Sign in to follow this
byte
DrawNciPoints Chook Mastercam 2021
This chook draws points used in the selected operation after the chook is run, run it again to disengage the function. Targeted toward 3axis mill operations, a different way to analyze your toolpath.
DrawNciPoints.ft
DrawNciPoints.dll
26 minutes ago, Aaron Eberhard - CNC Software said:
I'm not quite sure after watching the video, does this do something fundamentally different than turning on "Endpoint"under "Advanced Display?"
With this chook you can view the toolpath points without the blue lines/arcs in the display (points only).
The points are also visible in the users points style which could make the points easily visible.
There is also a feature that each point is drawn in different color depending on if it is a drill point, rapid point,g1 or movement g2/g3 movement.
Yellow == rapid, Green == g1, blue == g2/g3, red == drillpoint
I used it yesterday to easily detect an operation with a low retract out of 100's of toolpaths.
I now used it to create a filtering mechanism that shows only the points using the specified tool in a nesting operation, I also added the ability to store the points as mastercam entities.
DrawNciPoints.dll
DrawNciPoints.ft
DrawNciPoints.dll
DrawNciPoints.ft
That's a cool improvement :)
