C++/Cli Operations : Delete and Replace Method
Hi,
These are my latest operations exported to .Net, they contain the Delete and Replace method to deal with unwanted associated entities
typedef struct MastercamChookSdk
	typedef struct OperationsManager
		// GetOperationList
		//define the functions parammeters
		typedef struct GetOperationListParams
			TP_OPCODE opCode = TP_OPCODE::TP_NULL;
		// define the functions
		typedef std::vector<operation*>(*GetOperationsList)(GetOperationListParams);
		typedef struct GetOperationListFunctions
			GetOperationsList getoperationslist;
			std::vector<operation*> getoperationslistresult;
		// GetPointsToOperation
		typedef struct GetPointsInOperationParams
			operation *op;
			std::vector<ent_tp> drillPointTPEnts;
		typedef std::vector<ent_tp>(*GetPointsInOperation)(GetPointsInOperationParams);
		typedef struct GetPointsInOperationFunctions
			GetPointsInOperation getpointsinoperation;
			std::vector<ent_tp> getpointsinoperationresult;
		// AddPointsToOperation
		typedef struct AddPointsToOperationParams
			operation *op;
			std::vector<ent> points;
		typedef int(*AddPointsToOperation)(AddPointsToOperationParams);
		typedef struct AddPointsToOperationFunctions
			AddPointsToOperation addpointstooperation;
			int addpointstooperationresult;
	// GetChainsInOperation
		typedef struct GetChainsInOperationParams
			long opID;
		typedef CHAIN*(*GetChainsInOperation)(GetChainsInOperationParams);
		typedef struct GetChainsInOperationFunctions
			GetChainsInOperation getchainsinoperation;
			CHAIN* getchainsinoperationresult;
// AddChainsToOperation
		typedef struct AddChainsToOperationParams
			long opID = 0;
			CHAIN* chain;
		typedef bool(*AddChainsToOperation)(AddChainsToOperationParams);
		typedef struct AddChainsToOperationFunctions
			AddChainsToOperation addchainstooperation;
			bool addchainstooperationresult;
		// CloneChainBasedOperations
		typedef struct  CloneChainBasedOperationsParams
			long op_id = 0;
		typedef operation*(*CloneChainBasedOperations)(CloneChainBasedOperationsParams);
		typedef struct  CloneChainBasedOperationsFunctions
			CloneChainBasedOperations  clonechainbasedoperations;
			operation* clonechainbasedoperationsresult;
		typedef struct CloneDrillingOperationsParams
			long op_id = 0;
		typedef operation*(*CloneDrillingOperations)(CloneDrillingOperationsParams);
		typedef struct CloneDrillingOperationsFunctions
			CloneDrillingOperations clonedrillingoperations;
			operation* clonedrillingoperationsresult;
std::vector<operation*> GetOperationsList(MastercamChookSdk::OperationsManager::GetOperationListParams params);
MastercamChookSdk::OperationsManager::GetOperationListFunctions InitGetOperationsListFunctions();
std::vector<ent_tp> GetPointsInOperation(MastercamChookSdk::OperationsManager::GetPointsInOperationParams params);
MastercamChookSdk::OperationsManager::GetPointsInOperationFunctions InitGetPointsInOperationFunctions();
int AddPointsToOperation(MastercamChookSdk::OperationsManager::AddPointsToOperationParams params);
MastercamChookSdk::OperationsManager::AddPointsToOperationFunctions InitAddPointsToOperationFunctions();
MastercamChookSdk::OperationsManager::CloneDrillingOperationsFunctions InitCloneDrillingOperationsFunctions();
operation* CloneDrillingOperations(MastercamChookSdk::OperationsManager::CloneDrillingOperationsParams cdparams);
CHAIN * GetChainsInOperation(MastercamChookSdk::OperationsManager::GetChainsInOperationParams params);
MastercamChookSdk::OperationsManager::GetChainsInOperationFunctions InitGetChainsInOperationFunctions();
bool AddChainsToOperation(MastercamChookSdk::OperationsManager::AddChainsToOperationParams params);
MastercamChookSdk::OperationsManager::AddChainsToOperationFunctions InitAddChainsToOperationFunctions();
operation* CloneChainBasedOperations(MastercamChookSdk::OperationsManager::CloneChainBasedOperationsParams cbparams);
MastercamChookSdk::OperationsManager::CloneChainBasedOperationsFunctions InitCloneChainBasedOperationsFunctions();
/// <summary> Retrieves the operations found in the Toolpath Manager of the specified type. </summary>
/// <param name="opCode"> (Optional) The operation code to filter on. (TP_NULL for NO Filtering). </param>
/// <returns> The list of matching operations found. </returns>
// (TP_OPCODE opCode = TP_OPCODE::TP_NULL)
	std::vector<operation *> ops;
	for (auto index = 0; index < TpMainOpMgr.GetMainOpList().GetSize(); ++index)
		auto op = TpMainOpMgr.GetMainOpList()[index];
		if (op && (params.opCode == TP_NULL || op->opcode == params.opCode))
			ops.push_back(op);
	return ops;
	MastercamChookSdk::OperationsManager::GetOperationListFunctions functions;
	functions.getoperationslist = GetOperationsList;
	return functions;
	drillPointTPEnts.clear(); // out
	// Starting in Mastercam 2018 you use 'GetAllTpEntities' instead of 'tp_get_all'.
