akuser
Operation comment question
Hello,
I am using MP post for 3x VMC, I have edit the post to move M01 from before M06 to after M06 like the code I have pasted here.
Quote
G5.1 Q1
(ROUGH OUTSIDE)
(COMPENSATION TYPE - WEAR COMP)
N1 T18 M6
M01
 (2 INCH SHELL MILL 4.5 LOT)
( MAX -  Z2. )
( MIN -  Z-4.3016 )
G00 G17 G90 G54 X-3.025 Y-1.25 S8500 M03
G43 H18 Z2. T1
M08
Z.1
My question is how can I edit the post to move the operation comment location like this one
Quote
G00 G17 G20 G40 G80 G90
G91 G28 Z0.
G5.1 Q1
(ROUGH OUTSIDE)  <--- Move from here
N1 T18 M6
M01
(ROUGH OUTSIDE) <--- to here
( MAX -  Z2. )
( MIN -  Z-4.3016 )
G43 H18 Z2. T1
M08
Z.1
G G01 Z.05 F150.
Thank you very much
You will need to move the location of the 'comment$' Command Variable.
Typically, the 'comment$' command is setup to "dump all the buffered comment strings", at whatever location you see that Command Variable.
'comment$' needs to be on a line, all by itself. (It must also have at least 1 space character in front of it. Typical "indent" spacing is 6 space characters.)
So, in your existing Post, locate the line of code that has 'comment$' on it, and place a Pound Sign (or Hash Mark, depending on your word choice). [ # ]
This will 'comment out' the line of code.
Now, simply insert a new blank line, after the line where your "M01" is coming out, and then enter  '     comment$'.
Your Operation Comment will be output after the "M01" line.
Thank you for your rely,
I have try to edit my post file like this but still not worked.
Quote
ptlchg_com      #Tool change common blocks
      if force_output | sof,
        result = force(ipr_type,ipr_type)
        result = force(absinc$,absinc$)
        result = force(plane$,plane$)
      pcom_moveb
      pcheckaxis      #Check for valid rotary axis
      if sof, uninhibit_probe$
      #ptoolcomment
      if sof & scomm_sav <> snull,
        spaces$ = 0
        n$, pspc, scomm_str, *scomm_sav, scomm_end, e$
        spaces$ = sav_spc
      if sof = 0, scomm_sav = snull
      #comment$
      #pcomment3
      pmisccheck
      pcan
      if stagetool >= zero,
        if omitseq$ = 1 & tseqno > 0,
          if tseqno = 2, n$ = t$
          pbld, *n$, *t$, *sm06, e$
          pbld, n$, *sm01, e$
          comment$
          pbld, n$, ptoolcomm, e$
        else, [
        pbld, n$, *t$, *sm06, e$
        pbld, n$, *sm01, e$
        comment$
      spaces$=0
      if output_z = yes$,
and here is my nc file
Quote
G91 G28 Z0.
G5.1 Q1
(SPOT DRILL M4 HOLE)
M08
N1 T5 M6
M01
 (3/8 SPOTDRILL 3.75 LOT)
(MAX - Z2.)
(MIN - Z-.0675)
G00 G17 G90 G55 X5.1378 Y-.8573 S2000 M03
G43 H5 Z2. T9
Z.1
there is something wrong with my post?
Thank you
Thank you Colin, I have make my post work by add the code for comment
Quote
		  pbld, n$, *sm01, e$
		  #pbld, n$, ptoolcomm, e$
        else, [
		pbld, n$, *sm01, e$
        spaces$ = 0
		comment$
		"(",*t$, "-",pstrtool, ")", e$
I have another question the line
Quote
I used that line for Tool number and comment so the Setup guy can check with tool list. But my question is does it is proper code to use?
here is my nc code output
Quote
G5.1Q1
N5 T5 M06
M01
(T5-3/8 SPOTDRILL 3.75 LOT )
(MAX - Z2.)
(MIN - Z-.0675)
G43 H5 Z2. T9
M08
N9 T9 M06
M01
(DRILL M3 HOLE DEPTH 0.259)
(T9-0.0995 DRILL #39 )
(MAX - Z2.)
(MIN - Z-.4253)
G00 G17 G90 G55 X6.4961 Y-.7874 S3500 M03
G43 H9 Z2. T10
The first tool still do not have the operation comment.
Can anyone tell me how to fix it or which post block to looking for.
Thank you
Best Regard
Perhaps psof$?
