MC 2021 Won't run Verify
Rstewart
If able, put your simple file on here, maybe we can replicate. I've had this happen with a few other instances as well. Including invalid tools(custom tools saved on someone elses pc, or directory bad), and there's a temp file you can try clearing.
C:(your HDD)>users>(your name)>appdata(this folder is naturally hidden, to be able to view it you need to go to "folder explorer options"(search it windows 10), >view tab>show hidden files, folders, drives bubble......then within app data go >local>there's a temp folder you can delete everything in, just skip what it won't let you(MAKE SURE YOU CLOSE MASTERCAM FIRST OR YOUR FILE WILL BE BAD), there's also a fodler within Local named "CrashDumps" that you can delete. Then retry.
  • 1 year later...
There are many changes in 2022 that have reduced these occurrences, and there will be more in 2023.
One of the big causes is if you're using a file that had a specific machine in the Simulator options, and now you open and try to verify an operation on a PC that doesn't have that machine. See below- If I saved this and sent it to someone without a UMC in the MachSim folder, they might have trouble launching Verify. Even though the machine model isn't used for Verify, it still tries to load up all the settings in these panes and if the machine doesn't exist, there can be issues with the load that give you the Verify unknown error.
Even if you don't think this is your cause, when you run into the Verify error, try going into the options and toggling that machine selection to something else and then back, then retry the Verify launch.
Hope this helps.
  • 2 weeks later...
