CPP" command block. </param>
/// <returns> The MC_RETURN state flag(s) back to Mastercam. </returns>
extern "C" __declspec(dllexport) int BnciReaderEntry (int param)
	auto mToolMinZ = 99999.999;
	auto mToolMaxZ = -99999.999;
	auto mToolRapidMinZ = 99999.999;
	auto mToolRapidMaxZ = -99999.999;
	auto errcount = 0;
		for (auto op : *operationIDs)
			auto currentOperation = TpMainOpMgr.GetMainOpList().OpByID(op);
			auto view = currentOperation->tpln.v_idn;
				if (nciLine->type == NCI_MILL_TYPE)
					if (nciLine->gcode == 1000)
						StorePoint(nciLine->u.m0.ep1, view, MC_YELLOW, 5005);
						if (mToolRapidMinZ > nciLine->u.m0.ep1[Z])
							mToolRapidMinZ = nciLine->u.m0.ep1[Z];
						if (mToolRapidMaxZ < nciLine->u.m0.ep1[Z])
							mToolRapidMaxZ = nciLine->u.m0.ep1[Z];
					if (nciLine->gcode == 1001)
					if (nciLine->gcode == NCI_RAPID)
					if (nciLine->gcode == NCI_LINEAR)
						if (mToolMinZ > nciLine->u.m1.ep1[Z])
							mToolMinZ = nciLine->u.m1.ep1[Z];
						if (mToolMaxZ < nciLine->u.m1.ep1[Z])
							mToolMaxZ = nciLine->u.m1.ep1[Z];
						StorePoint(nciLine->u.m1.ep1, view,MC_GREEN, 6005);
					if (nciLine->gcode == NCI_ARC_CW)
						StorePoint(nciLine->u.m1.ep1, view, MC_LT_BLUE, 6005);
					if (nciLine->gcode == NCI_ARC_CCW)
						StorePoint(nciLine->u.m1.ep1, view,MC_BLUE, 6005);
					if (nciLine->gcode == NCI_DRILL_HOLE)
						if (mToolRapidMinZ > nciLine->u.m100.ep2[Z])
							mToolRapidMinZ = nciLine->u.m100.ep2[Z];
						if (mToolRapidMaxZ < nciLine->u.m100.ep2[Z])
							mToolRapidMaxZ = nciLine->u.m100.ep2[Z];
						StorePoint(nciLine->u.m100.ep2, view, MC_YELLOW, 5005);
						p_3d pt = {};
						pt.SetXY(nciLine->u.m100.x, nciLine->u.m100.y);
						pt[2] = nciLine->u.m100.depth;
						StorePoint( pt, view, MC_RED, 6005);
						if (mToolMinZ > nciLine->u.m100.depth)
							mToolMinZ = nciLine->u.m100.depth;
						if (mToolMaxZ < nciLine->u.m100.depth)
							mToolMaxZ = nciLine->u.m100.depth;
					if (nciLine->gcode == NCI_DRILL_START)
						p_3d pt = {};
			Cnc::Tool::TlAssemblyCPtr tool;
You don't need to check for 1000 or 1001 in the BNCI.  1000 and 1001 are text NCI lines, the don't exist in the binary; the binary NCI only contains 1002(NCI_TOOLCHG) lines.
It also seems like you're storing a point for each move and not just the extents?
25 minutes ago, Zaffin_D said:
You don't need to check for 1000 or 1001 in the BNCI.  1000 and 1001 are text NCI lines, the don't exist in the binary; the binary NCI onlcontains 1002(NCI_TOOLCHG) lines.
Yes, you are right, thanks.
Yeah, it was an easy way to check if it is working okay, I find it is actually a useful way to look at a large quantity of toolpaths, I think I will use it in a standalone add-in.
The performance is a lot better with your method. Nice work!!
Did you learn all that from just reading the docs?
Are there c-hook docs?  I know about the .chm file, but I never spent any time with it; it was very hard for me to find anything in there.
I search the headers in Visual Studio.  If my search comes up empty I ask a coworker.  If my coworkers don’t know I ask the SDK team.
It comes down to time and experience;  I stated with C++ and c-hooks about 8 months ago, and at first I couldn’t find my butt with both hands.
The chm file has a few extra notes that don't appear in the header files.
I have only been programming about a year or so, I learned programming with mastercam vbscript and went from there.
Didn't know what a chook was before that..
I saw they started to make c++ example projects now so I think that will be interesting!
Ouu I see you have a nice new website, I tried clicking the contact button, it wasn't popping up
@Zaffin_D I would say the area I struggle the most with is like matrix/vector stuff, I am trying to get my libraries down.
I started learing some "modern" opengl it's pretty fun, I made like a simple object loader in one tutorial, I was reading how you could build a .stp file parser as well.The hard part was just getting all the libraries and header files built and working lol.
Hopefully that is going to improve my programming knowledge.
I am also hoping to get a good menu system on the open gl platform, most people seem to say use qt.Then I will have a nice cross platform application, I think wpf also has that though anyway and there is c# graphic too, but I try to learn the low level api stuff first so when I do my high level program I will have a better trouble shooting skill, but it takes long to figure stuff out with .net.
Lots of people do graphics with python too, but I don't want that.
