Sign in to follow this
pullo
Has anybody any ideas how to overcome the 10 buffer limit ?
I have  a camaix post base which is using all the 10 buffers. I have been now trying  to implement a cimco  c-hook which also uses a buffer .  That makes 11 buffers I need , but
ten are available . Any ideas how to overcome this problem ?
Gracjan
Use a stack?
But, to write a stack to a file you need a buffer so it may not work for your application.
I’m not sure why stacks aren’t used more often by post developers.
Without knowing what your C-Hook does, I have the feeling that you have way more tools to manipulate text/NC file via C-Hook instead of a simple buffer. I've developed a NET-Hook for CIMCO MachSim and it has the option to manipulate everything outside of post, but still injects lines into NC code.
JM2C
Or you can try to figure out which buffer is a string buffer and re-use it for your purposes. Perhaps.
1 hour ago, Zaffin_D said:
Use a stack?
Yeah, stack(s)! Just forgotten, even if I used them :)
AFAIK stack is limited to numbers only (no strings), but still they very useful.
No, stack is a standalone stuff and you can define as many as you wish.
I did! :) I use stacks to collect tool H/D numbers.
I was thinking more among lines  of :  can I use a buffer , close it  , redefine it  and use it again... I have not had the need to use buffers before ...
Gracjan
Correct(ish)  you can have as many stacks as you'd like, but they exist in memory.  If you want to write them to disk you must use the pop function with mode -1
Quote
–1 = Write the data record to a buffer that has been previously defined with the fbuf statement.
In this case, option indicates the number of the buffer where the data will be stored.
The success/fail code will be stored in value.
Or you could use a different file stream to write the data to disk, but it's not as automatic.
You should contact CNC's post department.
Sort of, here is a Knowledgebase article that shows how to reuse a buffer, but as far as I'm aware you can't redefine it at runtime.  Something can be done for sure, but without more detail it's hard to know what options to present.
I'll check out the knowledge base ....
and Ill post more details tomorrow.
Gracjan
Gracjan
Are you using all of the 'Alternate Output Streams'? You could potentially re-configure any one of your String Buffers, to 'write to one of the Alternate File Streams', in-lieu of using a Standard Buffer File.
You have the following available:
  1. NC
  2. SUB
  3. AUX
  4. EXT
  5. LCC
For example - Most "Mill Base Posts" won't have a need to use the Lathe Canned Cycle Stream, so 'lcc' makes a lot of sense if you are already utilizing the SUB, AUX, and EXT file streams...
thanx Colin, solid as ever  :)
Gracjan
which postblock  posts before  a buffer is defined ?  I  could trick  the  post  to  output  a  file thru' the LCC so it won't have to use the  sbufname10$ ,  but the fle has to be in the
NC file directory before the buffer is defined.  I tried pwrtt$ and pparameter$ but they are too late in the game....
Gracjan
Gracjan
pprep$
Also,
prot$
'prot$' gets called after the Post has initialized the variables, but prior to the call to 'ptlchg_1002$'. (Allows editing of regular variables, and updating of Global Formulas, before the call to 'ptlchg_1002$'. This is only important in 5X Posts, as there is a bunch of stuff which happens in the 'ptlchg_1002$' Post Block...)
The buffer is stored as a text file, so you can rename the files and change the path that the buffer reads to have multiple buffers in the same buffer number. I don't think you can change the size of the buffer with this method, so maybe best to just double up on two string buffers.
What I've done is what Alex partially mention.  I make if as SHARED buffer when they are not in used then use it for other buffer.
