Sign in to follow this
AMCNitro
Indicating bore with Probe on Haas
I mat have to cut some molded parts on a mill for a second opp.  Its a round part with a bore.  Bosses want to have each part indicated, I know how to do that.  Problem I'm seeing is that the Indicate Bore routine on the Haas doesn't ask for a depth, you have to take it to the depth and then run the program.
How would I go about doing that?  Write the coordinates BEFORE the probe program ?
you set the probe up as a tool and just program it to the center of the bore and to the z depth that you want then call the probe bore sub
This is a sub I call to...it'll look something like this...though mine is not for a Haas, the premise will be the same
(*PROBING ROUTINES*)
N8901(PROBE 1 ROUTINE - FUSION LASER BENCH)
(PROBE 1 POSITIONS AFTER INITIAL OFFSETS SET)
(PROBE POSITION 1)
Z1.
G65P9809T1X.155Y-.1467F100.
G65P9809T1Z.1F100.
G65P9810Z-.565F100.  (This goes down inside the bore)
G65P9814D.22S#19(X,Y OFFSET)     (This calls the ID cycle)
G65P9810Z.25F100.
G65P9810X.625Y-.1467F100.
G65P9811Z-.125S#19(Z OFFSET)
G65P9810Z.1F100.
G28Z1.
(END PROBE 1)
M99
  • Like 4
Below is for a Haas, you will want to use the inspection plus macros and not use the Haas GUI
You can find the inspection plus manual here:
https://service.haascnc.com/sites/default/files/Locked/2/Renishaw_Programming_Manual_H_2000_6222_0A_B.PDF
M06 T24 (PROBE)
G00 G90 G154 P1 X0. Y0.
G43 H24 Z3.
G65 P9832 (TURN ON PROBE)
G65 P9810 Z0.2 F100. (PROTECTED MOVE)
G65 P9810 Z-0.5 F100. (PROTECTED MOVE)
(S1=G54,S2=G55....G154P10=S154.10)
G65 P9814 D1.75 S154.01 (BORE CENTER FIND)
G65 P9810 Z0.2 (PROTECTED MOVE)
G65 P9833 (TURN OFF PROBE)
G00 G53  Z0.
(T10)
(START MACHINING)
M06 T24 (PROBE)
G43 H24 Z3.
G00 G53  Z0.
(T10)
(START MACHINING)
I did it right from the machine control, I had to add some lines of code, but it was very easy.  Just saw what the machine wanted to do, and from there I figured out what it needed from me.
Thanks for this though.  And thanks to everyone that offered help
