LMVUICHARD
SearchManager.GetOperations ONLY for milling operations?
I meet some dificulties with the SearchManager.GetOperations Method.
It seems that Method run only with milling operations.
If i try to run it with a basic lathe machining file, with some turning operations and some drilling,
the code below returns only the drillings operations.
With a milling file, it's run properly, but impossible with a lathe file (i don't have try with a wire file, but it will be probably the same).
I have try with some modifiers, (you can see in comments),  but result is the same.
What is the way in NetHook to load an array with really all operations, not depending machining technology?
i need only access status (get)  in the Msbox, and get or set only posting, displayToolpath.
Its very easy to test, the code is only to paste in a standard Mastercam vb.net template, and i join the mastercam test lathe file too.
Thanks in advance
Mastercam version:2020
Code:
 Private Sub OnOkView(sender As Object, e As EventArgs) Handles buttonOK.Click
            Dim Tl As Tool = Nothing
            'Dim Optp As OperationType = Nothing
            'Dim Operationss = SearchManager.GetOperations(-1, -1, True, Tl)
            'Dim Operationss = SearchManager.GetOperations(True)
            Dim Operationss = SearchManager.GetOperations()
            For IndxBcl = 0 To Operationss.Count - 1
                If Operationss(IndxBcl).Selected = True Then
                    MsgBox("Opération ID:" & Operationss(IndxBcl).GetOperationID() & " Name:" & Operationss(IndxBcl).Name & " Tool:" & Operationss(IndxBcl).OperationTool.Number & " Posting:" & Operationss(IndxBcl).Posting & " Display:" & Operationss(IndxBcl).DisplayToolpath & " Dirty:" & Operationss(IndxBcl).Dirty)
                End If
            Next
        End Sub
Julien-LMV2.mcam
Thanks in advance
Code:
                End If
            Next
        End Sub
Julien-LMV2.mcam
Unless NEThook has updated it does not support lathe or wire operations,
like many things this would probably require c++
If you explain in great detail, what you are trying to do, I could write you a wrapper class for it, that you could use kn vb.net
You could import operations thats about it..
SearchManager in the NET-Hook API currently only supports Mill type operations.
A simple C++/CLI project that creates an interop DLL that your NET-Hook add-in can use would be simple to create. You would add a reference to this DLL. just like you do for the NETHook3_0.DLL to get access to the functionality in the standard API.
I have such a project. If you email -> SDK.mastercam.com and let us know you company contact information and what version of Mastercam this is for, I can probably set you up.
It appears you are looking for these data items in each operation -
Operation Name (comment)
Operation ID (number)
Operation Type ("type" code)
Operation Tool Number (and probably also the Tool Slot Number)
“Toolpath Visibility” status
“IsDirty” status
“Selected” status
“Posting” status (Is the operation ghosted?)
*Are there more?
Wow… thanks for the informations.
Roger as asked, i've send you an email.
Thanks for all!
“IsDirty” status
“Selected” status
*Are there more?
Hi Roger,
are you passing all the data as an array from C++/CLI to managed NET-Hook? I use similar approach to expose some Chook functions which are not available in NET-Hook, but I only pass some values, strings. I use Text.StringBuilder in one case to receive a list of Stock Model (operations) names.
Is there a better approach and/or better for multiple data like this example above?
