I am struggling to figure out what is happening inside my FT file for my C-Hook.
The c-hook  builds and program runs fine without the FT file, but if I add the FT file to the chook folder I get an error when mastercam starts. I have attached pictures of the FT file and the mastercam error as I do not know how to imbed the pics into the post.
Thanks in advance.
Karl S
Thanks in advance.
Karl S
Hey Karl, if you look in your x64/release folder, you can see the resource name of the resources, make sure it says Create_Cam.NETHook.resources
Is this a chook or a nethook? The ft structure is different for chooks and the resources need to be done in a .rc file
It is a nethook created by visual studio 2017 and VB. Here is what is in the resource folder, notice it is in the Function Table folder and not in just the resources folder. Does that matter? Sorry for the many questions as this resource stuff is really not clear to me.
Do I just correct the FT file to use NETHook.resx? Or am I not embedding it correctly ? or?
Look in Create_Cam/Create_Cam/x64/release.
Create_Cam\Create_Cam\obj\x64\Release
There is an option when you create a new project with visual studio 2017 create a folder for the solution, unchecking it avoids the create_cam/create_cam folder structure which makes things a bit confusing .
You can right click and select remove item, then right click on the project and add item back, dragging the file might do it as well.
For simplicity you could manually move all the files into one the main folder and then remove them all and add them again.
2 hours ago, byte me said:
Thia tutorial covers creating managed resources and everything else in a nethook from scratch, the resource part is the same foe all .net lamguages.
Thanks for sharing.
I would like to note that icon sizes should be 16 and 32, 24 was deprecated a couple of versions back.
Thanks again 👍
On 12/3/2020 at 3:12 PM, Karl@CP PISTONS said:
Do you know any good books that would help me as self taught  to learn these kinds of issues?
I'll let you know if I come across any.
It's more a matter of learning the controls.
If you right click on the project in the Solution Explorer under add, there is an add filter option.
This creates a subfolder in the Solution Explorer View.
Right click on the subfolder and add the items you want.
You have a choice between storing your items in seperate folders or all in the main folder, this won't affect your solution explorer view.