	// It returns a vector of 'ent_tp' items which is simple to iterate through
	// and does not require using FREE to clean up.
	ent opEnt;
	auto tpEnts = GetAllTpEntities(params.op->op_idn, opEnt);
	for (const auto &tpEnt : tpEnts)
		if (tpEnt.u.tp.tp_id == TP_PT_PT || tpEnt.u.tp.tp_id == TP_PT_SOLID)// || tpEnt.u.tp.tp_id == TP_ARC_SOLID || tpEnt.u.tp.tp_id == TP_PT_CIRC_MILL)
			ASSERT(tpEnt.u.tp.op_idn == op->op_idn);
			drillPointTPEnts.push_back(tpEnt);
	return drillPointTPEnts;
	MastercamChookSdk::OperationsManager::GetPointsInOperationFunctions functions;
	functions.getpointsinoperation = GetPointsInOperation;
	return functions;
	MastercamChookSdk::OperationsManager::AddPointsToOperationFunctions functions;
	functions.addpointstooperation = AddPointsToOperation;
	return functions;
#define IDS_POINT_NAME 13
	if (params.points.empty())
		return 0;
	bool succf = false;
	int ptsAdded = 0;
	// Retrieve the operation 'entity' for this operation.
	ent opEnt;
	if (TpMainOpMgr.GetMainOpList().DatabaseRetrieve(params.op->op_idn, opEnt))
		int index = 0;
		for (const auto &entity : params.points)
			if (entity.id == P_ID || entity.id == A_ID)
				// Create a point type toolpath entity.
				auto pointCode = (entity.id == P_ID) ? PEC_POINT : PEC_CENTER;
				auto pt = (entity.id == A_ID) ? entity.u.pt : entity.u.ar.c;
				double tval[2] = { 0 };
				ent tpEnt;
				init_tp_ent(&entity, P_ID, TP_PT_PT, pointCode, pt, tval, params.op, &tpEnt);
				//tpEnt.u.tp.u.pt.z_depth = entity.u.pt[ZCOORD];
				// We can give the drill point a "name".
				CString name;
				name.LoadString(IDS_POINT_NAME);
				name.Format(_T("Arc %i (\u2300%1.4f)"), ++index, entity.u.ar.r * 2);
				_tcsncpy_s(tpEnt.u.tp.u.pt.name, name, _TRUNCATE);
				// Update the optr data in the toolpath entity to point to this operation!
				tpEnt.u.tp.optr = opEnt.eptr;
				DB_LIST_ENT_PTR dbPtr = nullptr;
				bool ok = false;
				store_ent_assoc(&tpEnt, &dbPtr, TP_ID, &ok);
				if (ok)
					ptsAdded++;
		// Adjust for the number of points we added to the operation.
		opEnt.u.op.db.ent_count += ptsAdded;
		opEnt.u.op.db.disp_count += ptsAdded;
		if (ptsAdded > 0)
			// Update the "associated" ents in the operation.
			rewrite_ent_assoc(&opEnt, true);
			// Update the caller's operation pointer with the data we've updated.
				*params.op = opEnt.u.op;
				succf = true;
			else
				succf = false;
#ifdef DEBUG // See the toolpath entities after we've updated the operation.
#if C_H_VERSION >= 2000 // Mastercam 2018 or later.
		// In Mastercam 2018 you can use 'GetAllTpEntities' instead of 'tp_get_all'.
		auto tpEnts = GetAllTpEntities(op->op_idn, opEnt);
		bool debugStop = true; // Set a breakpoint here to see what was retrieved.
#else
		ent_tp *tp_ents = nullptr;
		long n_tp_ents = 0;
		bool ok = false;
		tp_get_all(op->op_idn, &opEnt, &tp_ents, &n_tp_ents, &ok);
		free(tp_ents); // MUST free what tp_get_all retrieved for us!
#endif
#endif
	return ptsAdded;
	operation op;
	int ptCount = 0;
	auto succf = false;
	// Find the Drill toolpath operations.
	MastercamChookSdk::OperationsManager::GetOperationListParams params;
	functions = InitGetOperationsListFunctions();
	params.opCode = cdparams.opCode;
	auto operationlist = functions.getoperationslist(params);
	auto count = 0;
	for (auto drillop : operationlist)
		if (drillop && (cdparams.opCode == drillop->opcode || cdparams.opCode == TP_OPCODE::TP_NULL))
			if (drillop && (cdparams.op_id == drillop->op_idn || cdparams.op_id == 0))
				//CString str;
				//str.Format(_T("op#  : %d"), ptCount);
				//count++;
				//MessageBox(NULL, str,
				//	TEXT("Message"), 3);
				auto validoperation = true;
				prm_drill prm_drill;
				prm_circmill prm_circmill;
				if (drillop->opcode == TP_DRILL)
					prm_drill = drillop->u.prm_drl;
				else if (drillop->opcode == TP_CIRCMILL)
					prm_circmill = drillop->u.circmill;
				else
					validoperation = false;
				if (validoperation)
					auto WCS = drillop->WCS;
					auto tpln = drillop->tpln;
					auto cpln = drillop->cpln;
					auto tewl = drillop->tl;
					auto cmn = drillop->cmn;
					auto dcuts = drillop->dcuts;
					auto mcuts = drillop->mcuts;
					auto lead = drillop->lead;
					auto prm_drl = drillop->u.prm_drl;
					std::vector<ent> drillPointEnts;
					// GetPointsInOperationFunctions functions;
					MastercamChookSdk::OperationsManager::GetPointsInOperationFunctions functions2;
					MastercamChookSdk::OperationsManager::GetPointsInOperationParams params2;
					functions2 = InitGetPointsInOperationFunctions();
					params2.op = drillop;
					params2.drillPointTPEnts = functions2.getpointsinoperation(params2);
					///params2.opCode = TP_DRILL;
					if (!params2.drillPointTPEnts.empty())
						// Go through the Drill Points of this operation and
						// replicate the geometry used by those points to a new level.
