JB7280
Optirough Efficiency
I know it's not exactly necessary on this part, but I was playing around with optirough/rest, because I haven't used it much.  On my toolpath, it wants to do a pass about 1/8 inch below the stock, before dropping down to the full depth cut.  It seems like it'd be more efficient to start at the bottom and work up, so I'm guessing I have something set wrong.  Anyone know where I'm wrong?
333A072.mcam
333A072.mcam
You have your top of stock in the steep and shallow setting at .846 when the top of stock is 1.000. Change it to that and regenerate and it does what you are after.
Get in the habit of defining your holders. Your lead in and out on the Finish OD could be rotate to be off a surface to avoid slamming the tool into the part face.
Overall nice work and good job.
Thanks Ron, fwiw it's I always define my holders, i'm just throwing toolpaths on this part at the moment.  I still need to define cutting tool p/n's, speeds and feeds, etc.
Tried your advice, and it worked.  That seems to work differently than I expected.  I was using .846 to try to "force" the toolpath to start lower.  Perhaps I'm thinking about it incorrectly.  Also, thanks for the Finish OD suggestion!
I'm not able to change the start point.  I right clicked the chain, and clicked start point, then it gives me fwd, or back choices.  Both of them are ineffective because it's just a closed edge.  Do I need to make that wireframe in order to change the startpoint?
And one additional ?...finishing the top face, I used an area mill, staying off the wall of the boss, followed by a contour of the boss.  Is there a better way?  I usually try to avoid area mill, as I don't care for the entry/exit arcs (not enough control, and unnecessary code for our older machines), and I don't care for the aesthetics of dynamic paths as finishing.  Maybe I'm just being too damn picky though!!
Okay I get it about the holders sorry.
The stock shape has to match if not then the toolpath is looking to that stock and not sure how to go about it. Your stock is really the boundary and yes OPTI-ROUGH will do some weird things when the top of stock is even a little off. The start point is changed on wireframe on a solid chain you cannot change it like that.
Nothing wrong with area mill to finish the top. Many ways to go about whatever gets you what you want is good enough.
Awesome, Thanks again for the help.  I didn't expect a reply on a Friday night, haha.
Well running some CAV on a 1650 operation part for a DMU80 DuoBlock Mill/Turn so killing time waiting for it to get done.
Glad to help. Have a good weekend.
I didn't want to create a new thread with the same part.  For OP2 I want to position the parts roughly as they are in level 210.  How would you go about laying that out?  A seperate file? Would you create solids of the first operation finish state, and create an all new setup, or continue working off of the original stock model?  The second op transition is where things always get a little confusing for me.  I put an updated file in dropbox, because it's now too big to upload.
https://www.dropbox.com/s/0jgnhy6o8nz6z7e/333a072.mcam?dl=0
Sigh unseen. WCS and then new Toolpath group for Setup 2. I will review later. I want to give others time to review and give feedback. No one gives you an answer by the end of the day then I will give you my thoughts. Fair enough?
There are several ways to make it. It depends how you want to organize your work. On complex parts i usually make one file equals one setup.
However, here, part is simple so it'd be perhaps better to get all setups in the same file.
There are several ways to achieve it but my strategy is usually to move fixtures (not part designs) and use WCS/viewsheets.
In your case it's a little tricky as you're using one stock model for 2 parts. I usually keep 1 part per stock model (except if i need to verify) it makes things easier.
Then, I made a mesh from your OP1 stock model for 1 part only and made a copy of this mesh for 2nd part. Then make another stock model from these 2 if needed.
I updated your file here: https://www.dropbox.com/s/ehick6vmsajvzl7/333A072-mod.mcam?dl=0
Ok, I think that makes sense.  I do like the view sheets in this case.  I've never actually used them.  My issue was using the same part model, but changing the orientation of the parts, which you seem to have fixed by only reusing 1, then copying.  My original plan was to put toolpath on 1 part, then use transforms for the second part, but I couldn't seem to get the transforms to work how I wanted.  I noticed you have 2 stock models.  1 as a single part, and 1 as both parts.  You included both, just to show both options, but would normally only have one or the other, correct?
Thanks for taking a look at it.
For sure.  I appreciate the feedback.
The first one is an exact copy of your 'finished OP1' stock model but with stock part_1 only. I did it to export mesh for part_1 only, copying/transforming this mesh to make OP2 part 2 stock. This stock model toolpath can be delete after meshes export. I let it in the file as it's part of the process.
Gotcha.  I also noticed you created a new machine group.  In the past, I had just been creating a new toolpath parent group called OP2, or whatever op it was.  Any reason you used a new machine group?  I know a lot of things are just personal preference, but I thought maybe there's a reason.  I suppose with your way, it would be easier to put the parts on 2 different machines.
Yes, this is to clearly separate setups and you can select different machines easily.
Makes sense.  And thanks again for taking a look!!
Dave did an excellent job of giving you a way to go about it. I would program one part in OP1 and use Transform to program the 2nd Part. Then you could use one model for OP1 and OP2 using your WCS to control everything. They way you have it will get the job done, but to me from a programming stand point creates a lot of extra work. Agree ViewSheets are helpful. Currently knee deep programming so don't have time to really make a file up showing you what I am thinking.
Think about what I have said and see if you figure out what I am saying and how I would go about it. Envision it and then see if that makes sense. David is spot on if moving to a different machine then yes you need anew machine group. However if it is staying in the same machine then only one machine group is needed.
I will play with it more tomorrow.  I couldn't get the optirest to behave correctly with a transform, otherwise I'd have used it.  Perhaps over Thanksgiving break I'll take my pc home and play with it some more when I'm not under the gun.
OT but, why do you have your Entry/Exit angle set at 120 degrees?  Any particular reason?
Funny question, when I started programming, it was with Esprit, and the guy who taught me liked those teardrop shaped entry/exits.  I can't remember how you do it now, (its been a few years since I've touched Esprit) but you did something like 66%/33%/33% on your entry/exit page.  So really it's just a habit I got into, and nothing more than that.
If I am inside of a hole I will use 135 degrees so that it has less of a chance of gouging the part. Old habit from before they had gouge check on entry/exit moves.
I haven't used Esprit in over a year since my last job, and I don't miss it one bit.  It was a 4 year disaster.  I'm glad to be back with Mastercam 2020 now.
Interesting.  I think it has something to do with what you learned on.  Esprit was the first CAM software I used, and I certainly prefer it over MC, but MC does what I need.
I was also taught 😁 60/40/40. If I remember correctly...60 percent allowed cutter comp to initiate and the 40/40 was to allow minimal sidewall clearance with a gradual or minimal attack angle.  You would never have to worry about material engagement or gouging. For the type of work we do, this has work well enough to be my default settings.
I started with Virtual Gibbs, then Mastercam, Part Maker, Pro E, Creo, then Esprit, and now back to Mastercam.  I learned on Gibbs first and I don't miss it.  My pick for the best is Mastercam.  Just my opinion.
