Mill/Turn question
gcode
I'm programming my first program on out new Mori NT6000
I'm using a 1.5" insert drill defined as a lathe drill to start a hole in the center of a slug
Then I take a 2" insert mill and open the hole up to 4" with a C axis face mill toolpath
The problem  I'm having is that the 2" insert mill path is not reflected in the lathe stock definition
so my subsequent tool paths won't process due to stock collisions
I'm faking it my defining my 1.5" insert drill as a 4" flat bottom drill
It works, but it's really lame.. and dangerous
Is there any way to make the lathe stock get updated by a milling toolpath ?
Why not use your insert drill as a boring bar to rough out to your diameter?
its a test program proving out a new Postability  post proccesor
the file is also being used as a training file so I wanted to include some live spindle stuff  as well
https://us.dmgmori.com/products/machines/turning/turn-mill/nt/nt-6600-dcg
19 hours ago, gcode said:
Jesus G!  You must of grew up with the biggest toys in the sandbox. :respect:
21 hours ago, gcode said:
I just tried this and it worked properly.
I was surprised at how long it took such a simple stock model to process though
Try and loosen up the stock tolerance.  Round stock needs a lot of triangles to define, and with your Behemoth parts,  I would loosen them up quite a bit.
I found the problem
For my first attempt, I was using the original stock, then selecting all my lathe ops to create the stock model
The 2nd time, I found the lathe ops dropdown and selected the last lathe op.... than ran MUCH better
