Select operations and post them off with vbs
Hi everybody, I’m working with X4 and creating a vbs file script.
I’m wondering if it’s possible to select operations from the toolpaths and post them off using vbscript? I mean: I want to select some operations and automatically (using the vbs script) post them off (as if I were using toggle posting button).
X4 , that's a very old version.
Link to similar topic ->
This might help but it is old.
'//        Author:   Mick George [email protected]
'//          Date:   11/11/2003 06:34 PM
'//     File Name:   NC for each OP.vbs
'//   Description:
'//      Comments:   I should be home playing threewave...
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
Dim intOpsCount, intThisOp
' -- Pass a null string to tell MC we want this files ops
intOpsCount = GetOperationCount(vbNullString)
If intOpsCount > 0 Then
    For intThisOp = 1 To intOpsCount
        If Not RunPost(intThisOp, GetOperationNameFromID(vbNullString, intThisOp)) Then
           ShowString "Failed to create NC for operation " & intThisOp
        End If
    Next
Else
  ShowString "Nothing to post"
End If
End Sub
Another for groups, again might be helpful
'//          Date:   16/03/2004 01:35 PM
'//     File Name:   OperationGroups.vbs
'//   Description:   Demo script that highlights various group functions
'//      Comments:   SP2 req + March Main 2004 mcamvb CHook
Const GROUP_ALL        = -1
Const GROUP_GEOMETRY   = 0
Const GROUP_OPERATIONS = 1
Const SYSTEM_GROUP     = 2
Const SYSTEM_RESULT    = 3
Const GROUP_TOOLPATH   = 4
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
   Dim idx, intGroup
   ' -- Get all groups
   intGroup = GetGroupCount
   ' -- Do we have at least one?
   If intGroup = 0 Then
      ShowString "No operation groups"
      Exit Sub
   Else
      ShowString intGroup & " operation groups found"
   End If
   If askYesNo("List all group types?") = mcMSG_YES Then
       ' -- Iterate all groups
       For idx = 1 To intGroup
           Select Case GetGroupTypeFromNumber(idx)
                  Case GROUP_ALL: ShowString "Group #" & idx & " is of type group all"
                  Case GROUP_GEOMETRY: ShowString "Group #" & idx & " is of type geometry group"
                  Case GROUP_OPERATIONS: ShowString "Group #" & idx & " is of type operation group"
                  Case SYSTEM_GROUP: ShowString "Group #" & idx & " is of type system group"
                  Case SYSTEM_RESULT: ShowString "Group #" & idx & " is of type system result"
                  Case GROUP_TOOLPATH: ShowString "Group #" & idx & " is of type group toolpath"
           End Select
       Next
   End If
      ' -- Echo their name
      ShowString GetGroupNameFromNumber(idx)
      ' -- Rename groups
      If Not SetGroupNameFromNumber(idx, "My New Operation Group #" & idx) Then
         ShowString "Could not set operation group name for " & GetGroupNameFromNumber(idx)
      End If
   Next
   ' -- Create a temp group
   If CreateGroupFromName("Test Group") Then
      ' -- Delete it?
      If askYesNo("Delete new test group?") = mcMSG_YES Then
         If DeleteGroupFromName("Test Group") Then
            ShowString "Group Deleted"
         End If
      End If
   Else
     ShowString "Could not create Test Group but it was created??"
   End If
      Exit Sub
   Else
      If intGroup = 1 Then
         ' -- We can't remove the only group
         ShowString "One group remains"
         Exit Sub
      End If
   End If
   If askYesNo("Delete last operation group by number?") = mcMSG_YES Then
      ' -- Delete the last operation group
      DeleteGroupFromNumber intGroup
   End If
      Exit Sub
   Else
   End If
End Sub
And one more
'//          Date:   15/03/2004 09:30 AM
'//     File Name:   SetEveryOtherOpForPostingOff.vbs
'//   Description:   Iterate all operations in current drawing, set every other
'//                  operation off for posting.
'//      Comments:   Requires March Maintenance release
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
Dim intOpCount, idx, intCount
' -- How many operations do we have?
intOpCount = GetOperationCount(vbNullString)
' -- Test
If intOpCount = 0 Then ShowString "No operations in current drawing": Exit Sub
' -- Initialize
intCount = 0
' -- Let's see how many operations are off before we do anything
For idx = 1 To intOpCount
    If GetOperationPostingFromID(vbNullString, idx) Then
       intCount = intCount + 1
    End If
Next
' -- Test
If intCount  = 0 Then
   ShowString "All operations are set to post off"
Else
   ShowString intCount & " operations are currently set to posted on, we will now set all of them post off"
End If
' -- Turn off all ops first regardless if they are on or not
 If SetOperationSelectedFromID(vbNullString, idx, False) Then
     If Not SetOperationPostingFromID(vbNullString, idx, False) Then
        ShowString "Could not turn off operation # " & idx
     End If
 End If
Next
' -- Initialize
intCount = 0
' -- All operations should now be off, lets do a quick check
    End If
Next
   ShowString "All operations are set to post off after call to SetOperationPostingFromID(FALSE)"
Else
   ShowString intCount & " operations are posted on!!??"
End If
intCount = 0
' -- Select every other operation
For idx = 1 To intOpCount Step 2
 If SetOperationSelectedFromID(vbNullString, idx, True) Then
     If SetOperationPostingFromID(vbNullString, idx, True) Then
        ' -- Success
     Else
        ShowString "Could not set operation # " & idx & " off"
     End If
 End If
Next
If intCount > 0 Then
   ShowString intCount & " operations are set to post off from " & intOpCount &  " total operations"
End If
' -- Post only what is not ghosted
'Call RunPostAll(GetPathOfThisScript, True)
End Sub
Thanks guys for your help, and for wasting your appreciate time answering my question.
I have created my needed VB script, basing it on what you told me here, changing my original idea.
Finally, I convert the toolpath from post off to post on, because it was very difficult for me to choose only the operations to change.
Below I’m going to share my script, so that anybody can use it if needed.
' -- Start Script
Call Main()
Sub Main()
Dim intOpCount, idx
' -- COGEMOS TODAS LAS OPERACIONES QUE TENEMOS
' -- MARCAMOS POST OFF AQUELLAS OPERACIONES QUE ESTÁN POST ON
Dim success
    success=SetOperationPostingFromID(vbNullString, idx, False)
Next
 RunPostAll "", 1
End Sub
Thanks again.
Thank you for sharing,
you may want to incorporate some error handling in your code as Mick did.
I noticed you created a variable called success but never use it.
Jm2c
Also, if you learned something, it's never a waste of time! 😀
