What is this statement doing?
if (mr1$ <> mr1flg), phsm_off
I understand that it is stating "if misc real #1 is less than or greater than mr1 flag, turn off high-speed machining.
But I don't understand what the mr1 flag represents.
I'm thinking thats a logical not operator <>
its a boolean flag find where its declared
mr1flg:
then see where it is being alterned
I'm not sure what that means (I really need to take some basic programming courses)
This is the complete line in the post:
if (mr1$ <> mr1flg) | (mr2$ <> mr2flg) | (mr3$ <> mr3flg), phsm_off
So, I get that it's stating that if mr1, or mr2, or mr3 are greater or less that mr1flg, mr2flg or mr3flg, respectively , turn off high-speed machining.
But I have no earthy idea what the mr flags represent.
Does: if (mr1$ <> mr1flg) mean "if mr1 is greater than 0"?
I don't know the language, I think its
if mr1 does not equal mr1flag or mr2 does not equal mr2flag .. then phsmoff
It's the MP language used for MC posts
Yes, I understand that, I am saying I don't "speak" Mp
201. Default miscellaneous real variable 1 (mr1)? 0.0
mr1_flg    : 0      #Flag to indicate whether look ahead function is active or not
phsm1_on         #High speed functions before G43
      if opcode$ = 3 | opcode$ = 16,
        mr1$ = 0
        mr2$ = 0
      if mr1$ = 1 & mr1_flg <> 1, #Advanced Preview (look-ahead) control - G08 P1
phsm2_on         #High speed functions after G43
        mr1$ = 0
        mr2$ = 0
#      HPCC is working when called before G43.4 on Fanuc 31i, see phsm_1 above
phsm_off         #High speed functions Off
      if mr1_flg = 1, #Advanced Preview (look-ahead) control - G08 P1
From my post
I've got it. The flag is set in the phsm2_on or phsm_off sections.
        mr1$ = 0
        mr2$ = 0
        mr3$ = 0
      if fmtrnd(mr2$) & not(mr2flg),
        pbld, pn, *mr2$, pe  #M821 - Accuracy Level 1 through M830 - Accuracy Level 10
        mr2flg = 1
      if mr1$ & not(mr1flg),
        shapecomp_r = mr5$
        pbld, pn, "G61.1", [if shapecomp_r, *shapecomp_r], pe
        mr1flg = 1
      if mr3$ & not(mr3flg),       #you can't call any G codes inside this
        if dyndatum <> 1,
          pbld, pn, "G5", "P2", pe
          mr3flg = 1
phsm_off        #High speed functions off
      if mr3flg,
        pbld, pn, "G5", "P0", pe
        mr3flg = 0
      if mr1flg | mr2flg,
        #pbld, pn, "G64", pe
        pbld, pn, "G61.1 P0", pe
        mr1flg = 0
        mr2flg = 0
      hsmflg = 0
In MP those characters represent the "Not Equal To" Logic Operator. (<> is NOT EQUAL)
If 'the current value of MR1$' is not equal to the 'value of MR1 Flag', then do something...
Zeek,
Based of my reading:
Someone created a variable (mr1flg), that tracks the state of MR1.
If the value of the current Operation has a value that is different from the value programmed in the last Operation, then don't turn off HSM.
If the value of MR1 is different from the last Operation's value, turn off HSM.
It makes more sense, if you are aware that each depth-cut or Multi-pass, is coded as 'an operation', in the NCI Data.
So this allows you to skip turning off HSM (mode remains on), unless there is a new value detected in MR1.
When there is a new MR1 value, the HSM Off block gets called here.
There will be other logic, to output the HSM On block. Search for both 'mr1$', and 'mr1flg', using Code Expert Editor, and use CTRL + B to set a bookmark at each location where those variables are used.
mr1flg is user defined, so there should be a variable initialization somewhere. It may be in the PSB, depending on who built the Post.
mr1$ is predefined, so the Post Developer can just 'use it', without having to format or initialize the variable.
Have you attempted to watch my Post Processor Development Class on YouTube yet? 28 videos for basic MP...
11 minutes ago, Colin Gilchrist said:
Zeek,
Yes, I had been assuming that the <> was the same as the ≠ sign.
I got it sorted out, I didn't initially see where it was defined, so I was worried it might be in the binned portion. I'm a little slow on the draw some days.
That was where I was brain-farting for a bit. I don't know why it took me 20 minutes to decide to do the simple search, that I should have thought of 1st thing. Meh, like I said, 'some days I'm a little slow'🙃.
