Hi,
I upgrade the Api Tools Chook it now will check if a tool fits into the geometry before chain assignment and translate pocket geometry to the nearest flat surface.
C# Source Code :
// <copyright file="Main.cs" company="Peter Evans, Inc.">
//   Copyright (c) 2020 "Peter Evans, Inc.
// </copyright>
// <summary>
// </summary>
namespace ApiTools
    using Mastercam.App;
    using Mastercam.App.Types;
    using System.Linq;
    public static class I
        private static System.Collections.Generic.List<T> DistinctSorted<T>(
    this System.Collections.Generic.IEnumerable<T> source, System.Func<T, T, bool> areEqual)
            source = source.OrderBy(x => x);
            var lastElement = default(T);
            var result = new System.Collections.Generic.List<T>();
            foreach (var sourceElement in source)
                if (!areEqual(sourceElement, lastElement) || !result.Any())
                    result.Add(sourceElement);
                    lastElement = sourceElement;
            return result;
    public class Main : NetHook3App
        #region Public Override Methods
        /// <summary>
        /// The main entry point for your NETHook.
        /// </summary>
        /// <param name="param">System parameter.</param>
        /// <returns>A <c>MCamReturn</c> return type representing the outcome of your NetHook application.</returns>
        public override MCamReturn Run(int param)
            var ret = CreateGeometryProfile(true,true);
            var tlslot3 = ChookSdkLibrary.OperationManagerUtilities.CreateOperations.makendmil(3, .75, 1.0, .25, .25, 420, 18000, "T3 0.250 endmill", 180.0);
            ChookSdkLibrary.OperationManagerUtilities.MakePocketOpFromChainsParams Params = new ChookSdkLibrary.OperationManagerUtilities.MakePocketOpFromChainsParams();
                Params.level = 12500;
				Params.clearancePlane = 0.25;
				Params.feedPlane = 0.25;
				Params.topOfStock = 0.0;
				Params.depth_incremental = true;
				Params.viewId = 0; // ???
				Params.cuttercompdir = Mastercam.Database.Types.CutterCompDir.CutterCompRight;
				Params.chndir = Mastercam.Database.Types.ChainDirectionType.CounterClockwise;
				Params.FeedRate = 420.0;
				Params.spindlespeed = 18000;
				Params.slot = tlslot3;
            ChookSdkLibrary.OperationManagerUtilities.CreateOperations.MakePocketOpFromChains(Params);
            return ret;
        private static void SelectWireframeInListOfList(System.Collections.Generic.List<int[]> BtmWireframeDatabsePointerList)
            foreach (var WireframeDatabasePointerList in BtmWireframeDatabsePointerList)
                SelectWireFramInList(WireframeDatabasePointerList);
        private static void SelectWireFramInList(int[] WireframeDatabasePointerList)
            foreach (var WireframeDatabasePointer in WireframeDatabasePointerList)
                if (!ApiToolsWrapper.GeometryUtilities.DatabasePointerBits.GetDatabasePointerBits(WireframeDatabasePointer, 2))
                    ApiToolsWrapper.GeometryUtilities.DatabasePointerBits.SetDatabasePointerBits(WireframeDatabasePointer, 2, 1);
        public static MCamReturn CreateGeometryProfile(bool Translate,bool CheckToolFit)
            var TopWireframeDatabsePointerList = new System.Collections.Generic.List<int[]>();
            var BtmWireframeDatabsePointerList = new System.Collections.Generic.List<int[]>();
            var SilhbndWireframeDatabsePointerList = new System.Collections.Generic.List<int[]>();
            int[] DataBasePointerList = ApiToolsWrapper.GeometryUtilities.DataBaseSearch.GetEntitiesMask(65536, true, 0, 0);
            if (DataBasePointerList == null)
                System.Windows.Forms.MessageBox.Show(
                "Error (0) selected solids were detected!"
