So not a Guru
Screwy arc output
MC is outputting this for an arc:
G1 Z.9476 F25.
G41 D17 X-4.2967 Y4.0874 F8.25
G3 X-4.2968 Y4.0874 I.3388 J-.1742
G1 G40 X-4.1189 Y3.9959
The result being that the machine cuts the lead in & lead out only, no arc.
Anyone know is this an MC issue, or a post issue?
Try going into the control def >> arcs and let it break arcs...
also, in Mastercam, with backplot set to show distance moves, not endpoint moves, is it actually going around in an arc?
Try making the diameter an even value. It looks like it's rounding funny
Whoa! Allowing break arcs at 180° changed to output to cut in a completely different location, I shifted the work offset up & sure enough, it would have cut the hole in the wrong location.
G1 Z.8349 F25.
G41 D17 X-4.4971 Y4.0399 F8.25
G3 X-4.4971 Y4.0399 I.3388 J-.1742
G1 G40 X-4.3192 Y3.9484
Do you have the shorten lead in checked?
G1 Z.9476 F25.
If you output as R is it the same issue?
Do you mean the "Adjust start/end of contour"? If so, then no I do not.
Apparently, I would have to modify the post for this, changing it in the CD had absolutely no effect on the output.
What operation is responsible for this?
Contuor
40 minutes ago, So not a Guru said:
Contuor
So the lead in is the issue?
If its set to pct maybe set it to a rounded value instead.
can you upload that mastercam file ... just that contour
also, what post are you running??
it must be a very old post if it does not respect Control Def edited on the Arc page
Here is a zip2go of just the arcs. It's a Postability post, about 4 or 5 years old, but we opted not to pay maintenance.
for CC.ZIP
@JParis, I'm a dumba$$, I forgot to uncheck the "Allow 360 degrees arcs" box. I've already hand edited the original code, so we can get the parts out, but it looks like this might work.
Yeah, it seemed to me a control def setting, that was why I asked about the backplot move too  :)
:cheers:
:cheers:
It still outputs a different end point than the start point though.
G1 Z.9476 F25.
G3 X-3.6192 Y3.739 I.3388 J-.1742
X-4.2968 Y4.0874 I-.3388 J.1742
G1 Z.9476 F25.
That's just a rounding error...take it out to 5 places and you'll see the difference
Check your Geometry Zeke.
Not at 4 Decimal Places, but at 7 Decimal Places.
Is your Arc "perfect"? Make sure the Center Point Location, Radius, and Arc Sweep values are perfect.
I always double check my geometry now, at about 100 times the tolerance that I will be outputting to.
Remember, a 89.999431 Arc Sweep, could be interpreted as "90", due to rounding. At the actual "arc" location, you may be within a tenth, but once you've offset by the radius of your cutter + lead in/out values, you can see some of those rounding errors creep into your NC Code.
Anytime I'm getting a "1-tenth flutter" in the position output of my NC Code, the first thing I check is the quality of my geometry "input" to the system.
In rare cases, your geometry can be "perfect", but right on the edge of a rounding error itself.
Take the value 1.00045. Is it 1.0004 or is it 1.0005, based on rounding to 4 decimal places?
Well, you have to understand that your computer does not store any of your values as true rational numbers. All of the numbers are stored as 'floating point values', so occasionally there can be issues with Windows and the routines it uses to round the values internally. For these situations, there is a Post Variable 'round_opt$', which can be used to influence the rounding of these close values, to make sure they either round up, or round down, or are properly truncated.
I would've thought that this section would ensure there was no mismatch.
      #Check for mismatched arc data
      if xyarc,
        arcrad1 = sqrt((fmtrnd(xcabs)-prv_xabs)^2+(fmtrnd(ycabs)-prv_yabs)^2)
        arcrad2 = sqrt((fmtrnd(xcabs)-xabs)^2+(fmtrnd(ycabs)-yabs)^2)
      if yzarc = 1,
        arcrad1 = sqrt((fmtrnd(ycabs)-prv_yabs)^2+(fmtrnd(zcabs)-prv_zabs)^2)
        arcrad2 = sqrt((fmtrnd(ycabs)-yabs)^2+(fmtrnd(zcabs)-zabs)^2)
      if xzarc,
        arcrad1 = sqrt((fmtrnd(xcabs)-prv_xabs)^2+(fmtrnd(zcabs)-prv_zabs)^2)
        arcrad2 = sqrt((fmtrnd(xcabs)-xabs)^2+(fmtrnd(zcabs)-zabs)^2)
      if fmtrnd(arcrad1) <> fmtrnd(arcrad2),
        #if arcwarnflg = 0, result = mprint(sarcwarn)
        #spaces$ = 0
        #pn, pspc, sm00, " ", scomm_str, sarcwarn, scomm_end, pe
        #spaces$ = sav_spc
        #arcwarnflg = 1
        #result = fexist(snircmd)
        #sparams = 'speak text "' + sarcwarn + '"'
        #if result, result = launch(snircmd,sparams)
      if hel_lead = 1, pcirout2
      else, pcirout1
Not all values are stored as floating point types.
You have the whole number types short - int - long - long long, which all store different sizes of numbers.
Floating point numbers would typically be float(7 decimal places) or double(15 decimal places).
All values in Mastercam are stored as Doubles.
Unless they recently made a change to the underlying data structure in Mastercam, but that would be a recent development, if they did. Historically, all 'reals' are stored as Doubles, and Strings are stored as Strings, up to the 'Windows MAX PATH' value, which I believe defaults to '2048' on 64-bit systems...
That's interesting, you would know better than me whats under the hood. Are you referring only to the contents of the database or..
      if xyarc,
      if yzarc = 1,
      if xzarc,
        #spaces$ = 0
        #spaces$ = sav_spc
        #arcwarnflg = 1
      else, pcirout1
I mean, I guess not right!
Is this a big problem for you Zeke?
Actually, this is the 1st time I've had this issue. So, hopefully not.
Also, it looks like that snippet is for testing the junction between 2 different arcs not the issue I'm having. I could be wrong though, I am always struggling to interpret what the variables represent.
