Holder .stp import
Hi,
Im trying to import .stp file as holder custom geometry.  Im using ToolNetApi.dll and this is some of my code:
                miTlib.OpenLibrary(Operadores.rutaPortas + @"\Master3DTool.tooldb",true);
                List<TlAssembly> ListaMontajes = new List<TlAssembly>();
                miTlib.GetAllTlAssemblies(ListaMontajes);
                TlHolder nuevoholder = new TlHolder();
                ListaMontajes[0].Name = "XXXXXX";
                nuevoholder = ListaMontajes[0].MainHolder;
                nuevoholder.Name = "KKKKKKK69990000";
                nuevoholder.GeometryFile = @"D:\Escritorio\83-PORTA.stp";
                ListaMontajes[0].MainHolder = nuevoholder;
                miTlib.DeleteAll();
                miTlib.Add(ListaMontajes[0]);
                miTlib.UpdateLibrary();
                OperationsManager.ToolLibraryName = miTlib.GetLibraryPath();
However, the holder loads its custom name and stp geometry, but in Mastercam it still represents the original default holder.
Can someone help me?
Thank you very much.
83-PORTA.stp
4 hours ago, RubenIAM said:
Hi,
                miTlib.DeleteAll();
83-PORTA.stp
I don't see that setting that value implicitly tells mastercam to load the 3d holder, I'm not sure this is supported.
namespace CreateMillToolAddIn
    using System;
    using System.Collections.Generic;
    using System.Diagnostics;
    using System.Windows.Forms;
    using Cnc.Tool.Interop; // ToolNetApi.dll
    using Mastercam.App;
    using Mastercam.App.Types;
    /// <summary> CreateMillTool Class (implements the NetHook3App interface) </summary>
    public class CreateMillToolAddIn : NetHook3App
        #region Public Methods
        /// <summary> The REQUIRED main entry point 'Run' method for the NETHook. </summary>
        /// <remarks> This is the only really required method that you must override in order
        ///           to implement the NETHook3App interface. </remarks>
        /// <param name="param"> Parameter supplied via a (optional) FT File PARAM command. </param>
        /// <returns> A MCamReturn return type representing the outcome of the NetHook application. </returns>
        public override MCamReturn Run(int param)
            try
                var folder = Mastercam.IO.SettingsManager.SharedDirectory + @"mill\Tools\";
                var library = "Master3DTool.tooldb";
                var file = "83-PORTA.stp";
                // If the library does not exist, it will be created.
                var tls = new ToolLibrarySystem();
                tls.OpenLibrary(folder + library, true);
                TlAssembly toolAssembly = null;
                MessageBox.Show("1");
                toolAssembly = this.DemonstrateCreatingFlatEndMillToolAssembly();
                MessageBox.Show("2");
                var result = false;
                if (toolAssembly != null)
                        if (tls.IsOpen())
                            result = tls.Add(toolAssembly);
                        MessageBox.Show(
                            $"Result => {result}",
                            "Add Tool Assembly to library",
                            MessageBoxButtons.OK,
                            MessageBoxIcon.Information);
                tls.GetAllTlAssemblies(ListaMontajes);
                nuevoholder.GeometryFile = folder + file;
                // tls.DeleteAll();???
                // ** IMPORTANT ***
                // If the assembly was a default assembly before making this change, we need to set the "IsDefault" property
                // on the assembly to make Mastercam understand that this is now a user defined assembly.  Default assemblies
                // in Mastercam are treated as regular tools with a default holder.  Non-default assemblies are presented
                // differently in the tool lists throughout Mastercam through the filtering options and name outputs.
                // This step will not be required in the long-term, but for the short-term, setting this property is necessary
                var set = ListaMontajes[0].SetAsDefaultAssembly(false);
                tls.Update(ListaMontajes[0]);
                tls.UpdateLibrary();
                Mastercam.Operations.OperationsManager.ToolLibraryName = tls.GetLibraryPath();
            catch(System.Exception e)
                System.Windows.Forms.MessageBox.Show("Error!" + e.Message);
            return MCamReturn.NoErrors;
        #endregion Public Methods
        private TlAssembly DemonstrateCreatingFlatEndMillToolAssembly()
            // Create a "default" tool assembly of the specified type.
