Sign in to follow this
LMVUICHARD
Corners coordinates of a box selection
Hello,
Is it possible to retrieve the corners coordinates of a user box selection ?
(in view coordinates AND screen coordinate, for a projected application, i will need the both...)
For example,  after a line like this :
SelectionManager.BoxSelectGeometry("Select the holes", New GeometryMask(True), 1)
How is it possible to know the corner position of the user selection box?
I have try to use and understand the "McUIEvent.GetEvent Method", without success.
I don't understand  how i must use the UIEventData Class, Is it possible to give me some example with this Method and this class?
Thanks in advance!
I use VS2019 Vb.net, with Mastercam 2020
The SelectionManager.BoxSelectGeometry method does not provide access to the (2) corners of the user sketched window.
There is the SelectionManager::WindowSelect method where your NET-Hook supplied the corner of the window.
The first question would be, exactly what are you wanting to do using the UIEventData Class?
(You almost always use this along with a modeless dialog.)
I have a (C#) NET-Hook project the uses a GetEvent loop.
If you email us with your company contact to [email protected] we can get you a copy of this sample project.
Thank you for your quick answer.
Probably, one again more, I’ve gave you bad explanations, sorry my English isn’t, one again more, very clear…
It's a part of a big customer project we have, and to solve it, we are looking for the better solution. Inside this project, it can be a way if it's possible to make somes extractions directly Inside a Mastercam session that's the reason i try to test that.
What I want to do:
-              Ask the user to make a box selection
-              Letting him to do that on the graphics screen area
-              After it’s done, retrieve the box corners values the user has done
-              With these values, launch the two treatments I need, on Entities and on bitmap image. I think I have the ability to do that.
I have seen the SelectionManager.WindowSelect method, but it’s not what I want. With that I must give the corners coordinate, not retrieve the user's one, it’s exactly the reverse…
As asked, I've send an e-mail at [email protected] with more explanations.
Maybe do both?
https://docs.microsoft.com/en-us/dotnet/api/system.windows.forms.cursor.position?redirectedfrom=MSDN&view=netcore-3.1#System_Windows_Forms_Cursor_Position
Get the cursor position from windows and pass it to mastercam.
What do you mean treatments?
If you are selecting geometry there are several ways to extrapolate the minimum maximum xyz coordinates, such as getting an array of centerpoints then finding the limits or the arcs.(probably easier to use creep_record at that point rather than messing with the views to get the arcs position.
Thanks for your answers Byte (Peter?)!
For the bitmap side, I have already tryed to use the windows graphic management.
But there is a big issue with 4K screens (3840x2160).
To manage with these, it's mandatory to make some additionnal declarations in the dot.net project
(Add a manifest file, make some declarations (Win10 app, Dpi Aware app, etc..).
https://docs.microsoft.com/en-us/dotnet/framework/winforms/high-dpi-support-in-windows-forms
I have try to do it and that run normally on a stand alone windows form.
But when i try to do that inside a NETHook project, and run it inside Mastercam, that's wrong,
these declarations have no effect and all cursor position or windows dimensioning refers to a
screen resolution with 1920x1080  one quater of the real screen...
It's not possible or I have not been able to properly insert the statements.
I believe that in any case the app inherits The Windows settings of Mastercam, and I can not change them.
That's the reason I want to try with NetHook commands, I hope that will gave a different result.
For the other side, sorting of Mastercam entities, for sure, there is many ways to do that,
If it's possible to retrieve the view coordinates of user's box, i think it will be easier,
i have some ideas to achieve that (most based on arrays, yes...).
Thanks for your help!
2 hours ago, LMVUICHARD said:
(Peter?)!
Yes sir,
Try linking to this DLL the way you do to NEThook_3.DLL https://github.com/PeterRussellEvans/ApiToolsManagedMc2020Dll
Place it in your -> Program Files/Mcam2020 Folder
Then you can access it from VB.net
Imports Mastercam.App
Imports Mastercam.App.Types
Imports Mastercam.IO
Imports Mastercam.Support
Imports Mastercam.Curves
Imports Mastercam.Database.Types
Imports Mastercam.Math
Public Class NethookMain
    Inherits NetHook3App
#Region "Public Methods"
    ''' <summary>
    ''' This method is designed to be the main entry point for your NetHook app. This is where your app should do
    ''' all of the things it's supposed to do and then return an MCamReturn value representing the outcome of your
    '''  NetHook application.
    ''' </summary>
    ''' <param name="param">Parameter is not used</param>
    ''' <returns>A <c>MCamReturn</c> return type.</returns>
    ''' <remarks></remarks>
    Public Overrides Function Run(param As Integer) As MCamReturn
        Dim a As ArcGeometry
        If SearchManager.GetSelectedGeometry().Any() Then
            SelectionManager.UnselectAllGeometry()
        End If
        a = SelectionManager.AskForGeometry("Select Arc", New GeometryMask(False, False, True, False, False, False, False, False))
        If IsNothing(a) = True Then
            System.Windows.Forms.MessageBox.Show("No Arc Found In .NET")
            Return MCamReturn.NoErrors
            Exit Function
        End If
        Dim ents = ApiTools.Database.PointerArrays.GetEntitiesMask(4, True, 0, 0)
        If IsNothing(ents) = True Then
            System.Windows.Forms.MessageBox.Show("No Arcs Found in C++")
            Exit Function
        End If
        Dim lstOfPoints = New List(Of Mastercam.Math.Point3D)()
        For Each arrayItem In ents
            Dim creepamount = 0.002
            ApiTools.CreepRecord.GetPointsFromWireframe(arrayItem, creepamount, lstOfPoints)
            Next
            GraphicsManager.ClearColors(New GroupSelectionMask(True))
            GraphicsManager.Repaint(True)
            a = Nothing
        If IsNothing(lstOfPoints) = True Then
            System.Windows.Forms.MessageBox.Show("No Points Found in C++")
            Exit Function
        End If
        For Each arrayItem In lstOfPoints
            System.Windows.Forms.MessageBox.Show("X = " + arrayItem.x.ToString() + " Y = " + arrayItem.y.ToString() + " Z = " + arrayItem.z.ToString())
        Next
    End Function
#End Region
End Class
This will give you an array of points that represent all the positions in the arc.