						for (auto point : params2.drillPointTPEnts)
							ent entity;
							if (get_ent_from_eptr(point.u.tp.eptr, &entity) == 0)
								auto ent = entity;
								short sel = ALIVE_BIT;
								MC_BYTE color = MC_RED;
								int level = point.u.tp.eptr->eptr->level;
								store_ent(&ent, &ent.eptr, sel, color, level, main_attrib, &succf);//nothing happens?this must not be the ptr
								if (succf)
									drillPointEnts.push_back(ent);
						// We are replicating the original operation we're going delete later.
						// We get its OpCode and the Tool that it's using.
						ZeroMemory(&op, sizeof(operation));
						op.opcode = drillop->opcode;
						operation_manager(&op, OPMGR_INIT_ADD, &dbPtr, &succf);
						auto boolfind = false;
						auto boolassign = false;
						if (succf)
							//Mastercam::IO::EventManager::LogEvent(Mastercam::IO::Types::MessageSeverityType::InformationalMessage, boolfind.ToString(), boolassign.ToString());
							// Create new Drill Points for the new operation.
							// ToolPath Entities CANNOT be shared between operations.
							// We must create new ones for this new operation.
							MastercamChookSdk::OperationsManager::AddPointsToOperationParams params3;
							MastercamChookSdk::OperationsManager::AddPointsToOperationFunctions functions3;
							functions3 = InitAddPointsToOperationFunctions();
							params3.op = &op;
							params3.points = drillPointEnts;
							ptCount = functions3.addpointstooperation(params3);
							op.WCS = WCS;
							op.tpln = tpln;
							op.cpln = cpln;
							op.tl = tewl;
							op.tl.feed = tewl.feed;
							op.cmn = cmn;
								op.u.prm_drl = prm_drill;
								op.u.circmill = prm_circmill;
								op.dcuts = dcuts;
								op.mcuts = mcuts;
								op.lead = lead;
								op.lead.on = true;
								op.u.circmill.hs_entry_on = true;
								op.u.circmill.hs_trans_angle = 90.0;
								op.u.circmill.start_at_center = true;
								op.u.circmill.start_angle = 90.0;
							else
								//unreachable
							if (ptCount > 0)
								operation_manager(&op, OPMGR_REWRITE, &dbPtr, &succf);
								// Regenerate the new operation.
								operation_manager(&op, OPMGR_NCI_REGEN, &dbPtr, &succf);
							// Delete the old operation.
							operation_manager(drillop, OPMGR_DELETE, &dbPtr, &succf);
						//System::Windows::Forms::MessageBox::Show("boolassign is : " + boolassign.ToString());
						//System::Windows::Forms::MessageBox::Show("boolfind is : " + boolfind.ToString());
					else
						//auto txt = " f";
	return &op;
	MastercamChookSdk::OperationsManager::CloneDrillingOperationsFunctions functions;
	functions.clonedrillingoperations = CloneDrillingOperations;
	return functions;
/// <summary> Gets the chains in an operation. </summary>
/// <param name="opID"> Identifier for the operation. </param>
/// <returns> Null if it fails, else the chains referenced by the operation. </returns>
CHAIN *GetChainsInOperation(MastercamChookSdk::OperationsManager::GetChainsInOperationParams params)
	bool succf = false;
	chain_manager_info ChainManagerInfo;
	ChainManagerInfo.mode = CHNMGR_GET;
	ChainManagerInfo.op_idn = params.opID;
	chain_manager(&ChainManagerInfo, 0, &succf);
	return (succf) ? ChainManagerInfo.chns : nullptr;
	MastercamChookSdk::OperationsManager::GetChainsInOperationFunctions functions;
	functions.getchainsinoperation = GetChainsInOperation;
	return functions;
	bool succf = false;
	ChainManagerInfo.mode = CHNMGR_ADD;
	ChainManagerInfo.chns = params.chain;
	return succf;
	MastercamChookSdk::OperationsManager::AddChainsToOperationFunctions functions;
	functions.addchainstooperation = AddChainsToOperation;
	return functions;
	auto succf = false;
	operation op;
	params.opCode = cbparams.opCode;
	auto count = 0;
	for (auto currentop : operationlist)
		if (currentop && (cbparams.opCode == currentop->opcode || cbparams.opCode == TP_OPCODE::TP_NULL))
			if (currentop && (cbparams.op_id == currentop->op_idn || cbparams.op_id == 0))
				prm_contour prm_cntr;
				prm_pocket prm_pkt;
				if (currentop->opcode == TP_CONTOUR)
					prm_cntr = currentop->u.prm_cntr;
				else if (currentop->opcode == TP_POCKET)
					prm_pkt = currentop->u.prm_pkt;
				else
				//CString str;
				//count++;
				if (validoperation)
					auto WCS = currentop->WCS;
