SearchManager.GetOperations disable some operations. Is this normal?
Hi.
The interface we are developing requires retrieving information from mastercam operations.
We use SearchManager.GetOperations() but that seems to disable some operations.
However, our interface must not modify the model.
Is this normal? The SearchManager.GetOperations() function is it not supposed not to modify the model?
Do you have a solution to avoid this issue?
Thanks !
8 minutes ago, Deflandre JY said:
Hi.
Thanks !
Please, always  include which version of Mastercam you are using.
Can you share a code snippet or description of what you are trying to do?
Calling Commit() may dirty the operation. Keep in ming the NEThook api does not have wire edm or lathe support.
Hi,
We are using Mastercam 2021, we have the same with Mastercam 2020 .
We see this problem by running only the code below. Otherwise, the goal is to retrieve for each operation information such as  Tools used,  planes and axis.
        Group[] aGroups = SearchManager.GetGroups();
        foreach (Group oGroup in aGroups)
            if (oGroup.GetParentGroup() != null)
                if (oGroup.IsToolpathGroup())
                    if (oGroup.Name != null)
                        List<Operation> aOperations = new List<Operation>();
                        if (SearchManager.IsAnyOperations(oGroup.ID))
                            Operation[] aOperations1 = SearchManager.GetOperations(oGroup.ID);
                            foreach (Operation oOp in aOperations1)
                                aOperations.Add(oOp);
11 minutes ago, Deflandre JY said:
Hi,
Yes, you don't want to be using the Add method here.
oOp already contains the operation info, for specific supported types you can get the type and cast it as eg. circlemill contour drilling pocket or nesting.
//get a list of the nethook supported lists in mastercam
var List = Mastercam.Support.SearchManager.GetOperations();
//loop through the list of operations
foreach(var operation in List)
//if the operation type is not nesting
if (operation.Type.ToString() != "Nesting")
         //get the operations toolnumber
         var tlnum = operation.OperationTool.Number;
         //write the tool number to mastercams event logger
         Mastercam.IO.EventManager.LogEvent(Mastercam.IO.Types.MessageSeverityType.InformationalMessage,""," ToolNumber : " + tlnum.ToString() + " ");
         //write the operation type to mastercams event logger
         Mastercam.IO.EventManager.LogEvent(Mastercam.IO.Types.MessageSeverityType.InformationalMessage,"","Op Type : "+ operation.Type.ToString());
          //write the operation id and cycletime to mastercams event logger
         Mastercam.IO.EventManager.LogEvent(Mastercam.IO.Types.MessageSeverityType.InformationalMessage,""," OpID : " + operation.GetOperationID().ToString() + " Time : " + operation.CalcCycleTime().ToString() + " TlNum : " + operation.OperationTool.Number.ToString());
Hi.
Thank you for your answers, but that was not really the subject of my question.
I've minimized my code as below. Only one call to GetOperations(). And this disables an operation. I just wanted to know if it's normal for a "Get..." function to do this and how to find out why my operation is disabled.
        public override MCamReturn Run(int param)
            return MCamReturn.NoErrors;
Thanks.
23 minutes ago, Deflandre JY said:
Hi.
Thanks.
 I see,
I haven't seen this before,
can you describe what exactly you mean by "operation is disabled"?
What is the name of the affected operation?
