Level Report
Müřlıń®
Hello Guys.
I have a file error that happens sometime when using the "save as".
I have a level that will not go away no matter what you do and it gives an error message about the active level not being visible
even after saving file with that level visible.
Report has symbols that I think are associated with stack overflow...not sure...
any ideas?  Below is the file that will error.
1.mcam
3 minutes ago, Müřlıń® said:
Hello Guys.
any ideas?
What version of Mastercam are you using Murlin?
Is it possible to share a stripped down version of the file?
I can't say that I've seen this before
I'm not seeing any error Murlin, I added a new level and cleared the old one.
 I got the error the second time I opened it. However I was able to clear the level after that.
I'm thinking there could be corruption in your configuration files or the Mastercam Install.
Do you have a backup for the shared Mastercam and My Mastercam folder?
I would replace those, and if that doesn't fix it re-install.
15 minutes ago, Müřlıń® said:
2021...I added the file...
What update version of 2021?
 I'm running update 2.1.
I would suggest sending it to QC, in case they know something else I don't.
  • 5 months later...
Thank you Mick...
I finally figured out how to purge this bug...so far it is working.
I always open a Mastercam file by double clicking on the file.
Today this error got so bad I could not use a file because the popup window in Mastercam would NOT echo it to the screen...probably because I am using 3 monitors.
The window would only appear after I exited the file...and while the popup was active the file was useless.
So I opened a fresh Mastercam file by using icon on task bar.
Then used the open command to pull in my file.
The popup complaining about the active level not being visible came up and I clicked ok.
Then I renamed the offensive level, saved the file, and closed down Mastercam.
Then I opened the customers folder and double clicked the file as  I normally do and voila....no popup...
Note I had already done this several times to no avail.  but I hadn't accessed the file above secquence.