					auto tpln = currentop->tpln;
					auto cpln = currentop->cpln;
					auto tewl = currentop->tl;
					auto cmn = currentop->cmn;
					auto dcuts = currentop->dcuts;
					auto mcuts = currentop->mcuts;
					auto lead = currentop->lead;
					MastercamChookSdk::OperationsManager::GetChainsInOperationFunctions functions2;
					MastercamChookSdk::OperationsManager::GetChainsInOperationParams params2;
					functions2 = InitGetChainsInOperationFunctions();
					params2.opID = currentop->op_idn;
					functions2.getchainsinoperationresult = functions2.getchainsinoperation(params2);
					if (functions2.getchainsinoperationresult != nullptr)
						op.opcode = currentop->opcode;
						if (succf)
							MastercamChookSdk::OperationsManager::AddChainsToOperationParams params3;
							MastercamChookSdk::OperationsManager::AddChainsToOperationFunctions functions3;
							functions3 = InitAddChainsToOperationFunctions();
							params3.chain = functions2.getchainsinoperationresult;
							params3.opID = op.op_idn;
							functions3.addchainstooperationresult = functions3.addchainstooperation(params3);
							op.WCS = WCS;
							op.tpln = tpln;
							op.cpln = cpln;
							op.dcuts = dcuts;
							op.mcuts = mcuts;
							op.lead = lead;
							op.tl = tewl;
							op.cmn = cmn;
								op.u.prm_cntr = prm_cntr;
								op.u.prm_pkt = prm_pkt;
							else
								//unreachable
								return false;
							if (functions3.addchainstooperationresult)
							operation_manager(currentop, OPMGR_DELETE, &dbPtr, &succf);
	return &op;
	MastercamChookSdk::OperationsManager::CloneChainBasedOperationsFunctions functions;
	functions.clonechainbasedoperations = CloneChainBasedOperations;
	return functions;
namespace ChookSdkLibrary
// <copyright file="ChangeAttributes ">
//   Copyright (c) 2020 PeterRussellEvans, Inc.
// </copyright>
// <summary>
//   NET-Hook
// </summary>
	namespace OperationManagerUtilities
		/// <summary> A make contour operation from chains parameters package. </summary>
		public ref struct MakeCircleMillOpFromGeometryParams
			int level;
			double clearancePlane;
			double feedPlane;
			double topOfStock;
			double depth;
			int viewId;
			int FeedRate;
			int spindlespeed;
			int slot;
			int num_fcuts = 0;
			double stock_to_leave_on_wall = 0.0;
			double size_fcuts = 0.0;
		public ref struct MakeContourOpFromChainsParams
			int level;
			double feedPlane;
			double topOfStock;
			double depth;
			int viewId;
			Mastercam::Operations::Types::ContourSubtypeType cntrtpe;
			Mastercam::Database::Types::CutterCompDir cuttercompdir;
			Mastercam::Database::Types::ChainDirectionType chndir;
			double FeedRate;
			int spindlespeed;
			bool tabison;
			int slot;
			bool osciateison;
			int num_fcuts = 0;
			bool leadinoutison = false;
			double line_length_pct = 0.0;
			bool doleadin;
			double minz;
		/// <summary> A make pocket operation from chains parameters package. </summary>
		public ref struct MakePocketOpFromChainsParams
			int level;
			double feedPlane;
			double topOfStock;
			double depth;
			int viewId;
			double FeedRate;
			int spindlespeed;
			int slot;
			int num_fcuts = 0;
		/// <summary> A make drill operation from geometry parameters package. </summary>
		public ref struct MakeDrillOpFromGeometryParams
			double feedPlane;
			double topOfStock;
			double depth;
			int viewId;
			double FeedRate;
			int spindlespeed;
			int slot;
			int targetlevel;
		public ref class CreateOperations abstract sealed
		public:
#pragma once
			//create an endmill
			static int ChookSdkLibrary::OperationManagerUtilities::CreateOperations::makendmil(int tlnum, double flutelen, double shldrlen, double shldrdia,
				double tooldia, double feedrate, int rpm, System::String ^Name, double tipangle);
			//create a contour operation
			static int ChookSdkLibrary::OperationManagerUtilities::CreateOperations::MakeContourOpFromChains(const MakeContourOpFromChainsParams ^params);
			////int level, double clearancePlane, double feedPlane, double topOfStock, double depth, int viewId,
			////Mastercam::Operations::Types::ContourSubtypeType cntrtpe, Mastercam::Database::Types::CutterCompDir cuttercompdir,
			////Mastercam::Database::Types::ChainDirectionType chndir, int FeedRate, int spindlespeed, bool tabison, int slot, bool osciateison,
