cncgotoguy
Ending in single digit spindle speed warning, that isn't 0
Our spindles don't like when we have a speed ending in a single digit, that isn't 0.
We do however want the posted code to match the mastercam file
Any idea the best way to throw a warning at posting to let the programmer know the spindle speed needs to be rounded?
It might be better to just round it up or down but I have no idea how to do that
Which mastercam version?
2020 Mcam
I see some string functions to convert the number to a string, then break the string into pieces.
We don't want to round. We want the posted file to be exactly the same as the source file.
Implement a modulo post block in your post, something like this should get you started...
modulo_result : 0
int_a         : 0
int_n         : 0
remainder     : 0
p_modulo(int_a, int_n, !remainder)
	modulo_result = int_a / int_n
	modulo_result = int(modulo_result)
	modulo_result = modulo_result * int_n
	remainder = int_a - modulo_result
Then call it passing in your spindle speed as int_a, 10 as int_n, and use any numeric value for the returning value (the remainder)
p_modulo(ss$, 10, !result)
If the remainder returns 0, your spindle speed is evenly divisible by ten, so it ends in zero.
Here are a few test cases
	  p_modulo(20000, 10, !result)
	  "->", ~result, e$
	  //Output
          // -> result 0.
	  p_modulo(123456, 10, !result)
	  "->", ~result, e$
	  //Output
          // -> result 6.
	  p_modulo(45000, 10, !result)
	  "->", ~result, e$
	  //Output
          // -> result 0.
	  p_modulo(1776, 10, !result)
	  "->", ~result, e$
	  //Output
          // -> result 6.
	  p_modulo(1852, 10, !result)
	  "->", ~result, e$
	  //Output
          // -> result 2.
	  p_modulo(105, 10, !result)
	  "->", ~result, e$
	  //Output
          // -> result 5.
Have the post alter the variable 'speed' so a spindle speed not ending in zero won't happen, such as:
change the least significant digit to zero.
speed = (int(speed/10)) * 10
or
define a new variable, say, alt_speed  then a new postblock:
pfixspeed         # spindle speed to end in zero
             alt_speed = (int(speed/10)) * 10
             speed = alt_speed
              *speed
or
              *alt_speed
then substitute pfixspeed where speed is output
Thanks everybody, especiialy  Zaffin_D for the help on this. I went with the following code and got it to work. Probably not the prettiest code around
fmt     4  modulo_result
fmt     4  int_a
fmt     4  int_n
fmt     4  remainder
modulo_result : 0
int_a         : 0
int_n         : 10
remainder     : 0
p_modulo
    int_a = speed
    if remainder <>0, result=mprint(ssingledigitspindle)
    If remainder <>0, "(TOOLPATH SPINDLE SPEED ENDS IN SINGLE DIGIT)", e$
Then I ran the post block p_modulo after each toolchange.
