MSL
Generic Haas VF-TR_Series 5X Mill post
Hi,
I noticed on new Generic Haas VF-TR_Series 5X Mill post we have an option to switch to G28 or G53 home.
But none of these options sends the machine's Y axis home at the end of program. What would be the best approach to send the Y axis home only at end of the program?
Thank you.
Code it into the peof section
That's the "end of file" section
John is right. You can code this move into the "peof$" Post Block.
Typically, the first line in 'peof$' makes a call to 'pretract'.
Inside of 'pretract', you have this logic:
      if nextop$ = 1003 | tlchg_home, pbld, n$, *sg28ref, "X0.", "Y0.", protretinc, e$
The "if nextop$ = 1003" is used to flag "end-of-file". You should uncomment this line (if commented out), or add this line to your post. (May have to remove the 'tlchg_home' condition, if you don't have that switch in your Post.
Depending on how the logic is setup in the VF_TR Post, it may be using 'sg28ref' to output the "G53" command.
It might just be easier to add the line directly to 'peof$', after the call to 'pretract'...
Thank you John and Colin,
I added these lines after pretract in "peof" and It outputs the codes I wanted.
 pretract
	  if return_mode = one,
        #pbld, n$, *sgcode, *sg28, *sgabsinc, "Z0.", e$
	pbld, n$, *sgcode, *sg28, *sgabsinc, "Y0.", e$
	else,
        #pbld, n$, sg53, *g53_return_z, e$
	pbld, n$, sg53, *g53_return_Y, e$
Colin, always a gentleman.  I wish I knew what you've forgotten.
