SlaveCam 116
Got it:
atest : 0.0
stest : ""
pheader$ #Call before start of file
stest = opinfo(1032, 0)
atest = rparsngl(stest, 1)
"Test:", *atest, e$
Zaffin_D 205
Just so you are aware, this is not an ideal use for opinfo. When you tell opinfo to query an NCI line it searches the NCI file that’s on disc.
I’m almost positive you can get the value you are looking from a traditional parameter in memory, have you done a parameter dump?
Using opinfo on an NCI line should only be done if the data isn’t available in memory.
SlaveCam 116
15 minutes ago, Zaffin_D said:Just so you are aware, this is not an ideal use for opinfo. When you tell opinfo to query an NCI line it searches the NCI file that’s on disc.
Hi,
This hack is due to this problem
Program numbers are not written at all to NCI for transform operations, so I have to use a transform operations's misc integer. Furthermore, trans_mi$ does not contain the "latest" mi-value in case of nested operation. If you know a better way, I am all ears
Colin Gilchrist 3,304
31 minutes ago, SlaveCam said:Hi,
Are you sure the values aren't written to the NCI? There is a switch inside the Control Definition, that controls which parameters; Original Op or Transform or Both, that actually get written. Is that switch set to "Transform" or "Both"?
I'm honestly not sure either way, but I do know that switch exists in the CD.
1
SlaveCam 116
1 hour ago, Colin Gilchrist said:Are you sure the values aren't written to the NCI? There is a switch inside the Control Definition, that controls which parameters; Original Op or Transform or Both, that actually get written. Is that switch set to "Transform" or "Both"?
No, I'm not sure. Didn't even think about the existence of such a switch. I'm going to check it out tomorrow, thank you for this tip!
Check on the "Files" page. This actual "Parameter Setting" (Radio Button) would be a zero-based index. Meaning "Option 1 = 0", Option 2 = 1, and Option 3 = 2.
I think you either want "Option 1" (Parameter output as "0", for the 1st option in the list), or "Option 3" (Both) [Option 3 would output as "2" for this parameter, being the 3rd item in the list.]
Technically, you won't be querying the value of the Radio Button. All you really care about is "are my Transform Operation Misc Values being written to the NCI File"?
SlaveCam 116
I did some testing and it seems no matter what's selected in the abovementioned setting, the program number of a transform operation that uses another transform operation as source does not have its program number written to NCI. So in this case program number seems to be kind of a special case.
In 4 axis work it's common that I use the same source operations for different tombstones and the fixture positions may wary as well, so there is no avoiding nested transforms, unless you love useless extra repetitive work. G54.2 would be a huge help, so maybe I'll get it one day.
Recently Browsing 0 members
A NCI file has the following lines:
1031 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 1032 3000 0 0 0 0 0 0 0 0 0
These are transform operation's custom parameters, where 3000 is the value of trans_mi1$ (or actually in case of nested transform, it is not, thus my attempt at opinfo)
The following code outputs the following string Test:3000 0 0 0 0 0 0 0 0 0
stest : "" pheader$ #Call before start of file stest = opinfo(1032, 0) "Test:", *stest, e$
However, I don't know how to capture the "3000" part of the NCI line; if I change the code to
test : 0 pheader$ #Call before start of file test = opinfo(1032, 0) "Test:", *test, e$
the result is always 0 or -99999, no matter what I enter into the second and third parameter.
How Do I Use Opinfo Correctly?
