Okuma 5 Axis problem
Max_vgl
Hello,
I have a problem with my Okuma Mu 400 VA.
We bought this machine a few weeks ago and I ran a few tests on it but it wont make a full 5 axis cut.
I read about TCPC (G169) on Okuma and tried it but it throws an error.
I cant find a solution maybe someone can help me out here?
3 hours ago, Max_vgl said:
Hello,
Will have to get a hold of the application team from whom you bought the machine from and have them come in and give you a break down of what the machine can and cannot do. Where did you get your post to post the code from? What toolpath are you using to make 5 Axis motion for the machine? Was a CDS or 5 Axis Artifact run to prove out the machine? I tell all of our customers getting any new machine make them run a CDS for 3 Axis, 4 Axis part for a 4 Axis and 5 axis part on your machine. Test 20 different items since I have seen to many 5 Axis machines setup and not done correctly. Fought with one customer years ago changing a program for 6 weeks never able to dial some blends in. It wasn't until the applications manager realized they had bumped their machine 1st day and never said anything. He rechecked all the machine parameters and they were off. The told him it was setup that way. He then pulled up the alarm history they thought they had erased and showed them overload condition in Z 1 day after the machine was installed. Then they confessed they were trying it out and bumped the machine. That was the customer on that one, but seen other times where parameters were not configured correctly or options that should have been installed were not. Why a customer should always run a test piece as part of the purchase order with the machine. Funny thing is it helps machine builders get a machine paid for quicker since some companies don't know the first thing about 5 axis. They can take months getting their machine up and running and refuse to pay for it until they make a good part. The test piece serves 2 purposes and helps both sides of the process. The customer and the machine builder.
We had a guy here he help us setting up the machine but only for 3 + 2 machining. I asked him about simultaneous but he wasnt sure if the machine can do that.
Im using a post from Fusion 360. I want to rewrite it for the MU and the only problem is simultaneous machining.
I found a manual for a few 5 axis functions maybe there is something that explains my problem.
Thank you for your help :)
You'll definitely want to get in contact with Okuma.
All "full 5-Axis" Controls require proof of the "machine's physical location". There are Export Control regulations which control this.
You will need someone to check the Parameter values on the machine, and must also check to be sure that Tool Center Point Control (TCP) is:
1.) > Enabled
2.) > Properly configured on the Machine Parameter side
Like all 5-Axis Functions > There is a correct order for calling/nesting the 5-Axis Functions, with other functions like "high-speed machine functions". This means that your combination of 'machine functions' must be called in the correct order (output to the NC Code), and then cancelled in the correct order.
With any of the "True 5-Axis Functions", you must calibrate the Center of Rotation Parameters, and also calibrate the Tool Measuring (Tool Length Offsets). Making the machine cut accurately is always a combination of "correctly configured NC Code" and "set of Machine Parameters and purchased Machine Functions", that work together.
I see so many companies that "have 5-Axis machines", but only do positional work. They do this with a "3-Axis Methodology & Approach", and always have to tweak each individual Work Offset, and Tool Offset, to make a complete part that is "in tolerance". Every time they breakdown the job, and set it back up, they struggle with getting a good 1st Article part, and have to scrap a few parts before the job is back up and running smoothly. It doesn't have to be this way.
By using the CALL OO88 Function, and TCP, you can just "set a Work Offset with the Probe", and start cutting.
1.) > Enabled
Yeah I think Im going to contact someone cause I dont want to mess up the Parameters.
Thank you.
10 hours ago, Greg Williams said:
What error do you get?
The machine is from germany btw.
And the error is in the line with "G169 ..."
This is what a G169 command looks like on our Okuma MU-1000 horizontal 5 axis trunnion machine
This is an OSP200 control 2013 vintage
Note that the G169 line defines all 5 axis X Y Z A and B and includes the tool length offset HA
N2
(SEMIFINISH FLOOR)
(LEAVE .030 STOCK)
(OPERATION NO - 2)
G116 T58 (1.25 X .25R INGERSOLL 2.75 LOC)
M01
G15 H1
/T8
M404
M11
M21
G00 G17 G90 A-86.219 B17.422 S1528 M03
G00 X.046 Y15.2523
G00 G169 HA X-4.4732 Y3. Z-14.409 A-86.219 B17.422
X-4.4732 Y2.4274 Z-14.409
X-4.4851 Y1.8288 Z-14.4467
G94 G01 X-4.493 Y1.4296 Z-14.4719 F80.
