Haas Probe Run Out Macro
I wrote this macro to quickly check my spindle probe run out at anytime.
***This is for Next Generation Controller only and the mill will also need Rigid Tapping/Spindle Encoder.***
Just position the probe .5 or less to the left of a clean ground surface that is parallel with the Y axis.
Hit Cycle Start and the program will pickup the face and then rotate 45° and pickup again.  It will do this 8 times - a full 360°.  When finished the TOTAL run out will be displayed in the "SIZE" field on the controller which is macro variable #10188.
(---START OF PROGRAM---)
     (CHECK PROBE RUNOUT PROGRAM)
(----NEXT GENERATION CONTROL ONLY----)
(---MUST HAVE RIGID TAPPING/SPINDLE ENCODER---)
(POSITION PROBE .5 OR LESS TO THE LEFT OF A)
(GROUND EDGE THAT IS PARALLEL TO THE Y AXIS)
(--HIT CYCLE START)
(--THE PROBE WILL PICKUP IN THE +X DIRECTION)
(--THE SPINDLE WILL ROTATE 45 DEGREES)
(THIS WILL REPEAT 8 TIMES = 360 DEGREES)
(THE TOTAL RUNOUT WILL BE IN "SIZE" FIELD)
(WHICH IS VARIABLE #10188)
#10188=#0
G65 P9832 (TURN PROBE ON)
#100=#5021 (CURRENT X START POSITION)
#101=#0 (SET VARIABLES TO NULL)
#102=#0
#103=#0
#104=#0
#105=#0
#106=#0
#107=#0
#108=#0
#109=#0
#1=0
#120=0
WHILE[#120 LT 360] DO1
G103P1
G52
M19P#120 (SPINDLE POSITION)
G91
M79 G31 X.5 F50.
G1 X-.1 F100.
G31 X.3 F4.
#[101+#1]=#5061
G90
G1 G53 X#100 F100.
#120=#120+45(ROTATE SPINDLE 45 DEG INC., FROM 0-360)
#1=#1+1(USED TO ADVANCE PICKUP VARIABLE)
END1
M19P0
#110=#101(CALC. SMALLEST X VALUE INTO #110)
IF [#102 LT #101] THEN #110=#102
IF [#103 LT #110] THEN #110=#103
IF [#104 LT #110] THEN #110=#104
IF [#105 LT #110] THEN #110=#105
IF [#106 LT #110] THEN #110=#106
IF [#107 LT #110] THEN #110=#107
IF [#108 LT #110] THEN #110=#108
#111=#101(CALC. LARGEST X VALUE INTO #111)
IF [#102 GT #101] THEN #111=#102
IF [#103 GT #111] THEN #111=#103
IF [#104 GT #111] THEN #111=#104
IF [#105 GT #111] THEN #111=#105
IF [#106 GT #111] THEN #111=#106
IF [#107 GT #111] THEN #111=#107
IF [#108 GT #111] THEN #111=#108
#10188=#111-#110 (TOTAL DEVIATION DISPLAYED IN "SIZE")
#109=#10188
M69 P1134 (PROBE OFF)
IF [#10188 LT .0005] GOTO 100
#3000=1(PROBE RUN OUT IS .0005 OR GREATER!)
N100
(---END OF PROGRAM---)
  • 3 months later...
(--HIT CYCLE START)
#10188=#0
#102=#0
#103=#0
#104=#0
#105=#0
#106=#0
#107=#0
#108=#0
#109=#0
#1=0
#120=0
G103P1
G52
G91
M79 G31 X.5 F50.
G1 X-.1 F100.
G31 X.3 F4.
#[101+#1]=#5061
G90
G1 G53 X#100 F100.
END1
M19P0
#109=#10188
N100
Used this today.....thank you!