			////int num_fcuts, double stock_to_leave_on_wall, double size_fcuts, bool leadinoutison, double line_length_pct
			//create a pocket operation
			static int ChookSdkLibrary::OperationManagerUtilities::CreateOperations::MakePocketOpFromChains(const MakePocketOpFromChainsParams ^params);
			////Mastercam::Database::Types::CutterCompDir cuttercompdir,
			////Mastercam::Database::Types::ChainDirectionType chndir, int FeedRate, int spindlespeed, int slot
			//create a drilling operation
			static int ChookSdkLibrary::OperationManagerUtilities::CreateOperations::MakeDrillOpFromGeometry(const MakeDrillOpFromGeometryParams ^params);
			////double clearancePlane, double feedPlane, double topOfStock,
			////double depth, int viewId, int FeedRate, int spindlespeed, int slot, int targetlevel
			static int ChookSdkLibrary::OperationManagerUtilities::CreateOperations::MakeCircleMillOpFromGeometry(const MakeCircleMillOpFromGeometryParams ^params);
int ChookSdkLibrary::OperationManagerUtilities::CreateOperations::makendmil(int tlnum, double flutelen, double shldrlen, double shldrdia, double tooldia, double feedrate, int rpm, System::String ^ Name, double tipangle)
	Mastercam::Tools::EndMillFlatTool tool;
	tool.Diameter = tooldia;
	tool.Feed = feedrate;
	tool.Length = 2.0;
	tool.FluteLength = flutelen;
	tool.Flutes = 4;
	tool.MfgToolCode = _T("Code : Tcode");
	tool.TipAngle = tipangle;
	tool.PlungeFeed = 50.0;
	tool.DiameterOffset = tlnum;
	tool.LengthOffset = tlnum;
	tool.Number = tlnum;
	tool.Name = Name;
	tool.SpindleRotation = 0;
	tool.RadiusType = Mastercam::Database::Types::ToolRadiusType::None;
	tool.RPM = rpm;
	tool.RetractFeed = 500.0;
	tool.ShoulderDia = shldrdia;
	tool.ShankDia = tooldia;
	tool.ShoulderLength = shldrlen;
	tool.IsMetric = false;
	tool.Coolant = Mastercam::Database::Types::CoolantMode::COOL_OFF;
	return tool.Commit() ? tool.Slot : 0;
int ChookSdkLibrary::OperationManagerUtilities::CreateOperations::MakeContourOpFromChains(const ChookSdkLibrary::OperationManagerUtilities::MakeContourOpFromChainsParams ^params)
//int num_fcuts, double stock_to_leave_on_wall, double size_fcuts, bool leadinoutison, double line_length_pct)//, EndMillFlatTool ^ tool)
	auto views = Mastercam::Support::SearchManager::GetViews();
	Mastercam::IO::ViewManager::GraphicsView = views[params->viewId];
	Mastercam::IO::ViewManager::CPlane = views[params->viewId];
	Mastercam::IO::ViewManager::TPlane = views[params->viewId];
	Mastercam::Database::ChainManager::ChainTolerance = .001;
	const auto chains = Mastercam::Database::ChainManager::ChainAll(false, false, nullptr, params->chndir, params->level);
	//check that we have something///////////////////////////////////////////////////////////////////////////////////////////////////
	double stock_to_leave_on_floor = 0.0;
	//System::Windows::Forms::MessageBox::Show("chk");
	if (chains != nullptr && chains->Length != 0)
		auto cntrop = gcnew Mastercam::Operations::ContourOperation;
		cntrop->AssignMillToolBySlot(params->slot);
		cntrop->CutterComp.Direction = params->cuttercompdir;
		cntrop->CutterComp.RollCorners = Mastercam::Database::Types::CutterCompRoll::CutterCompRollAll;
		cntrop->OperationTool->SpindleRotation = 0;
		//linking params
		cntrop->Linking->FeedPlane = params->feedPlane;
		cntrop->DepthCuts.Enabled = true;
		cntrop->DepthCuts.CutOrderByDepth = true;
		cntrop->DepthCuts.FinishNumberCuts = params->num_fcuts;
		cntrop->DepthCuts.FinishStep = params->size_fcuts;
		cntrop->DepthCuts.MaxRoughStep = .755;
		cntrop->DepthCuts.TaperedWalls = false;
		cntrop->DepthCuts.UseSubprogram = false;
		cntrop->Linking->Depth = params->depth;
		cntrop->Linking->ClearanceOn = true;
		cntrop->Linking->Clearance = params->clearancePlane;
		cntrop->Linking->Retract = params->clearancePlane;
		cntrop->Linking->RetractOn = true;
		cntrop->Linking->TopStock = params->topOfStock;
		//		cntrop->UpdateToolSettings();
		cntrop->MiscValues->UseValuesFromPost = true;
		cntrop->MultiPass.Enabled = false;
		if (params->doleadin)
			cntrop->LeadInOut.Enabled = true;
			cntrop->LeadInOut.GougeCheck = true;
			cntrop->LeadInOut.EnterAtMidPt = true;
			cntrop->LeadInOut.Entry.Enabled = true;
			cntrop->LeadInOut.Entry.ArcRadius = .05;