                + System.Environment.NewLine
                + "Select (1) solid");
                return MCamReturn.ErrorOccurred;
            if (DataBasePointerList.Length > 1)
                "Error  ("
                + DataBasePointerList.Length.ToString()
                + ") selected solids were detected!"
            var faceTagLists = ApiToolsWrapper.GeometryUtilities.SolidTag.GetFlatFaceTagArray(DataBasePointerList[0]);
            var MaxDepth = ApiToolsWrapper.GeometryUtilities.SolidInformation.GetMaxzDepthOnSolid(DataBasePointerList[0]);
            var MinDepth = ApiToolsWrapper.GeometryUtilities.SolidInformation.GetMinzDepthOnSolid(DataBasePointerList[0]);
            if (MinDepth < -.002 && MinDepth > .002)
            System.Windows.Forms.MessageBox.Show("Error  ("
            + ") selected solids were detected at the incorrect zDepth!!"
            + "Position the top of the 3D model at Z0.");
            if (faceTagLists.Count != 3 || faceTagLists == null)
            ApiToolsWrapper.GeometryUtilities.DatabasePointerBits.BlankUnblankAllEntsMask(0, true, true);
            for (var i = 0; i < faceTagLists.Count; i++)
                switch (i)
                    case 0:
                            CreateEdgesFromFaceTag(BtmWireframeDatabsePointerList, faceTagLists, i);
                            break;
                    case 1:
                            CreateEdgesFromFaceTag(TopWireframeDatabsePointerList, faceTagLists, i);
                            break;
                    case 2:
                            if (Translate)
                                foreach (var faceTag in faceTagLists[i])
                                    Mastercam.IO.LevelsManager.SetMainLevel(7000);
                                    var eptrarray = ApiToolsWrapper.GeometryUtilities.SolidTag.CreateSurfaceFromFaceTag(faceTag);
                            break;
            SelectWireframeInListOfList(TopWireframeDatabsePointerList);
            ApiToolsWrapper.GeometryUtilities.Color.ColorInnerOuterSelectedChain(10, 15, 1000, 10000);
            SelectWireframeInListOfList(BtmWireframeDatabsePointerList);
            ApiToolsWrapper.GeometryUtilities.Color.ColorInnerOuterSelectedChain(20, 25, 2000, 20000);
            if (!ApiToolsWrapper.GeometryUtilities.DatabasePointerBits.GetDatabasePointerBits(DataBasePointerList[0], 2))
                ApiToolsWrapper.GeometryUtilities.DatabasePointerBits.SetDatabasePointerBits(DataBasePointerList[0], 2, 1);
            ApiToolsWrapper.GeometryUtilities.SilhouetteBoundaryUtilities.CreateSilhouetteBoundary(500, 50, 55, 5000, 50000);
            ApiToolsWrapper.GeometryUtilities.Spline.SplineAll();
            ApiToolsWrapper.GeometryUtilities.Delete.DeleteDuplicateChains(1000, 5000, false, true, 0);
            ApiToolsWrapper.GeometryUtilities.Delete.DeleteDuplicateChains(2000, 5000, false, true, 0);
            if (Translate == true)
                ApiToolsWrapper.GeometryUtilities.ApiMacros.TranslateEntitiesToSurfaces();
            if (CheckToolFit == true)
                ApiToolsWrapper.GeometryUtilities.ApiMacros.CheckOffsetSize();
            Mastercam.IO.SelectionManager.UnselectAllGeometry();
            return MCamReturn.NoErrors;
        private static void CreateEdgesFromFaceTag(System.Collections.Generic.List<int[]> TopWireframeDatabsePointerList, System.Collections.Generic.List<System.Collections.Generic.List<int>> faceTagLists, int i)
            if (faceTagLists[i] != null)
                    Mastercam.IO.LevelsManager.SetMainLevel(100);
                    var eptrarray = ApiToolsWrapper.GeometryUtilities.SolidTag.CreateSolidEdgesArrayFromFaceTag(faceTag);
                    TopWireframeDatabsePointerList.Add(eptrarray);
        #endregion
Requires ApiToolsWrapper.dll (C++/Cli)
<this if statement should be || not && since this case would never happen where a number is larger and smaller than a given number at the same time..>
In its current state it is ignored..
Sign in to follow this
