Probing C-axis offset on a Mazak VCU500
Any probing gurus out there who can verify that this will work?
We have a couple of vise fixture plates that we use for 95% of the work we do on this machine, using preset XYZB & C offsets, passed thru the our programs. Each fixture is a little bit off the 0 angle of "C".
I already use Renishaw's o9817 B axis measurement program to set the "B" offset. We put a 6" x 1/2" x 1-1/4" parallel centered in the 5" vise & run the our program to measure & enter the offset.
As it is now, we use an indicator to find & set the "C" offset.
What I'd like to do is modify the o9817 program, changing the axis variable to C (#3=5) and save it as o9818 to measure & set the "C" offset. My program would look like this:
G0 G17 G20 G40 G80 G90 G94
G54.4 P0
G53 Z0.
G53 Y0.
G53 X0.
M46 M43
G53 B0. C0.
M00
(LOCATE & SECURE THE V562 VISE & ADAPTER PLATE)
(THOROUGHLY CLEAN THE BOTTOM RAILS & JAW FACES OF THE VISE)
(CLAMP A 6" X 1/2" X 1-1/4" PARALLEL CENTERED IN THE VISE)
#5221=-9.84252
#5222=-9.84252
#5223=-20.733
(***G54 SET C OFFSET***)
G53 Z0.
G53  B90. C270.
T30 M06
G54
G65 P9544 H1 (CALCULATE G54.4 DYNAMIC OFFSET)
G54.1 P300 (CENTER OF ROTATION WPC)
G54.4 P1
G0 G90 G54 X0.0 Y-0.225 G43 H30 Z6.
G65 P9818 X5.6 Z0.25 S1
G65 P9810 Z6.0 F50.  (PROTECTED MOVE)
G54
G53 Z0.
Be aware on some machines you need to move the C Axis away from the Picked up Position to apply any changes to the offset and then move back to make sure they applied. I did this years ago on a Mazak Integrex in the post to output my logic as I wanted it.
      if drillcyc$ = 11, #C Axis Measure - Vertical B0/B90/B180
           pdrlcommonb
           if babs = 180,
                pbld, n$, *strg659810, prnrefht, e$
                pbld, n$, *strg659818, *cyspan, pfxout, *offupdate,[if cangtoler > 0, *cangtoler], [if drl_prm2$ > 0, *drl_prm2$], e$
                pbld, n$, *strg659810, *prnrefht, e$
           if babs = 90,
                pbld, n$, *strg659610, prorefht, e$
                pbld, n$, *strg659618, *cyspan, pfxout, *offupdate, [if cangtoler > 0, *cangtoler], [if drl_prm2$ > 0, *drl_prm2$], e$
                pbld, n$, *strg659610, *prorefht, e$
           if babs = 0,
                pbld, n$, *strg659818, *cyspan, pfxout, *offupdate, [if cangtoler > 0, *cangtoler], [if drl_prm2$ > 0, *drl_prm2$], e$
           *sg00 ,*sg91, sg30_3, "X0", e$
           *sg00, *sg90, [if workofs$ > 53, *g_wcs], [if workofs$ < 49 , "G54.1", *p_wcs],[if spindle_no$ = 0, "C20."],[if spindle_no$ = 1, "U20."],e$
           *sg00, *sg90, [if spindle_no$ = 0, "C0"],[if spindle_no$ = 1, "U0"], e$
           spaces$ = 0
           sif,sbracketopen,spound,sm152,sgt,drl_prm1$,sbracketclose,sgoto,ngoto2, e$
           spaces$ = 1
           pcom_movea
You will notice the C20. or U20. based off the Spindle I was probing. This was automatically output anytime I was probing for C0 or U0 on that machine.