X-3.3439 Y1.3606 Z-14.1331 A-86.229 B13.311
G56 is not used in 5x toolpaths
also note that the A and B axis are prepositioned prior to defining them in the G169 line
(POSTABILITY OKUMA GENOS 460V 5AX)
(DRILL BIT)
(MASTERCAM - 2021)
(MCAM FILE - C:\CUSTOMERS\XXXXXXXXXXX\DRILL BIT\DRILL BIT MACHINING.MCAM)
(POST      - MPPOSTABILITY_OKUMA_Genos_460V_5ax.PST)
(PROGRAM   - TOOL 4.MIN)
(DATE      - 2020.09.23)
(TIME      - 2:17 PM)
(T4   - 1/4 BALL ENDMILL     - H4   - D4   - D0.2500" - R0.1250")
(T2   - 1/4 BALL ENDMILL     - H2   - D2   - D0.2500" - R0.1250")
G00 G17 G20 G40 G80 G90
G00 Z=VPPLZ
N1
(FINISH WALL SECTION TOOTH 1A)
(OPERATION NO - 52)
(OPERATION TYPE - SWARF 5AX)
G00 Z=VPPLZ
T4 M06 (1/4 BALL ENDMILL)
G15 H10
M404
CALL OO88 PX=0. PY=0. PZ=0. PA=-96.0845 PC=323.0572 PH=10 PP=51
G00 G17 G90 X.89187 Y3.22605 (TOP MAPPED)
G15 H10
M11
M27
A-96.0845 C323.0572 S5348 M03
G56 HA
M510
G00 G169 X2.11649 Y1.33059 Z-3.49328 A-96.0845 C323.0572 T2
M08
M51
G94 G01 X2.01361 Y1.19377 Z-3.47504 F60.
X2.01296 Y1.19031 Z-3.47414
X2.01018 Y1.17293 Z-3.4721
X2.00848 Y1.15538 Z-3.47388
X2.00839 Y1.1385 Z-3.47926
X2.0103 Y1.12307 Z-3.48775
X2.01452 Y1.10978 Z-3.49869
X2.02086 Y1.09881 Z-3.51117
X2.01958 Y1.10268 Z-3.49839 A-93.3087 C323.7743
X2.01849 Y1.1068 Z-3.48563 A-90.5325 C324.4874
X2.01759 Y1.11118 Z-3.47287 A-87.7561 C325.1999
X2.01686 Y1.11581 Z-3.4601 A-84.9801 C325.915
X2.0163 Y1.1207 Z-3.4473 A-82.2049 C326.6363
X2.01592 Y1.12585 Z-3.43446 A-79.4309 C327.3673
X2.01589 Y1.12586 Z-3.43435 A-79.4323 C327.367
X2.01586 Y1.12587 Z-3.43424 A-79.4336 C327.3667
X2.01584 Y1.12588 Z-3.43413 A-79.435 C327.3664
X2.0158 Y1.12589 Z-3.43398 A-79.4368 C327.3661
X2.01577 Y1.12591 Z-3.43386 A-79.4383 C327.3658
Here it was mapped with CALLOO88 Positioned the A and C axis then G56 HA was called and then G169 was called like Gcode's example. This was posted for a OSP-300M control last year.
So what does that say in English?
I run pretty much the same as Ron in Metric
(POST - OKUMA-MU-TCP)
(POST REV - 8.3)
(DATE - 07-07-21)
(TIME - 08:10)
(MCX FILE - 5AX__2021.MCAM)
(NC FILE - 5AX TEST.MIN)
(T6|EMUGE 12250A |H6)
VC200=0.2 (TOOL BREAKAGE TOLERANCE)
M404
G0 G17 G40 G80 G90 G94
G0 G16 H0 Z999.
M11
M27
G0 A0. C0.
(EMUGE 12250A |TOOL - 6|DIA. OFF. - 6|LEN. - 6|TOOL DIA. - 12.)
(TOP FACE 1)
N1 T6(EMUGE 12250A TOOL - 6)
M6
G15 H1
G0 G90 A-63.1049 C19.1142 S4000 M3
CALL OO88 PX=0. PY=0. PZ=0. PC=19.114 PA=-63.105 PH=1 PP=51
G0 X3.582 Y28.217
G56 HA Z101.04
G15 H1
M510 (CAS OFF)
G169 HA
G1 X-30.302 Y98.376 Z20.541 A-63.1049 C19.1142 F15000.
M8
M51
M120
Y32.764 Z-.146
X-27.382 Y24.337 Z-4.67
X-24.462 Y15.911 Z-9.194 F800.
X-24.458 Y15.913 Z-9.195 F1000.
X-24.347 Y15.979 Z-9.246
N2
(SEMIFINISH FLOOR)
(LEAVE .030 STOCK)
(OPERATION NO - 2)
M01
G15 H1
/T8
M404
M11
M21
G00 X.046 Y15.2523
I tried it that way but it wont work. Always the same error.
(DRILL BIT)
(MASTERCAM - 2021)
(DATE      - 2020.09.23)
(TIME      - 2:17 PM)
G00 Z=VPPLZ
N1
(OPERATION NO - 52)
G00 Z=VPPLZ
G15 H10
M404
G15 H10
M11
M27
G56 HA
M510
M08
M51
Hmm thank you I am going to try this one. I thought i cant use CALL OO88 and G169 together.