            var assembly = Cnc.Tool.Interop.TlServices.CreateITlAssemblyFactory().Create(Cnc.Tool.Interop.MCToolType.FlatEndmill, false);
            assembly.Name = "Programmatically created Assembly";
            // And set some of the parameters of the tool in this assembly...
            var millTool = assembly.GetMillTool(); // Get the tool from the assembly
            // Cast it to the type to access specific properties!
            var tool = millTool as TlToolEndmill;
            Debug.Assert(tool != null, "Cast to TlToolEndmill type was invalid!");
            tool.ToolNumber = 1;
            tool.Name = "My End Mill Tool";
            // If you are changing the "length" of the tool ->
            // It is best to update both the OverallLength and TruePhysicalLength properties.
            // Setting them apart will tell the containing assembly that the projection of that tool
            // is whatever is in the overall length property.
            // If the overall length is set to be greater than the current true physical length,
            // the true physical length is updated to match the overall length value.
            // Set the Overall dimensions
            tool.OverallDiameter = 0.9125; // Cutting diameter
            tool.TruePhysicalLength = tool.OverallLength = 4.125; // Overall length
            tool.CuttingDepth = 0.735; // Flute Length / Cutting Length
            // Set the Cutting geometry dimensions
            tool.TipDiameter = 0.505;
            // Set the Non-cutting geometry dimensions
            tool.ShoulderLength = 1.15; // Shoulder length
            tool.ShoulderDiameter = 0.5; // Shoulder diameter
            tool.ArborDiameter = 0.75; // Shank diameter
            // Set the Shank Type
            tool.ShankType = TlShankType.Straight; // Straight / Tapered / Reduced
            // tool.ShankType = TlShankType.Tapered; // Straight / Tapered / Reduced
            // tool.TaperAngle = 45.0;
            //// or...
            // tool.TaperLength = 0.135;
            // tool.ShankType = TlShankType.Reduced; // Straight / Tapered / Reduced
            // tool.NeckDiameter = 0.5; // Neck Diameter
            // tool.TaperLength = 0.575; // Neck length
            // Set Feed/Speed parameters
            var toolOpParams = tool.OpParams;
            toolOpParams.FeedRate = 7.55;
            toolOpParams.PlungeRate = 4.4;
            toolOpParams.RetractRate = 13.5;
            toolOpParams.SpindleSpeed = 2555;
            tool.OpParams = toolOpParams;
            // Set the changed Tool into the Assembly.
            assembly.MainTool = tool;
            // Add a segment to the default holder that was created
            // and set the altered holder into the assembly.
            var holder = assembly.MainHolder;
            holder.Name = "My Holder";
            holder.AddSegment(3, 3, 1);
            // Add more segments?
            assembly.MainHolder = holder; // Set the Holder into the Assembly
            // ** IMPORTANT ***
            var set = assembly.SetAsDefaultAssembly(false);
            Debug.Assert(set, "Assembly is still set as a default assembly");
            return assembly;
I got the same result running the above code, the other information was updated
12 hours ago, RubenIAM said:
Hi,
                miTlib.DeleteAll();
83-PORTA.stp
Mick figured it out, we need to call the method to store the profile->  TlGeometryImportExport.ImportProfileFromFile( (HOLDER) , (Path To File) );
Here is a working example that will create a new library and tool if none are found or if one is found, swap out the holder.
    using System;
            try
                bool CreateNewTool = false;
                if (!System.IO.File.Exists(folder + library))
                    CreateNewTool = true;
                var success = tls.OpenLibrary(folder + library, true);
                if (!success) { Mastercam.IO.DialogManager.Exception(new Mastercam.App.Exceptions.MastercamException($"Failed to open {library}")); }
                //only create a new tool if the library does not exist or is empty
                if (CreateNewTool == true || ListaMontajes.Count <= 0)
                    var result = false;
                        if (tls.IsOpen())
                        MessageBox.Show(
                            ListaMontajes.Add(toolAssembly);
                success = TlGeometryImportExport.ImportProfileFromFile(nuevoholder, folder + file);
                if (!success) { Mastercam.IO.DialogManager.Exception(new Mastercam.App.Exceptions.MastercamException($"Failed to load holder from path -> {folder + file}")); }
                // ** IMPORTANT ***
                Mastercam.Operations.OperationsManager.RefreshOperationsManager();
            //// or...
