Sign in to follow this
byte me
Post Processor coding
Hi all,
I've been practicing the post processing writing a bit this weekend.
I noticed the user defined names in the posts I see are a bit unclear as to what they do a lot of shortened names,
For my posts that I'm writing I think I might use a camel case like we do for the chook and nethook programming.
In the following example the user defines variables are written like this
stringOpenParentheses    : "("   #String for open parenthesis "("
stringCloseParentheses   : ")"   #String for close parenthesis ")"
stringDelimiter   : "|"   #String for delimiter
I think that makes it more clear to the end user what everything does. JM2c
[POST_VERSION] #DO NOT MOVE OR ALTER THIS LINE# V23.00 P0 E1 W23.00 T1596718960 M23.00 I0 O1
# Post Name           : CUSTOM POST
# Product             : Mastercam
# Machine Name        : MACHINE
# Control Name        : CONTROL
# Description         : MASTERCAM POST
# Subprograms         : YES
# Executable          : MP v11.0
# Post Revision       : 0
# ---------------------- Break ------------------------#
# -------- Start of Miscellaneous Strings -------- #
# -------- End of "Miscellaneous Strings" -------- #
# -------- Stat of "Header Info" -------- #
pheader$         #Call before start of file
      "%", e$
      !spaces$, spaces$ = 0
      spathnc$ = ucase(spathnc$)
      smcname$ = ucase(smcname$)
      stck_matl$ = ucase(stck_matl$)
      snamenc$ = ucase(snamenc$)
      stringOpenParentheses, "MCX FILE - ", *smcpath$, *smcname$, *smcext$, stringCloseParentheses, e$
      stringOpenParentheses, "NC FILE - ", *spathnc$, *snamenc$, *sextnc$, stringCloseParentheses, e$
      stringOpenParentheses, "MATERIAL - ", *stck_matl$, stringCloseParentheses, e$
      spaces$ = prv_spaces$
# -------- End of Header Info -------- #
# -------- Start of "Comment Info" -------- #
pcomment$        #(must call pcomment2 if booleans)
      pcomment2
pcomment2       #Output Comment from manual entry
      scomm$ = ucase (scomm$)
      if gcode$ = 1008, stringOpenParentheses, scomm$, stringCloseParentheses, e$  #Operation comment
      if gcode$ = 1051, stringOpenParentheses, scomm$, stringCloseParentheses, e$  #Machine name
      if gcode$ = 1052, stringOpenParentheses, scomm$, stringCloseParentheses, e$  #Group comment
      if gcode$ = 1053, stringOpenParentheses, scomm$, stringCloseParentheses, e$  #Group name
      if gcode$ = 1054, stringOpenParentheses, scomm$, stringCloseParentheses, e$  #File Descriptor
      ##### Stop custom changes #####
# -------- End of "Comment Info" -------- #
# -------- Start of "Start Of File" Info -------- #
psof$            #Start of file for non-zero tool number
        ##### Custom changes allowed below #####
peof0$           #End of file for tool zero
      peof$
#End of file for non-zero tool
# -------- End of "Start Of File" Info -------- #
# -------- Start of "End Of File" Info -------- #
peof$
         #Write the G28 A0. Line
         n$, "G28", "A0.", e$
         #Write the % EOF Line
         n$, "M30", e$           #Write the M30 Line
         #mergesub$
         #clearsub$
         #mergeaux$
         #clearaux$
         "%", e$
#End Region
# -------- End of "End Of File" Info -------- #
If a variable has a $ at the end, it's a system variable and that name cannot be changed
Those of us who have dug around in posts for awhile know what the other variables are...
If you were going to write your own post engine, yeah I can see it...if you're modding existing posts, it probably doesn't make a lot of sense to rewrite a huge portion of what already works.
JM2C
Yeah I knew that going in, I was purely speaking on the User Defined varables.
Yeah I was thinking more for new posts, updating existing posts using find and replace could be error prone..