  • 3 years later...
3 hours ago, Rick Henrickson 65 said:
Ron, what are the values representing behind your Call 0088? we getting an MB-56V with an indexer 4+1, we are trying to figure out G169 or G605 or CALL 0088. Vericut doesnt like any of them to much but that is to be expected till we figure out how to use it.
Thanks.
Colin, pretty much nailed it.
From my experience, CALL OO88 is for Tilted Work Plane (3+2), not for TCP. TCP should be G169/G170 (on/off).
CALL oo88 = "Call an internal Subprogram on the control and pass values to the subprogram for execution"
(Similar to G68.2)
Colin, Ron, Greg thank you for the replies and good to hear from you all. Ron, this was some code you posted
what are the values doing behind the 0088.
I have never dealt with an okuma using this, the Mazak VCU is just G codes and it handles the coordinates.
Thanks for the help.
PX value is the amount from the workoffset how much shift should the post coded use to shift the matrix call to.
PY value is the amount from the workoffset how much shift should the post coded use to shift the matrix call to.
PZ value is the amount from the workoffset how much shift should the post coded use to shift the matrix call to.
PA value is the amount from the workoffset how much rotation should the post coded use to shift the matrix call to.
PC value is the amount from the workoffset how much rotation should the post coded use to shift the matrix call to.
I am not sure about PH and PP and been years since I have looked at an Okuma Control.
PH and PP
PH is the original unshifted work offset that the operator sets. In this case it is #10
and it is usually your Mastercam Zero as well.
PP is the new shifted offset. In my experience, it is always PH =1
Here is an example from our Okuma MU 1000H horizontal 5 axis  mill
CALLOO88 calls subroutine  OO88, a proprietary Okuma subroutine
which calculates a new PP value.
In Mastercam, there are tool planes for Sec M-M and Sec A-A
The origin of these planes  is the same as the main WO, in this case #10
That is why PX, PY, PZ PA and PB are the same in the CALLOO88 statement as
they are in the toolpath.
The control calculates the distance in X,Y,Z, A and B from the defined WO#10 (Mastercam origin)
to the actual pivot point of the machine and uses this data to calculate a new WO #11
Then it evokes WO#11 and runs the toolpath.
If you watch the work offset page on the control, you will see the value of WO#11
changing as new PP = 11 values are calculated
(*** SEC M-M ***)
(SPOT CHECK)
(OPERATION NO - 8
CALL OO88 PX=0. PY=0. PZ=0. PA=-45. PB=202.5 PH=10 PP=11
M11
M21
A-45. B202.5
M10
M20
X0. Y-1.7678
Z15.
Z12.1054
G71 Z12.1054
G81 Z11.5954 R11.7054 F2.25 M53
G00
Z15.
(*** SEC A-A ***)
(SPOT CHECK)
(OPERATION NO - 9)
CALL OO88 PX=0. PY=0. PZ=0. PA=-45. PB=180. PH=10 PP=11
M11
M21
A-45. B180.
M10
M20
X0. Y-1.7678
Z15.054
Z12.1054
G71 Z12.1054
G00
Z3.
(*** SEC C-C ***)
Now let's say you want to output Sec-A-A's gcode at the face of the feature
which is at X, 4 Y6, Z8  from your Mastercam Zero (WO#10)
In Masterm, you would copy the Sec A-A tool plane, setting  it's origin at
X4, Y6, Z8
Now the CALL0088 statement would look like this
(*** SEC A-A ***)
(SPOT CHECK)
(OPERATION NO - 9)
CALL OO88 PX=4. PY=6. PZ=8. PA=-45. PB=180. PH=10 PP=11
M11
M21
A-45. B180.
M10
M20
X0. Y0.
Z3.
Z.5
G71 Z.1
G81 Z-.005 R.1 F2.25 M53
G00
Z15.054
 Hope this makes sense.
The below format will run as well
M404
N1 G0 G16 H0 Z999.
M11
M27
G0 A0. C0.
G30 P1
(16 ENDMILL R0.5 4FL |TOOL - 16|DIA. OFF. - 16|LEN. - 16|TOOL DIA. - 16.)
G116 T16(16 ENDMILL R0.5 4FL TOOL - 16)
G0 G16 H0 Z999.
M01
G15 H1
G469 P1 Q313 X0. Y0. Z0. I0. J-45. K0.
G467 P1
G0 G90 A-45. C0. S1790 M3
G0 X16. Y-31.074 Z999.
G56 HA Z75.064
G468 P1
M510 (CAS OFF)
G169 HA
G0 X16. Y31.106 Z75.05 A-45. C0.
Y-33.544 Z10.4
Y-40.616 Z3.329
G1 Y-47.687 Z-3.742 F600.
X15.998 Y-47.515 Z-3.913 F700.
X15.979 Y-47.116 Z-4.313