			cntrop->LeadInOut.Entry.ArcSweep = 90.0;
			cntrop->LeadInOut.Entry.LineLength = params->minz + .125;
			cntrop->LeadInOut.Entry.RampHeight = params->minz + .125;
			cntrop->LeadInOut.Entry.OneDepth = false;
			cntrop->LeadInOut.Entry.Feedrate = params->FeedRate;
			cntrop->LeadInOut.Entry.HelixHeight = 0.0;
			cntrop->LeadInOut.Entry.Perpendicular = true;
			cntrop->LeadInOut.Exit.Enabled = false;
			cntrop->LeadInOut.ContourStart.Enabled = false;
			cntrop->LeadInOut.ContourEnd.Enabled = false;
			cntrop->Entry.EnterFirstOrExitLastOnly = false;
			cntrop->LeadInOut.OverLap = 0;
			cntrop->Entry.Enabled = true;
			cntrop->Entry.UseFeedOverride = false;
			cntrop->Entry.Perpendicular = true;
			cntrop->Entry.UsePoint = false;
			cntrop->Entry.UsePointDepth = false;
			cntrop->Exit.Enabled = true;
			cntrop->Exit.UseFeedOverride = false;
			cntrop->Exit.EnterFirstOrExitLastOnly = false;
			cntrop->Exit.Perpendicular = true;
			cntrop->Exit.UsePoint = false;
			cntrop->Exit.UsePointDepth = false;
		if (params->tabison)
			cntrop->Tabs.AutomaticPosition = true;
			cntrop->Tabs.TabAll = true;
			cntrop->Tabs.Enabled = true;
			cntrop->Tabs.AutoTabByDistance = false;
			cntrop->Tabs.NumberOfTabs = 4;
			cntrop->Tabs.EntryExitMode = Mastercam::Operations::Types::TabEntryExitType::Arc;
			cntrop->Tabs.TabThickness = 0.04;
			cntrop->Tabs.TabWidth = 0.3;
			cntrop->Tabs.RampAngle = 45.0;
		if (!params->tabison)
			cntrop->Tabs.Enabled = false;
		auto osclinkdepth = 0.0;
		if (params->viewId == 0)
			osclinkdepth = 0.0;
		if (params->viewId == 3)
			osclinkdepth = params->minz;
		if (params->osciateison)
			if (params->minz <= .25)
				cntrop->Linking->Depth = osclinkdepth;
				cntrop->Oscillate.MaximumDepth = 0.035 - params->minz;
			if (params->minz <= .755 && params->minz > .25)
				cntrop->Linking->Depth = osclinkdepth - .05;
				cntrop->Oscillate.MaximumDepth = 0.085 - params->minz;
			if (params->minz > .755)
				cntrop->Linking->Depth = osclinkdepth - .25;
				cntrop->Oscillate.MaximumDepth = -.5;
			cntrop->Oscillate.OscillationDistance = 4.0;
			cntrop->Oscillate.MovementType = Mastercam::Operations::Types::OscillationMovementType::Highspeed;
		cntrop->ForceToolChangeOn = false;
		cntrop->BreakThrough.Enabled = false;
		cntrop->ArcFilter.Enabled = false;
		cntrop->RotaryAxis.Enabled = false;
		cntrop->CutParams.ContourSubtype = params->cntrtpe;
		cntrop->CutParams.InternalCornerRoundingRadius = .001;
		cntrop->PlungeRate = 75.0;
		cntrop->RetractRate = 500.0;
		//lead in
		//entry params
		//end lead in
		cntrop->SpindleSpeed = params->spindlespeed;
		//set feedrate
		cntrop->FeedRate = params->FeedRate;
		cntrop->NCIName = _T("Contour #1");
		cntrop->Name = _T("Contour operation created via API");
		operation op = {};
		DB_LIST_ENT_PTR ptr;
		bool succf;
		cntrop->SetChainArray(chains);
		if (!cntrop->Commit())
			return 0;
		cntrop->Regenerate();
		op.op_idn = cntrop->GetOperationID();
		operation_manager(&op, OPMGR_GET, &ptr, &succf);
		op.u.prm_cntr.ex_corner_rad = 0.001;
		op.dcuts.stock_t_l = stock_to_leave_on_floor;
		op.misc.on = false;
		op.cmn.rapid_retract = true;
		op.cmn.retract_inc = false;
		op.cmn.retract_on = false;
		op.cmn.clearance_inc = false;
		op.cmn.depth_inc = false;
		op.cmn.top_stock_inc = false;
		op.cmn.feed_inc = false;
		op.cc.type = CC_COMPUTER;
		op.cmn.stk_remain = params->stock_to_leave_on_wall;
		op.dcuts.fin_n = params->num_fcuts;
		op.dcuts.fin_amt = params->size_fcuts;
		op.u.prm_cntr.tab.adv_auto = true;
		op.u.prm_cntr.tab.full_thick = false;
		if (params->leadinoutison)
			op.lead.entry.on = true;
			op.lead.entry.arc_radius_pct = 0.0;
			op.lead.entry.arc_sweep = TWO_PI / 4;
			op.lead.entry.line_length_pct = params->line_length_pct;
			op.lead.entry.perp = true;
			op.lead.entry.helix_height = 0.0;
			op.lead.entry.ramp_height = 0.0;
			op.lead.exit.on = true;
			op.lead.exit.arc_radius_pct = 0.0;
			op.lead.exit.arc_sweep = TWO_PI / 4;
			op.lead.exit.line_length_pct = params->line_length_pct;
			op.lead.exit.perp = true;
			op.lead.exit.helix_height = 0.0;
			op.lead.exit.ramp_height = 0.0;
			cntrop->CutParams.InternalCornerRoundingRadius = .000;
			op.u.prm_cntr.ex_corner_rad = 0.000;
		op.tl.feed = params->FeedRate;
		operation_manager(&op, OPMGR_REWRITE, &ptr, &succf);
