Dhananjay @Mastercam India
Macro Variable Value Increment is not getting
Hello everyone,
I need help in below macro variable value  addition with the  increment of  1
if macro_active,      #25/06/20
	  submacro = 101
	  if angle_from_x_plus <> prv_angle_from_x_plus, submacro = 101 + n$
	  pbld, *submacro, no_spc$, *angle_from_x_plus, e$
Result=
#101=
#102=
#103=
so on ......
I'm not seeing what you're wanting here...  Can you share a zip2go and posted code edited to what you want?
n$ may not be the best variable to use since it can be used in a lot of places and might be incrementing at each location. You might be better of to create a new variable that you increment instead. Or initialize submacro at 100, and just add 1 to that variable at each instance.
Thank You sir ! I'm getting correct increment value
submacro : 100 (By  initialization the Numeric variable  )
Also, be careful to recognize changes to Variable Modality.
  • The 'prv_' variable value only gets updated when a value is output to the NC File.
  • If you are only using a variable "internally" in your Post calculations, then the 'prv_' value will never be updated, because the 'current value' of the variable is never written to the NC File, so the 'replace prv_ value with current' action never takes place.
  • If the variable is only used by you 'internally', then you can use the "Update Variable Modifier" (!) by putting the Exclamation Mark in front of the variable name. You must be careful to do this "at the end of the intended action", since you only want that 'update action' to take place "once", before you loop around to test the condition again.
  • This is why you will typically see the "variable updates" at the end of a major post block, like 'posf$', 'ptlchg$', and 'ptlchg0$'.
This is from 'MPFAN.PST', notice the "Variable Updates" at the end of the Post Block:
ptlchg$          #Tool change
      pcuttype
      toolchng = one
      if mi1$ = one, #Work coordinate system
        pfbld, n$, *sg28ref, "X0.", "Y0.", e$
        pfbld, n$, sg92, *xh$, *yh$, *zh$, e$
      inhibit_probe$
      if prog_stop = 1, pbld, n$, *sm01, e$
      if prog_stop = 2, pbld, n$, *sm00, e$
      pcom_moveb
      pcheckaxis
      ptoolcomment
      comment$
      pcan
      result = newfs(15, feed)  #Reset the output format for 'feed'
      pbld, n$, *t$, sm06, e$
      pindex
      sav_absinc = absinc$
      if mi1$ > one, absinc$ = zero
      if use_rot_lock & (cuttype <> zero | (index = zero & prv_cabs <> fmtrnd(cabs))), prot_unlock
      if convert_rpd$, pconvert_rpd
      pcan1, pbld, n$, [if gcode$, *sgfeed], *sgcode, *sgabsinc, pwcs, pfxout, pfyout, pfcout,
        [if nextdc$ <> 7, *speed, *spindle], pgear, [if gcode$, *feed], strcantext, e$
      if use_rot_lock & cuttype = zero, prot_lock
      pbld, n$, sg43, *tlngno$, pfzout, pscool, pstagetool, e$
      absinc$ = sav_absinc
      pbld, n$, sgabsinc, e$
      pcom_movea
      toolchng = zero
      c_msng$ #Single tool subprogram call
      !xnci$, !ynci$, !znci$
      pcuttype
      toolchng = one
      inhibit_probe$
      pcom_moveb
      pcheckaxis
      ptoolcomment
      comment$
      pcan
      pindex
      pcom_movea
      toolchng = zero
 Thank You sir ! For quick guide line
