Swaf Milling multi slice retract
akuser
Hello everybody,
I have problem when using Swaf Milling with multiple slice cut. When finish 1st slice cut, the tool retract to clearance plane and the other axis return to the begin point for 2nd slice cut.
While other axis returning the machine run like slow motion (look like we run cut a arc contour with multi G1 instead of G2/G3)
Here is the code I have posted from mastercam 2020
Quote
X-.0118 Y-.2939 Z8.1367
X-.0067 Y-.2944 Z8.1378
G00 X-.0423 Y-.6929
X-.0779 Y-1.0913
X-.1178 Y-1.6811 Z8.1375
X-.2406 Y-1.6682 Z8.1471 A-89.876 C170.843
X-.3621 Y-1.6464 Z8.1568 A-89.753 C166.788
X-.4817 Y-1.6157 Z8.1664 A-89.63 C162.733
X-.5988 Y-1.5763 Z8.1759 A-89.51 C158.678
X-.7126 Y-1.5283 Z8.1854 A-89.392 C154.622
X-.8226 Y-1.4722 Z8.1948 A-89.277 C150.567
X-.9282 Y-1.4081 Z8.2041 A-89.166 C146.511
X-1.0288 Y-1.3364 Z8.2132 A-89.059 C142.456
X-1.1238 Y-1.2575 Z8.2222 A-88.957 C138.4
X-1.2129 Y-1.1718 Z8.2311 A-88.86 C134.343
X-1.2954 Y-1.0798 Z8.2397 A-88.768 C130.287
X-1.3709 Y-.982 Z8.2482 A-88.683 C126.23
X-1.439 Y-.8789 Z8.2564 A-88.605 C122.173
X-1.4995 Y-.771 Z8.2644 A-88.533 C118.115
X-1.5518 Y-.659 Z8.2722 A-88.469 C114.058
X-1.5958 Y-.5435 Z8.2798 A-88.412 C110.
X-1.6311 Y-.425 Z8.287 A-88.363 C105.942
X-1.6577 Y-.3042 Z8.2941 A-88.323 C101.883
X-1.6754 Y-.1818 Z8.3008 A-88.291 C97.825
X-1.684 Y-.0584 Z8.3073 A-88.267 C93.767
X-1.6836 Y.0653 Z8.3135 A-88.253 C89.708
X-1.6741 Y.1887 Z8.3194 A-88.247 C85.649
X-1.6555 Y.311 Z8.3251 A-88.249 C81.591
X-1.6281 Y.4317 Z8.3305 A-88.261 C77.532
X-1.5918 Y.55 Z8.3356 A-88.281 C73.474
X-1.547 Y.6654 Z8.3404 A-88.31 C69.415
X-1.4939 Y.7772 Z8.345 A-88.347 C65.357
X-1.4327 Y.8848 Z8.3493 A-88.393 C61.299
X-1.3637 Y.9876 Z8.3533 A-88.447 C57.241
X-1.2874 Y1.0851 Z8.3572 A-88.508 C53.183
X-1.2042 Y1.1768 Z8.3608 A-88.577 C49.125
X-1.1144 Y1.2621 Z8.3641 A-88.653 C45.068
X-.7186 Y.8144 Z8.3508
X-.4355 Y.5319 Z8.3414
G01 X-.1524 Y.2495 Z8.332
X-.1537 Y.2484 Z8.3369
X-.1556 Y.2467 Z8.3478
Here is the picture of toolpath
Quote
Here for simulation machine runing with move
Quote
What I did is wrong in somewhere else?
Thank you for your reading and help.
Best Regard
On 9/25/2020 at 11:35 AM, akuser said:
Here is the file with swarf toolpath only. I have to delete another toolpath to keep the file small
The file can be open with mastercam 2020
Thank you
SWARF.mcam
Well this is an industrial file so this topic should be moved to the Industrial forum.
Here is where you make the change.