            // ** IMPORTANT ***
            return assembly;
    using System;
            try
                    var result = false;
                        if (tls.IsOpen())
                        MessageBox.Show(
                // ** IMPORTANT ***
            //// or...
            // ** IMPORTANT ***
            return assembly;
Ok, how do I use this code inside MC? Is it saved as a dll file to use as a chook?
Here is a snippet of code that will create a new holder, assign a stp file to the geometry and add it to the the tool db
        /// <summary> Adds new holder to database. </summary>
        /// <returns> A TlHolder. </returns>
        private TlHolder AddNewHolderToDatabase()
            // build path to tools
            var folder = Path.Combine(SettingsManager.SharedDirectory, "mill\\Tools");
            // tool db
            const string library = "micks.tooldb";
            // build path to db
            var toolDb = Path.Combine(folder, library);
            // part file for holder geometry
            const string file = "83-PORTA.stp";
            // build path to stp file
            var geometryFile = Path.Combine(folder, file);
            if (!File.Exists(geometryFile))
                DialogManager.Exception(new MastercamException($"File not found {geometryFile}"));
                return null;
            try
                // verify it opened successfullly
                var success = tls.OpenLibrary(toolDb, true);
                if (!success)
                    DialogManager.Exception(new MastercamException($"Failed to open {toolDb}"));
                    return null;
                var holder = new TlHolder
                    Name = "micks holder with geometry",
                    Description = "created via toolnetapi",
                    // assign the path
                    GeometryFile = geometryFile
                // import the actual file
                success = TlGeometryImportExport.ImportProfileFromFile(holder, geometryFile);
                if (!success)
                    DialogManager.Exception(new MastercamException($"Failed to Import Profile From File {geometryFile}"));
                    return null;
                // add to tool library
                success = tls.Add(holder);
                if (success)
                    return holder;
                DialogManager.Exception(new MastercamException($"Failed to add holder {holder.Name}"));
                return null;
            catch (Exception e)
                DialogManager.Exception(new MastercamException(e.Message, e.InnerException));
            finally
                // clean up
                if (tls.IsOpen())
                    tls.CloseLibrary();
            return null;
Edited by Mick George
code edit - added clean up
6 minutes ago, So not a Guru said:
@Thee Byte™ I don't understand how I get this to operate. I opened it & built it in VS. Where do I go from here?
So, when you run the add-in a new toollibrary will be created, it's looking for an stp file in the same folder as the tool library.
c:/users/public/documents/shared mastercam 2021/mill/tools/
needs to contain the .stp file named in the application.
So you would put a file called "83-PORTA.stp" in that folder and it will be stored in the newly created library
1 minute ago, So not a Guru said:
Run it from where? I don't see it in my chooks folder. Was I supposed to save some file into the folder?
You have to copy the DLL file from the x64/release folder to the chook folder along with the accompanying .ft file if you wish to add an icon to the qat.
9 minutes ago, Thee Byte™ said:
x64/release folder
I can't find this folder. I have:
C:\Users\Programmer PC\Documents\MASTERCAM\AddToolStoreProfile-main\AddToolStoreProfile-main\CreateMillTool\obj\x64\Debug\TempPE
And there is a "Properties.Resources.Designer.cs.dll" file in that directory, but no ft files
I'm using Widows 7
1 hour ago, Thee Byte™ said:
I got an error when I imported your geometry, i remerged the surfaces and ran optimize, reads okay now.
I also updated the example with the openfiledialog to just add the holder into a library.
Let me know where you want to go from there.
https://github.com/xx4g/AddToolStoreProfile/tree/main
STP-22907-6-CAT40xSLN1_8_-6_.STP
ToolLibrary.tooldb
I'm outta thanks today.👍
I'll give it a go on Monday.
