Sign in to follow this
AlexofHardinge
X axis is inverted?
I recently changed my post from:
#Machine axis switches, initial
old_new_sw : 1 #Switch old (6T), new (0T+) cycle formats, 0=old, 1=new
to:
old_new_sw : 0 #Switch old (6T), new (0T+) cycle formats, 0=old, 1=new
because my HAAS lathe uses single line canned cycles, which worked to fix that but now my x values all post inverted.
ex.
if drawn to X1.0, Z-.5  it posts, X-1.0, Z-.5
How can I get these to post normally?
edit1: i tried switching back that line and it is still posting inverted, i must've changed something else...
It really comes down to how you want to program a TL. You can use the ST post and be done, just need to program it as a upper turret machine. I prefer this way, that way if you want to run the same program on another lathe that is a slant, just change the post and go. If you program a TL as a lower turret machine, you would have to mirror the geometry and then change the post when moving over to another lathe.
If you change the multiplier like Colin said, I believe you will also have an issue with the arcs being reversed.
