Sign in to follow this
essid.mh
New CAM programming algorithms
To improve the quality and the precision of the complex surfaces obtained by high speed machining and increases the service life of the CNC machine or Robots, it is necessary to integrate the manufacturing parts process parameters as a boundary condition in the calculation of the tool path: Dynamics of CNC machine axes, the parameters (numerical and kinematics) of the computer numerical control, parameters of the smoothing mode, …
I am writing to inform you that I am in the process of  developing of   new  CAM programming algorithms  approaches  allowing to integrate the principal parameters of the CNC units (smoothing mode defined in the CNC unit, anticipative setpoint mode of the CNC unit, maximum capacity of the feed-forward control, the effect of the axes inertia variation,...) in high speed machining process.
The proposed new software belongs to industry 4.0.
it allows  :
1) simulate the dynamic motion of the CNC machine taking into account the effect of all the environmental elements of the machining operation (parameter of the CNC unit, smoothing mode, NC file , tool/part interaction)
2) suggest to the programmer:
          a) improvements in the parameters defined in the cam software:  machining tolerance, smoothing tolerance, smoothing mode, ...
          b) improvements in the parameters defined in CNC unit : max axis jerk, max axis acceleration, feedforward control,.... ( the new cnc unit allow their parameters to be defined in the NC file, like sinumerik 840D).
3) create modifications at the NC file  in order to improve the machining quality
These algorithms can be programmed in CAM software or in post processor or in CAM simulation software
The new algorithms developed   result in a significant improvement in the accuracy and roughness of the free-form surface parts produced by high speed machining (CNC machine and robot).
The proposed project is in the form of new mathematical models for calculating the tool path integrating the drive controller parameters as a boundary condition.
In addition to these three projects, several other guidelines can be developed in this area with the aim of producing a new intelligent generation of CAM software.
Are you interested in collaborating in order to finalize the study ?
Best regards
Essid Mohamed
Teacher researcher : ISET SFAX and UGPMM-ENIS ( Tunisia)
https://www.linkedin.com/in/essid-mohamed-567865177/
https://www.researchgate.net/profile/Mohamed_Essid
How much do I get paid to consult????🤣
  • Haha 3
This sounds like an interesting project
I'm 99% sure the old Yasnac Matsuuras had this....I bought a 1994 FX5 for a place I worked, and I'm sure we had the high speed tolerance codes where we specified "?" (can't remember now) and that was a 0.1mm profile tolerance, and another code for 0.05mm etc...
....and a bit more trolling :lol:....purely because you state "Industry 4.0" (which for those that don't know, is the WEF's 4th Industrial revolution) :rolleyes:
Below is your post on Practical Machinist, stating you already have the algorithm to allow for optimal tolerance blah blah (attached).
So how does this work - how does your algorithm "tell the CAM" to allow for the following different machines?
Can you please explain?
I want to make the same part on 3x different machines.
#1 machine is a large Haas VF8 machine - a big heavy table with slow acceleration and deceleration.
#2 machine is a much smaller Haas - smaller lighter table with the next generation faster processing control and much better acc/dec.
#3 machine is a gantry design machine - the table is fixed and the axes are a bridge/portal design. So although mass of component on the table is irrelevant, unfortunately I have an issue with the X axis where there is "some" out of squareness to the Y.
This has an early Fanuc control with no lookahead processing.
IIRc Colin was making some really neat test parts on one of the new Yasnacs, it was very precise
i forgot the exact numbers already
I sometimes dabble in code, what language is your software written in?
Linux CNC does this. I believe it's g64.1 pxxxx for your corner rounding tolerance
(It was a Yasda machine, with a Fanuc 31iB5 Control...)
A Yasnac isn't a control that I have a lot of experience with.
I do however, know a bit about kinematics, motion control, high-speed modes, and NURBS processing. Add in the correct Dynamic Codes for Tilted Work Plane, Tool Center Point Control, and Workpiece Setting Error Correction, in addition to properly calibrated kinematic values, and the machines work like magic.
Parameter Settings and Proper Kinematic Calibration. Both of these are the real Boundary Conditions of making accurate components on any CNC Equipment. Repeating buzzwords like "Industry 4.0" won't overcome the real-world obstacles everyone encounters when they try and build software that solves a hardware problem.
Don't get me wrong; I'm all for progress and technological innovation, but I don't hear anything new in the offer being made here.
You can write NC code to query a lot of functions on the three major brands of control: Siemens, Heidenhain, and Fanuc. But without some kind of understanding of how all the equipment was configured and calibrated, good luck with trying to solve something in a novel way.
ah ok, yeah I got mixed up, yours was the yasda, It was someone else with the yasnac 👍
The thing not being shared is the testing and prove out process of this. Where are your machines located for testing? How many builders are on board to allow for the testing? What is your regression testing progress look like? What are your gauge R & R parameters for ensuring that the improvements are living up to what is being promoted? How many different parts and material have you developed and tested these on? What tool brands have you also tested the process with? What are the parameters for such? What about holders, fixtures, cutting fluids, and other things that play an important part in machining and getting the best results? How does the algorithm take those factors into account?
I was approached years ago by a team at a highly respected University. They wanted me to help them with their study similar to yours. There were 14 people with 20 PhD behind their names. They had 20,000 hours into their algorithm. I asked them about the same question and got a bunch of well and hum good points. Then I asked them to show what it could program. It could only do simple stuff. Anything really complex or other things they thought it would be another 20k to 40k hours to do 3 Axis then maybe another 100k in hours to get basic 5 axis parts. That was 6 years ago still not able to handle the 3 axis stuff. Know of 4 other companies trying to do the same thing all floundering so curious how your experience is going to best all of them?
What are your credentials for doing this? Background and other things to make anyone think your not trolling?
  • Like 4
Unite the Luddites - to Hell with the 4th Industrial Revolution :hrhr:
  • Haha 1
A fair amount of that was promised with STEP NC... back in the 1990's. And here we are 25 years later with no measurable improvement beyond CAD interoperability which would be expected regardless because of natural progression.
Call me a skeptic if you want, I prefer REALIST. There are few if any "standards" CNC Controls adhere to beyond CE basic electronics. Until THAT changes, this is nothing more than mental and code xxxxion.
Don't get me wrong. I like new stuff, I thrive on new stuff, and new stuff usually comes from impossible ideas.
Industry 4.0 ... more meaningless buzzwords from educrats.
  • Like 5