		//operation_manager(&op, OPMGR_NCI_REGEN, &ptr, &succf);
		auto chaincloner = InitCloneChainBasedOperationsFunctions();
		MastercamChookSdk::OperationsManager::CloneChainBasedOperationsParams chainclonerparams;
		chainclonerparams.op_id = op.op_idn;
		auto newop = chaincloner.clonechainbasedoperations(chainclonerparams);
		//RefreshOperation(newop->op_idn);
		Mastercam::Operations::OperationsManager::RefreshOperationsManager();
	return 1;
int ChookSdkLibrary::OperationManagerUtilities::CreateOperations::MakePocketOpFromChains(const ChookSdkLibrary::OperationManagerUtilities::MakePocketOpFromChainsParams ^params)
//int level, double clearancePlane, double feedPlane, double topOfStock, double depth, int viewId, Mastercam::Database::Types::CutterCompDir cuttercompdir,
//Mastercam::Database::Types::ChainDirectionType chndir, int FeedRate, int spindlespeed, int slot)//, EndMillFlatTool ^ tool)
	//CString strname = "Mastercam";
	//CString entryname = "delete_duplicates_basic";
	//post_FT_command(
	//	strname,
	//	entryname);
	Mastercam::Database::ChainManager::ChainTolerance = .01;
	const auto chains = Mastercam::Database::ChainManager::ChainAll(true, false, nullptr, params->chndir, params->level);
	repaint_graphics();
	operation op = {};
		auto cntrop = gcnew Mastercam::Operations::PocketOperation;
		cntrop->Roughing.Enabled = true;
		cntrop->Finishing.Enabled = false;
		//linking params
		cntrop->PocketRoughEntry.Helix.MaxRadius = .2;
		cntrop->PocketRoughEntry.Helix.FollowBoundaryOnlyFail = true;
		cntrop->PocketRoughEntry.Helix.Tolerance = .001;
		cntrop->PocketRoughEntry.Helix.MinRadius = .005;
		cntrop->PocketRoughEntry.Helix.ClearanceXY = .005;
		cntrop->PocketRoughEntry.Helix.ClearanceZ = .05;
		cntrop->PocketRoughEntry.EntryMode = Mastercam::Operations::Types::PocketRoughEntryMode::Helix;
		cntrop->DepthCuts.UseIslandDepths = false;
		cntrop->CutParams.LinearizeTolerance = .0001;
		//lead in
		//entry params
		//end lead in
		//set feedrate
		cntrop->NCIName = _T("Pocket #1");
		cntrop->Name = _T("Pocket operation created via API");
			return 0;
		DB_LIST_ENT_PTR ptr{};
		bool succf{};
		op.dcuts.stock_t_l = 0.0;
		op.misc.on = false;
		op.u.prm_pkt.add_finish = false;
		op.u.prm_pkt.climb = false;
		op.u.prm_pkt.taper.on = false;
		op.u.prm_pkt.rough = true;
		op.u.prm_pkt.ch_sort.sort_method = 1;
		op.u.prm_pkt.co_spir_disp = true;
		op.u.prm_pkt.add_finish = true;
		op.u.prm_pkt.rgh_step_pct = 50;
		//op.u.prm_pkt.rgh_entry.on = true;
		//op.u.prm_pkt.rgh_entry.entry_type = 0;
		//op.u.prm_pkt.rgh_entry.helix.angle = TWO_PI / 36;
		//op.u.prm_pkt.rgh_entry.helix.z_clear = .05;
		double min = .01, max = .5;
		//op.u.prm_pkt.rgh_entry.helix.rad_min = min;
		//op.u.prm_pkt.rgh_entry.helix.rad_max = max;
		//op.u.prm_pkt.rgh_entry.helix.xy_clear = .005;
		short stk_mde = 2;
		short cut_mthd = 2;
		op.u.prm_pkt.cp.cmp_to_tip;
		double dbl = .005;
		op.u.prm_pkt.cp.lin_tol = dbl;
		op.u.prm_pkt.cut_method = cut_mthd;
		op.u.prm_pkt.tool_down = true;
		short pck_typ = 0;
		op.dcuts.tool_down = true;
		op.u.prm_pkt.pock_type = pck_typ;
		op.u.prm_pkt.finish = false;
		op.u.prm_pkt.spiral_out = true;
		op.u.prm_pkt.rgh_step_pct_flat = true;
			op.u.prm_pkt.finish = true;
			op.u.prm_pkt.rough = false;
			op.u.prm_pkt.fin_n = 1;
			op.u.prm_pkt.fin_step = .01;
			op.u.prm_pkt.rgh_entry.on = false;
			op.u.prm_pkt.fin_outer = true;
			op.u.prm_pkt.fin_w_rgh = false;
			op.u.prm_pkt.n_spring_cuts = 0;
		repaint_graphics();
	return 1;
int ChookSdkLibrary::OperationManagerUtilities::CreateOperations::MakeDrillOpFromGeometry(const ChookSdkLibrary::OperationManagerUtilities::MakeDrillOpFromGeometryParams ^params)
////double clearancePlane, double feedPlane, double topOfStock, double depth, int viewId, int FeedRate, int spindlespeed, int slot, int targetlevel
	operation op = {};
	const auto views = Mastercam::Support::SearchManager::GetViews();
	Mastercam::Database::ChainManager::ChainTolerance = .0001;
	//create a new mastercam drilling opertation
	auto drilloperation = gcnew Mastercam::Operations::DrillOperation;
	//use the chainmanager to get the geometry from the mastercam database //closed chains only
