Slot mills not working correctly for stock model creation
By
Programinator, in Industrial Forum
Joe777 5
Check that "Lead in/out" are correct , It's easy to miss on a back plot. Else, it could be "Rapid motion linear settings" in control def. Also make sure that all your rapid movements if possible are above the part.
JParis 1,195
Set the check box in stock model to use flutes only
1
Joe777 5
23 minutes ago, JParis said:Set the check box in stock model to use flutes only
Thanks JParis,
Yeah, I should have mentioned that I'm still using 2020
Most of my colleagues moved to 2021. I have noticed that when updating post from an elder version to a newer version: certain settings in control def do not retain.
Also, I have noticed that using a stock model for "rest machining" is not as good as saving the stock model to .stl and then using .stl as cad file
Regards.
On 9/14/2020 at 5:05 PM, JParis said:Set the check box in stock model to use flutes only
Thanks JParis, I had that box checked. i unchecked and regenerated and it worked perfect. thanks
Recently Browsing 0 members
Anyone notice that when creating a stock model with one of the toolpaths being a slot mill it does not generate correctly? In backplot and verify everything looks good. The stock model generated however, has a huge gouge. I have seen this since 2021 everytime i use a slot mill. Anyone know why its doing this?