Zeke,I added some options to the logic in the solution to
-> delete existing library tools
-> programmatically create a new library tool and holder assembly
->assign a custom profile to the assembly from a .stp file using the wubdiws open file dialog
-> import library tool(s) into Mastercam
->assign the tools to existing operations in the file
I create a struct with a set of switches to control the behavior
      /// <summary>
        /// The parameter struct for our add-in
        /// </summary>
        public struct AssemblyBuilderParams
            public string geometryFile;//the file to import
            public string library;//the library to create/store tool in
            public string name;//the assembly name
            public string description;//the assembly
            public bool import;//import newly created tool into Mastercam
            public bool assignToAllOperations;//Assign the last tool in the library to all operations
            public bool deleteExistingLibraryTools;//delete existing tools in the library
Then in the run method a bit farther down
            //intialize thje string variables
            string library = "ToolLibrary.tooldb", name = "Pocket Nc holder with geometry", description = "created via toolnetapi";
            //instantiate the open file dialog class
            OpenFileName ofn = new OpenFileName();
            //allocate memory
            ofn.structSize = Marshal.SizeOf(ofn);
            //Set the file extension filter
            ofn.filter = "Stp files\0*.stp";
            //set more params
            ofn.file = new String(new char[256]);
            //set more params
            ofn.maxFile = ofn.file.Length;
            //set more params
            ofn.fileTitle = new String(new char[64]);
            //set more params
            ofn.maxFileTitle = ofn.fileTitle.Length;
            //starting directory
            ofn.initialDir = "C:\\";
            //user defined popup window title
            ofn.title = "OpeN FilE DialoG";
            //file extension
            ofn.defExt = "stp";
            //we could do something here with the found filename
            //the resulting path selected by the user is stored in the ofn.file variable
            if (LibWrap.GetOpenFileName(ofn))
                //define our user defined struct
                AssemblyBuilderParams bParams;
                //set the parameters
                bParams.library = library;
                bParams.name = name;
                bParams.description = description;
                bParams.geometryFile = ofn.file;
                bParams.assignToAllOperations = true;
                bParams.deleteExistingLibraryTools = true;
                bParams.import = true;
                //pass the parameters to our function
                var Assembly = AddNewAssemblyToDatabase(bParams);
 #endregion
This portion of code creates the libwrap class, I re-use this portion a lot, since this interface is nice than the one you get from .NET.
Here we are importing directly from The Windows Api
  #region Private Methods
        [StructLayout(LayoutKind.Sequential, CharSet = CharSet.Auto)]
        public class OpenFileName
            public int structSize = 0;
            public IntPtr dlgOwner = IntPtr.Zero;
            public IntPtr instance = IntPtr.Zero;
            public String filter = null;
            public String customFilter = null;
            public int maxCustFilter = 0;
            public int filterIndex = 0;
            public String file = null;
            public int maxFile = 0;
            public String fileTitle = null;
            public int maxFileTitle = 0;
            public String initialDir = null;
            public String title = null;
            public int flags = 0;
            public short fileOffset = 0;
            public short fileExtension = 0;
            public String defExt = null;
            public IntPtr custData = IntPtr.Zero;
            public IntPtr hook = IntPtr.Zero;
            public String templateName = null;
            public IntPtr reservedPtr = IntPtr.Zero;
            public int reservedInt = 0;
            public int flagsEx = 0;
        public class LibWrap
            //BOOL GetOpenFileName(LPOPENFILENAME lpofn);
            [DllImport("Comdlg32.dll", CharSet = CharSet.Auto)]
            public static extern bool GetOpenFileName([In, Out] OpenFileName ofn);
You may want to set these switches to false at first,
Demonstrates create a new tool assembly and adding an existing holder to it,
 private TlAssembly CreateFlatEndMillToolAssembly(TlHolder holder)
            if (holder != null)
                assembly.Name = "Pocket Nc Assembly";
                tool.Name = "Pocket Nc Tool 1/8";
                tool.OverallDiameter = 0.125; // Cutting diameter
                tool.TruePhysicalLength = tool.OverallLength = .8; // Overall length
                tool.CuttingDepth = 0.5; // Flute Length / Cutting Length
                tool.TipDiameter = 0.125;
                tool.ShoulderLength = .75; // Shoulder length
                tool.ShoulderDiameter = .125; // Shoulder diameter
                tool.ArborDiameter = .125; // Shank diameter
                //// or...
                toolOpParams.FeedRate = 50.0;
                toolOpParams.PlungeRate = 5.0;
                toolOpParams.RetractRate = 50.0;
                toolOpParams.SpindleSpeed = 500;
                // ** IMPORTANT ***
                return assembly;
            return null;