	const auto chains = Mastercam::Database::ChainManager::ChainAll(true, false, nullptr, Mastercam::Database::Types::ChainDirectionType::Clockwise, params->targetlevel);
	//array
	int size = 2;
	System::Collections::Generic::List<Mastercam::Database::CurveGeometry^>^ curvegeometry = gcnew System::Collections::Generic::List<Mastercam::Database::CurveGeometry^>(0);
	//array<Mastercam::Database::CurveGeometry^>^ curvegeometry;
	if (chains != nullptr && chains->Length > 0)
		//loop through the chains of the target geometry
		for (auto i = 0; i < chains->Length; i++)
			//System::Windows::Forms::MessageBox::Show("chains Detected");
			//get the tot
			//retrieve the geometry in the target level
			const auto selectedEnts = Mastercam::Database::ChainManager::GetGeometryInChain(chains[i]);
			if (selectedEnts != nullptr)
				//loop through the geometry assicuated with the chains
				for (auto j = 0; j < selectedEnts->Length; j++)
					//System::Windows::Forms::MessageBox::Show("Curvegeometry Detected");
					//add the geometry to the list
					curvegeometry->Add(selectedEnts[j]);
	System::Collections::Generic::List<Mastercam::Curves::ArcGeometry^>^ arcgeometry = gcnew System::Collections::Generic::List<Mastercam::Curves::ArcGeometry^>(0);
	//convert the list to an array
	auto curvearray = curvegeometry->ToArray();
	//loop through the array
	for (auto i = 0; i < curvearray->Length; i++)
		//declare the arc type id as a variable
		const auto arcType = Mastercam::Curves::ArcGeometry::typeid;
		//get the current type id
		const auto gt = curvearray[i]->GetType();
		//System::Windows::Forms::MessageBox::Show(gt->ToString());feedrate
		//check if we have an arc
		if (gt == arcType)
			//add the arc into the arc list
			arcgeometry->Add(dynamic_cast<Mastercam::Curves::ArcGeometry ^> (curvearray[i]));
			//System::Windows::Forms::MessageBox::Show("Arc Detected");
	//convert the arc list to an array
	auto arcarray = arcgeometry->ToArray();
	//define a variable to count the amount of arcs assigned as drill point
	auto ptcount = 0;
	//loop through the arc array
	for (auto i = 0; i < arcarray->Length; i++)
		auto drillPt = gcnew Mastercam::Database::DrillPoint(arcarray[i]);
		if (arcarray[i]->Validate())
			if (!arcarray[i]->Blanked)
				if (arcarray[i]->Data.Radius > 0.0)
					drilloperation->DrillPoints->Add(drillPt);
					ptcount++;
	drilloperation->ReverseDrillPoints();
	//	drilloperation->UpdateToolSettings();
	drilloperation->AssignMillToolBySlot(params->slot);
	drilloperation->OperationTool->SpindleRotation = 0;
	//linking params
	drilloperation->Linking->FeedPlane = params->feedPlane;
	drilloperation->Linking->Depth = params->depth;
	drilloperation->Linking->ClearanceOn = true;
	drilloperation->Linking->Clearance = params->clearancePlane;
	drilloperation->Linking->Retract = params->clearancePlane;
	drilloperation->Linking->RetractOn = true;
	drilloperation->Linking->TopStock = params->topOfStock;
	drilloperation->MiscValues->UseValuesFromPost = true;
	drilloperation->ForceToolChangeOn = false;
	drilloperation->RotaryAxis.Enabled = false;
	drilloperation->PlungeRate = 75.0;
	drilloperation->RetractRate = 500.0;
	//lead in
	//entry params
	//end lead in
	drilloperation->SpindleSpeed = params->spindlespeed;
	//set feedrate
	drilloperation->FeedRate = params->FeedRate;
	drilloperation->NCIName = _T("Drill #1");
	drilloperation->Name = _T("Drilling operation created via API");
	drilloperation->Commit();
	//cntrop->Regenerate();
	bool succf{};
	op.op_idn = drilloperation->GetOperationID();
	op.cmn.stk_remain = 0.0;
	op.misc.on = false;
	op.u.prm_drl.brk_thru = 0.0;
	op.u.prm_drl.calcDepthFromStock = false;
	op.u.prm_drl.cycle = 0;
	op.u.prm_drl.drill_tip = false;
	op.u.prm_drl.dwell = 0.0;
	op.u.prm_drl.peck1 = 0.55;
	op.u.prm_drl.peck2 = 0.05;
	op.u.prm_drl.peck_clr = 0.5;
	op.u.prm_drl.start_hole = false;
	op.u.prm_drl.sub_pgm = false;
	op.u.prm_drl.do_custom = false;
	op.u.prm_drl.TipControl = 0;
	op.u.prm_drl.sort_method = 1;
	drilloperation->Regenerate();
	auto drillcloner = InitCloneDrillingOperationsFunctions();
	MastercamChookSdk::OperationsManager::CloneDrillingOperationsParams drillclonerparams;
	drillclonerparams.op_id = op.op_idn;
	auto newop = drillcloner.clonedrillingoperations(drillclonerparams);
	repaint_graphics();
	return 1;
Target Mastercam 2018 & 2020