TIA, Peter
1 hour ago, Peter - NCS Ltd. said:
Hi Roger,
TIA, Peter
You can export arrays like this from cli :
//we need a class to export
#pragma once
namespace ApiTools
	namespace Database
		public ref class PointerArrays abstract sealed
		public:
			static array<System::Int32>^ GetWireframeOnLevel(const int level1);
//get an array of database pointers cast as int32 representing wireframe found on the specified level
array<System::Int32>^ ApiTools::Database::GetWireframeOnLevel(const int level1)
	auto EntityPointerList = gcnew System::Collections::Generic::List<System::Int32>;
	long count = 0;
	bool bSuccf;
	ent entity;
	DB_LIST_ENT_PTR foundPtr;
	DB_LIST_ENT_PTR eptr = db_start;
	bool found;
	found = false;
	long selectionMask = ALL_ENTITIES_MASK;
	for (; ; ) // loop until "break;" command
		get_ent(&eptr, &foundPtr, &entity, ALIVE_BIT,//get entity//found entity pointer//found entity new pointer//entity class object//sel bit//entity type
			selectionMask, // entity types
			&bSuccf); // entity successfully read
			if (!bSuccf) // No more entities
				break;
			if (bSuccf) // entity found loop once
				if (entity.level == level1)
					if (entity.id == S_ID || entity.id == NB_ID || entity.id == A_ID || entity.id == L_ID)
						EntityPointerList->Add(static_cast<System::Int32>(PtrToInt(entity.eptr)));
						count++;
	if (EntityPointerList->Count > 0)
		return EntityPointerList->ToArray();
	return nullptr;
If you are passing a known number of string you could create a struct in cli and pass that to your function :
namespace mynamespace
public ref struct OperationValues
System::String ^ param1;
System::String ^ param2;
public ref class GetOperationValuesClass{
public :
void GetOperationValues(OperationValues^ values)
values->param1 = "firststring";
values->param2 = "secondstring";
private:
Thank you Peter, that makes sense! I'll play with it.
1 hour ago, baby byte said:
Sorry, while this will work for importing to c++ there appear to be issues with c# and structs
 https://stackoverflow.com/questions/35912787/using-c-cli-structs-from-c-sharp
I would go ahead with the array  instead
I think you are misunderstanding that thread.  The example below works for me.
OperationService.h
#pragma once
namespace OperationServiceNative
	public ref struct OperationData
		System::String^ Comment;
		int ID;
		int Type;
		int ToolNumber;
	public ref class OperationService
	public:
		OperationService();
		OperationData^ GetOperationData(int opID);
		~OperationService();
OperationService.cpp
#include "pch.h"
#include "OperationService.h"
OperationServiceNative::OperationService::OperationService()
OperationServiceNative::OperationData^ OperationServiceNative::OperationService::GetOperationData(int opID)
	OperationData^ opData = nullptr;
	auto operation = TpMainOpMgr.GetMainOpList().OpByID(opID);
	if (operation != nullptr)
		opData = gcnew OperationData();
		System::String^ commentString = gcnew System::String(operation->comment);
		opData->Comment = commentString;
		opData->ID = operation->op_idn;
		opData->Type = operation->opcode;
		opData->ToolNumber = operation->tl.tlno;
	return opData;
OperationServiceNative::OperationService::~OperationService()
Main.cs
namespace MyNetHook
    using Mastercam.App;
    using Mastercam.App.Types;
    using OperationServiceNative;
    public class Main : NetHook3App
        public override MCamReturn Run(int param)
            var opService = new OperationServiceNative.OperationService();
            var opData = opService.GetOperationData(1);
            return MCamReturn.NoErrors;
28 minutes ago, Zaffin_D said:
void OperationServiceNative::OperationService::GetOperationData(int opID,OperationServiceNative::OperationData^ data);//can this be done?
I was trying to take the struct as a parameter,
not sure if that is the reason i was having
trouble. Nice example.. :thumbsup::turned:
Yes, you can pass a struct, see below
File: OperationService.h
#pragma once
	public value struct OperationData
		int ID;
		int Type;
		int ToolNumber;
	public:
		OperationService();
		bool CreateOperation(OperationData% opData);
File: OperationService.cpp
#include "pch.h"
	return opData;
bool OperationServiceNative::OperationService::CreateOperation(OperationData% opData)
	//Code to create an operation with the OperationData struct
	return false;
File: Main.cs
namespace MyNetHook
            var opService = new OperationService();
            var opData = (OperationData)opService.GetOperationData(1);
            var newOpData = new OperationData()
                Comment = "A new op",
                ID = 2,
                Type = 1,
                ToolNumber = 1
            var isSuccess = opService.CreateOperation(ref opData);
This is a way better way (imo) to import/export data.
Functions that take structs that take functions as parameters have no requirement to modify the function name and header file when adding/removing parameters..
Hi Zaffin,
are you willing to share this both VC projects on GitHub?
TIA,
Peter
2 hours ago, Peter - NCS Ltd. said:
Hi Zaffin,
TIA,
Peter
Yes.  Here you are.
  • Thanks 2
Great topic and good to see 3 very brilliant people working and sharing information. :thumbsup:
