Probing - RMP60
Probing - RMP60
1)  Trying to do probing  on DOOSAN NHP 5000  -HMC with B axis machine. Control Fanuc 31i - Model B
2) History -  we did only manual probe of the  raw material to set the offsets and measuring some feature  size etc only...no other serious probing. Machine is installed with Inspection plus & probe is RMP 60.
3) we started testing CAM (mastercam) based  probing just a week ago..with  CIMCO .
4)All the 3axis measuring  we did on the B0 side without any issue and it worked  good. We Checked ...hole dia & depth  , rectangle pocket size , single surface side angle check , Hole dia check and  re-cut by auto adjusting tool wear etc on B0 face..
5) PATH OBSTRUCTION  error pop-up when  rotated the B axis table to 90 ( B+90/-90/45/30 etc )  to check the  features on the B90 face .  Probe switch on at 9832 then goes to the line 9810 and throws the alarm but still the probe is around 60mm above the part surface.
6) Job mounted on  Tombstone face - B0
Please look at the code below and if anyone can point out my mistake...
TY
O0056
( DIA MEASURE on B90 FACE )
N2 M24
N4 M132
N6 ( TOOL LIST )
N8 ( T40 - RMP )
N10 G21
N12 G00 G17 G40 G80 G90
N14 G91 G00 G28 Z0.
N16 M01
N18 G69
N20 ( B90 SIDE - DIA. MEASURE )
N26 ( T40 - RMP )
N28 T40 M6
N30 G54
N32 S0 M05
N34 M184
N36 ( REF PLANE + B90 )
N38 G90 G00 B90.
N40 G68.2 P1 X0. Y0. Z0. I0. J90. K0.
N42 G53.1
N44 G00 X20. Y17.542
N46 G43 H40 Z150.
N48 M165 P9832
N50 G65 P9810 X20. Y17.5423 Z70. F600.
( PATH OBSTRUCTED ERROR AT THIS LINE )
(also tested removing N50 , probe advanced to Z32.5 ( refer N52) ) and retract back without any probing move )
N52 M165 P9823 A0. B120. C-120. D20. Z32.5 R-8. Q5.
N54 M165 P9810 Z70.
N56 M165 P9833
N66 M5
N68 G69
N70 G91 G00 G28 Z0.
N74 G00 G28 X0. Y0.
N76 G00 G91 G28 B0.
N78 M25
N80 M133
N82 M30
I work for Doosan. probing works well on that machine. I think you may be trying to enter machine interference zone. How close to the machine table are you in Y Axis? How close is the spindle face in the Z Axis are you to the machine table. That machine does have a couple of interference zones you need to be mindful of.
  • 4 weeks later...
I may be a little late to this party but I use Doosan 1250's and those codes wont work on my machine. I would change this:
to this:
N50  M165 P9810 X20. Y17.5423 Z70. F600.
You use M165 on every line but that one. Our Doosan's require M165 instead of G65 on probing. I also don't need to use P9833/P9832 in my probing, its automatic.
  • 4 weeks later...
